Tonneau cover with RCI bed rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Powder taco, Mar 11, 2018.
  1. Mar 11, 2018 at 2:28 PM
    Powder taco
    Powder taco [OP] Well-Known Member
    Brent
    Everett, WA
    17 TRD Off-Road
    So I went ahead and decided I wanted to keep some things dry and out of sight at the same time. Went with an access vanish tonneau cover, installed it and found out that it needed to sit more flush.......so I started cutting.
    After getting it in location I went ahead and scribed some cut lines and then tore it back apart.
    The RCI bed rack mounts stick into the bed by roughly half an inch.
    B137337C-995C-432F-A255-D6605F348F2D.jpg 8E1EECC7-2C78-475F-94A2-4E1521FABE53.jpg
    Still need to add just a tab bit of weather stripping on the transition points where the rack mounts meet the tonneau rails, I am pretty happy with it though.
    Pretty happy with the outcome.
    Access 95279 is the part number for the tonneau cover for the 6’ bed.
    LazloCO, SR-71A, Catfish21 and 10 others like this.
  2. Mar 11, 2018 at 5:10 PM
    OrangeTaco101
    OrangeTaco101 Well-Known Member
    Devin
    London Ontario
    17 Taco on 35’s
    That's awesome may do the same one day. Love it
    Powder taco[OP] likes this.
  3. Mar 11, 2018 at 5:12 PM
    bsp_taco
    bsp_taco Well-Known Member
    Nick
    Oregon
    ACLB 2008 2.7L M/T SR5 4x4
    Dirt King 3.5" LT, King 2.5 RRs, Duratrac 35s, 4.88s, arb air locker front & trutrac rear
    Nice job! I too have a tonneau cover/bedrack combination. Pretty great for keeping stuff dry :thumbsup:
    paleh0rse and Powder taco[OP] like this.
  4. Apr 2, 2018 at 11:08 AM
    Boonedoggle
    Boonedoggle Well-Known Member
    Lincoln, NE
    2012 DCSB TRD
    None.... Yet
    @bsp_taco What tonneau cover and rack do you have? I'm trying to find the best solution to use with an Access Literider.
  5. Apr 2, 2018 at 1:09 PM
    bsp_taco
    Nick
    Oregon
    I run @KB Voodoo rack with tonneau brackets (I'd link it but I don't want to cause confusion to the original post) and a Tygerauto tri-fold. I don't need to fold it back, it doesn't matter because I cannot fold it back. I am not sure if the literider will be able to roll all the way back to the cab with the rack/brackets. They'd know better than I would. The rack is great, love it, no issues for the 4 months I've owned it :thumbsup: I live in Portland and the combination keeps 95% of the rain and all snow out of my bed.
    xsf18cdf, Impoy47, Durango95 and 4 others like this.
  6. Apr 8, 2018 at 9:25 AM
    Powder taco
    Brent
    Everett, WA
    17 TRD Off-Road
    Got my CVT tent mounted yesterday at CVT in bend, Oregon.
    Catfish21, Impoy47, ST77 and 3 others like this.
  7. Apr 8, 2018 at 10:27 AM
    Boonedoggle
    Lincoln, NE
    2012 DCSB TRD
    None.... Yet
    Looks great! This motivated me to pull the trigger on the RCI rack to try with the Access Literider. I'll post photos once the rack arrives and is installed.
  8. Apr 8, 2018 at 12:47 PM
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    That looks awesome. Exactly the set up that I am looking to achieve. I currently have the Extang Solid Fold 2.0 (an OK cover), but I am looking at replacing it. I really like the RCI Bed Rack.
  9. Apr 8, 2018 at 12:57 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    similar idea to what I did with the CBI and Access Original tonneau. Nice work!
    I mounted my tonneau to the rack with some nuts and bolts and then siliconed between the two. Love having dry/hidden storage with the rack
  10. Apr 8, 2018 at 3:09 PM
    bsp_taco
    Nick
    Oregon
    Looks great!!
  11. May 22, 2018 at 11:05 AM
    moostache
    moostache uhhh...
    Queen Creek, AZ
    18 OR 6MT
    Downgraded driver, added a sticker.
    I've sorta narrowed my choices down to the CBI or the RCI, with access vanish, and am curious how you mounted the cover with the CBI full length rails?
  12. May 22, 2018 at 5:03 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Take a look a this pic in my build thread.
    I pulled the foam off the back of the tonneau rails and put a bead of silicone between the tonneau and CBI rails. Then drilled a few holes and bolted the tonneau rails directly to the CBI rack. So the cover is attached 100% to the rack versus to the truck now
    hirod and moostache[QUOTED] like this.
  13. Aug 5, 2018 at 10:33 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Thanks for the write-up OP. Just got an RCI rack and RTT and wanted to find an option for a tonneau. Do you know if the Tyger tonneau would also fit or did you choose the roll up version because that was the only option that we can run with this RCI one
  14. Aug 8, 2018 at 8:58 PM
    roguegs
    Angelo
    V8 T4R
    Pella likes this.
  15. Aug 8, 2018 at 9:08 PM
    roguegs
    Angelo
    V8 T4R
    @Uphillshunter can you help me with this? I don't trust myself with the angle grinder.
  16. Aug 8, 2018 at 9:13 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    No problem man:thumbsup:
    Bring it over, we'll cut it up.
  17. Aug 28, 2018 at 2:23 PM
    roguegs
    Angelo
    V8 T4R
    @sd1uh8as this is what I was talking about. Gonna have to modify mine a bit to fit the RCI rack.
    sd1uh8as likes this.
  18. Aug 29, 2018 at 2:37 PM
    Powder taco
    Brent
    Everett, WA
    17 TRD Off-Road
    Went with the roll up because I knew I could make it work. There might be other that will work, went with what I knew I wouldn’t cause me issues.
    roguegs[QUOTED] likes this.
  19. Aug 29, 2018 at 2:39 PM
    roguegs
    Angelo
    V8 T4R
    No worries, I ended up ordering the access cover yesterday. Going to try and install it next weekend. Can you do me a huge favor? can you measure clearance for height with the tonneau on? I have a feeling it would be clocking in at around 18 inches or so.
  20. Aug 29, 2018 at 2:46 PM
    Powder taco
    Brent
    Everett, WA
    17 TRD Off-Road
