Tonneau cover thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AY_ARONTRD, Nov 1, 2017.
  1. Dec 8, 2017 at 7:10 PM
    #81
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    It's been raining non stop here since I got it so I haven't been able to take any pictures. Take a look at this thread though -https://www.tacomaworld.com/threads/oem-tonneau-cover-install.444415/. You can keep the same bed rails your truck came with but you will need to cut them to fit the locking pins for the tonneau. Hope this helps.
    Mooseman537[QUOTED] likes this.
  2. Dec 9, 2017 at 6:22 AM
    #82
    cookingorsleeping
    cookingorsleeping Active Member
    17 trd pro cement at
    level kit, c4 fab low pro bumper, sumosprings, are fridge, diamondback cover, rci sliders, led hd
    The diamondback cover is sprayed with a bedlinen line x yes it is the same as what you are talking about but what I don't know is the cover is avail in sprayed or alum I bet you could spray it yourself it is only sprayed on the exterior it is hands down the best cover on the market it just has so many apps and mounting acc the best part is the weight it can hold so its your hunting deck/ leisure deck etc
  3. Dec 9, 2017 at 6:33 AM
    #83
    Bt_osu
    Bt_osu Well-Known Member
    Sw
    2018 Black Trd Pro Automatic
    Trd cold air intake and oil and radiator caps. 2657516 bfg ko2s. Bak revolver 2 tonneau cover, bed mat and extender. Mud flaps. Husky liner floor mats. Locking tail gate. Led bed lights. Carbon black tailgate Tacoma insert. Red Tacoma dash insert. Winco Infrared reducing window tint. Predator steps.
    I went with bak x2 revolver because i wanted almost all bed space usable when tonneau cover is rolled up. The tri-folds either fold and stack at front of bed and cause you to lose bed space or fold up against back window and reduce visibility. That eliminated this type for me. Revolver rolls up but has metal slats under vinyl for better theft protection and strength.
    Love the automatic retracting covers some of you have but the storage box they slide into at front of bed takes up too much space for my purposes
    CusterFan likes this.
  4. Dec 9, 2017 at 6:53 AM
    #84
    Tacos4ever15
    Tacos4ever15 Well-Known Member
    2015 Pyrite Mica Tacoma TRD Off-road 4x4
    How about going from a 16 or 17 onto a 15 ?
  5. Dec 9, 2017 at 7:10 AM
    #85
    jay_zed
    jay_zed Well-Known Member
    16 TRD Sport 6MT, 24 TRD Offroad 6MT
    The bed rails on the 2nd gen are a different shape and the bolt holes for the mounting brackets are missing, will not work
  6. Dec 9, 2017 at 8:00 AM
    #86
    Tacos4ever15
    That’s what I figured, thanks !
  7. Dec 9, 2017 at 9:59 AM
    #87
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    I’m in the market for a cover. I’m leaning towards a hard cover but still entertaining a vinyl roll up. Like so many others, I want to use my bed. Most seem to use the bed rails to mount track. I think it’s the Bak that uses a bracket that mounts the new factory rail back in truck but lower. A local dealer sells Undercover Tonneau covers. They have 3 different ones on display (those mini display models), all are same price installed. When I checked online prices, the covers are around $925 shipped to me. They will provide & install cover for $975. Must be a ton of mark-up on these or they are super simple to install. My question- does anyone have a list of what covers allow use of the factory rail system? What covers are the easiest to remove without having to adjust the whole fit each time? Do any of these covers not leak? Anyone running that retractable cover (don’t need power), can they be stopped & secured in any position? How do they hold up to dust & debris? The more I read, the more confused I get.
  8. Dec 9, 2017 at 10:31 AM
    #88
    Auroraboy
    Auroraboy Well-Known Member
    Dave
    London, Ont., Canada
    2017 Quicksand DCSB Off Road
    Husky Weatherbeaters, BAK Revolver X2, front bedrail, Salex console tray, Predator Steps
    A few of my thoughts on tonneau covers:
    1) Bak, Extang, Truxedo, Undercover, Bedrug and who knows what other brands, are all owned by one company, so just be aware.
    2) Anyone should be able to install a tonneau cover. Save money and do it yourself
    3) Not all Trifolds fold up against the back window. The Toyota OEM one does not, as example.
    4) I have a Bak Revolver X2. It rolls up within 8-10" of the back window, allowing almost full access to bed. The Bak Revolver cannot be stopped and secured in any position. It's either fully open (secured with straps) or closed. It does lower the factory bedrails, by the use of brackets, but because of this, you cannot use the Toyota factory bed divider, if you have that. Some of the Bak Trifolds also lower the factory rails. The cover can be fully removed by removing four bolts (PITA I would think, if you wanted to do regularly)
    5) The Bak Revolver tends to freeze along the side and back seals in wet freezing weather. Should not be a consideration in warmer climates. Something to consider when looking at covers
    6) I think all covers (maybe not a Diamondback) leak - some worse than others
    7) Had an Undercover Flex on another truck. Small screws holding the latching wire assembly etc. were constantly coming loose or falling out. Cheap design.
    8) If you need to worry about hail - check the material used for covers. Some are stronger than others.
