Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by Nola TSS, Mar 28, 2013.
  1. Apr 1, 2013 at 6:26 PM
    Jerryjc
    Jerryjc Well-Known Member
    New Jersey
    2012 TRD Off Road Barcelona Red 4x4 DCSB
    Tonno Pro soft Tri Fold bed cover
    Can't go wrong with Tonno Pro very happy with mine, It's been on my truck for nine months with no issues at all.
  2. Apr 1, 2013 at 9:48 PM
    stewbag15
    stewbag15 Member
    Stew
    Canada
    09 Tacoma TRD
    Extang Trifecta for me. Had it for 4 years, love it..
  3. Apr 3, 2013 at 6:31 PM
    Nola TSS
    Nola TSS [OP] Well-Known Member
    S Louisiana
    '13 Prerunner SR5 TSS v6
    Received the tonnopro today. Took about 30 min to install. Piece of foam against the back rail against the cab.
    The majority of the time was trying to center the cover. I was probably being a bit anal about trying to get it just right.
    The cover is well built. The vinyl is thick and the rubber gasket appears to be well made. The cover seals well on the sides and against the tail gate. The foam does help in sealing against the cab but there is a little gap on each corner. Will play around a bit more on the weekend to see if I can seal it better. If it does leak it will come from the two corners
    The quality seems to be very good but I don't have anything to compare it to. The frame is heavier than what I thought it would be at this price point.
    Ill report back in 6 mths as it is difficult to provide an accurate assessment at this point.
    This cover did come with the rail kit, weather stripping for the tail gate, an led light and vinyl care kit.
  4. Apr 15, 2013 at 9:35 AM
    Wickedwagens
    Wickedwagens Well-Known Member
    Mark
    Carson City NV
    07 Dbl Cab LB
    3" lift, 285/70/R17 BFG A/T
    How has it been doing? I am looking at the Tonno Pro also. Where did you get it from? It came with the bed rail kit? Can you still use the bed rail tie downs?
    Tanks in advance,
