Tonneau Cover with Tie down cleat accessibility
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bdunna, Nov 8, 2015.
  1. Nov 8, 2015 at 2:19 PM
    bdunna
    bdunna [OP] Well-Known Member
    2005 tundra access cab
    No seeing what I am looking for.....good soft cover for the winter/summer. Soft roll, tri'fold, whatever. But needs to be: light, 100 % removable or full access to bed, NOT INTERUPT THE USAGE OF FACTORY TIE DOWN CLEATS, no drain tubes.....
    So far i'm considering access loradao (which looks like it states can not use tie down cleats, so that out), and extang tri-fold (can't find a weight)
    Like a roll-up due to not needing to remove a 2 ft by 4 fit tonnneau and have no were to store. So maybe I need a good roll up with access to the tie downs when rolled up.
  2. Nov 8, 2015 at 2:37 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I have an Access tonneau roll up that allows the use of the bed rail system. Access has many different types of tonneau covers.
  3. Nov 8, 2015 at 7:36 PM
    bdunna
    Is it the roll up, sport, or larado. Confused at the different options?
  4. Nov 8, 2015 at 7:37 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Fold a cover elite. Folding but they fit.
  5. Nov 8, 2015 at 7:41 PM
    moondeath
    Pa, Gardners
  6. Nov 8, 2015 at 7:42 PM
    bdunna
    If I was to do folding it would be backflip. Need full bed access. Where do you put the g4 when hauling a full load? The roof?
  7. Nov 8, 2015 at 7:45 PM
    bdunna
  8. Nov 8, 2015 at 8:09 PM
    moondeath
    Pa, Gardners
    Tonneau bite clamps? I'm not sure I know what that would be on the access tonneau. The access roll up bolts into the same spot that the bed rail is bolted to. It goes in behind the rail and comes with longer bolts to accomodate. The only other part that is on the tonneau is a tensioner that is in the front (cab side) of the bed.
    Nothing with the access roll up interferes with any of the bed rail or cleat system. Unrolled or rolled, doesn't matter.
  9. Nov 8, 2015 at 8:28 PM
    bdunna
    Well, you sold me. Truxedo was my next choice. They have the bite clamps.
  10. Nov 9, 2015 at 8:03 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    +2 :thumbsup:
    The cover doesn't interfere with the stock rail setup. Once you get it installed you'll see.