    My 10 cents. Good luck deciding on a cover!
    L8Shift and chewbach like this.
  9. Dec 9, 2017 at 10:37 AM
    #89
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I researched bed covers until I was blue in the face, like everything else I buy. I decided to go with the Truxedo roll up. It was only $248 bucks at 4wheelparts and they had it the following day. It rolls up easy and pretty much out of the way, 3 small clamps don’t take up much real estate on the bed rails. I like it a lot and looks clean rolled out or up.
    InsuredToyota and drumr04 like this.
  10. Dec 9, 2017 at 1:11 PM
    #90
    Mooseman537
    Mooseman537 Well-Known Member
    Jim
    Pennsylvania
    2017 MGM Tacoma OR
    Thanks Jay that did help!!
  11. Dec 10, 2017 at 2:26 PM
    #91
    Deathray
    Deathray Are we there yet? ...Are we there yet?
    Jeff
    Central Illinois
    2021 Mazda3 AWD Hatchback
    I wanted a good roll up tonneau. I narrowed it down to TruXedo Lo Pro, or undercover Lorado. After reading exhaustively about the two, I went with the Lo Pro.
    Lifetime warranty, use of the cleat rails without removal, automatic tensioning, 15 second removal of entire cover, and a guy who sells and installs both said he’s seen fewer warranty claims on the TruXedo. Both good roll ups, though. I love the lower profile. 9CE4270B-A2B2-4FA0-8ABD-5D1B39214300.jpg
    drumr04, tacoma98042 and CusterFan like this.
  12. Dec 10, 2017 at 2:49 PM
    #92
    tacoma98042
    tacoma98042 Well-Known Member
    I bought the same one last month and I love the look and functionality of it. Leaks a bit however I didn't install the front seals and the rear seal doesn't completely sit flush with the tailgate.
    Don't forget about the rebate Truxedo has right now on the Lo Pro.
    Deathray[QUOTED] likes this.
  13. Dec 10, 2017 at 3:38 PM
    #93
    Deathray
    Jeff
    Central Illinois
    Yeah, sent mine in! I did install the front seal on the header bar. Only took a few minutes. If you do, be careful not to strip the Torx fasteners. I heard it’s easy to do. Mine weren’t a problem. Haven’t had any rain or snow since I put mine on. Few weeks ago, so not sure about the watertightness.
  14. Dec 10, 2017 at 4:42 PM
    #94
    Hoop21
    Hoop21 Well-Known Member
    2017 TRDOR DCSB 6MT
    I developed an a little issue with my Truck Covers USA roll-up tonneau. I ran it through the carwash a couple days ago and today I tried to open it but the release mechanism is frozen. Not a big deal because I was only trying to get easier access to the front of the bed, but if I needed it open to haul something big I would've been screwed. I'll probably have to wait until it sits in the sun for awhile and then work the mechanism and maybe spray it with some WD or silicone...
  15. Dec 10, 2017 at 5:28 PM
    #95
    Uleth
    Uleth Member
    Just installed an undercover flex hard folding cover. Install was straight forward. Seems to be of decent enough quality, fits flush, even adds to the look of the truck. Someone mentioned above the small screws holding the release wire/latch assembly coming loose and the cover being a cheap design, time will tell I guess but initial impressions are good.
    IMG_0227_zps34z9h196_0bd6dd5b7f342da8ce0a8e19f8628788f6d944cd.jpg[/URL]
    2k4Taco likes this.
  16. Dec 10, 2017 at 7:35 PM
    #96
    Dr. Mantis Toboggan
    Dr. Mantis Toboggan Well-Known Member
    2017 TRDOR 4x4 & 2000 TRD TACO 4x4
    Recently ordered a diamondback cover. Can’t wait to get it in. It will basically make the entire bed an aluminum tool box, but also with the option to haul big items.
  17. Dec 12, 2017 at 5:40 PM
    #97
    TacosnJeeps
    TacosnJeeps Member
    Kevin
    Central NC
    2016 TRD
    Just ordered my Diamondback SE from @Zach.RealTruck. Now just have to be patient. Putting some bitcoin profit to good use!
  18. Dec 26, 2017 at 11:53 AM
    #98
    ebrisse
    ebrisse Well-Known Member
    Atlanta, GA
    SSMDCLBTRDSPORT4X4
    So you've had no problems with the Lo Pro or with ordering from truck alterations? They're cheap but their really basic (kinda 1995ish) website worries me. You recommend? Also, totally bummed I missed the $40 rebate...
    tacoma98042[QUOTED] likes this.
  19. Dec 26, 2017 at 2:22 PM
    #99
    tacoma98042
    Yeah I had no problem at all. I know what you mean about the look of the website but I would recommend buying from them.
    ebrisse[QUOTED] likes this.
  20. Dec 28, 2017 at 8:11 AM
    #100
    Zach.RealTruck
    Zach.RealTruck Well-Known Member
    Zach
    16 Tacoma Inferno SR5
    Lift, wheels, tires, floor liners, tonneau cover, and bed rug.
    Hey just wanted to check in, how'd the cover turn out for you?
    oranjish likes this.
