Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by pittsburgh_matt, Jan 19, 2010.
  1. Jan 19, 2010 at 7:39 PM
    pittsburgh_matt
    pittsburgh_matt [OP] Member
    TRD Sport
    This is for anybody trying to decide on a new tonneau cover for their Tacoma . I know everyone has their own opinion on which they like best so I just wanted to share mine in case somebody was having trouble picking one. After weeks of searching a bunch of different types and brands I went with the Truxedo Lo Pro QT Soft Roll-Up from auto anything. I wanted one that would still let me use the bed rail system and though this one limits the use you can still use it. Also the product is of very high quality. It comes with a lifetime warranty too. I did the install myself with help from a friend. It only took about 15 minutes and was very easy. They send you brackets that are made for the tacoma. They slide right into the rail system(great idea). All you have to do is place the tie downs in between the brackets and they will be able to slide back and forth between them. The tension system is af very good design and is simple to adjust. Overall I really like it so far. Hope this can be of help to anybody shopping for one.
    later-----------matt
  2. Jan 20, 2010 at 2:49 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Nice post but...
    :worthless:
  3. Jan 20, 2010 at 2:56 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    How much was it? Im looking at a Lund soft tonnoue on Amazon for $169.00.
  4. Jan 20, 2010 at 8:13 PM
    pittsburgh_matt
    TRD Sport
    sorry just bad photos from my phone. Yes it is pretty expensive, i think it is around $450 but it has a lifetime warranty on it including the tarp so any problems down the road with that and you can get it replaced for free.The quality looks very good .mms_picture44_7ab0937f0d3303ab2083adc13fae3773957b3a9b.jpg
  5. Jan 20, 2010 at 8:14 PM
    pittsburgh_matt
    TRD Sport
  6. Jan 21, 2010 at 3:52 AM
    saf023
    East Coast
    Looks nice. Thanks for the pictures. I guess I've got another one to add to the list and consider.
  7. Jan 21, 2010 at 7:03 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    yea this is what i was going to get before i was convenced on buying a bestop
  8. Jan 21, 2010 at 7:47 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    How long does it take to remove when you need to use the bed?
  9. Jan 21, 2010 at 12:00 PM
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    Matt,
    Thanks for the info. I am currently doing exactly the same research and narrowed down my choice to Tuxedo LoPro and Access LE.
    The Access LE is about $40 more than the Truxedo, but comes with the seal and some other extra I cannot remember.
    The only difference between the two I can see is the Access requires you to remove the rails and then insert the mounting parts behind the rails. although it does gives you full use of the rails, they will now be narrower, hence accessories like the cargo divider will not fit anymore since it relies on the original distance between the two rails. On the other hand, the Truxedo uses clamps on the rails if I am not mistaken, so it limits the use of the rails.
    I am curious about your research and what choices you came down to, etc. I am still undecided now.
    Question, you need to open the tailgate in order to unlatch and rollup the tonneau right? same question goes to any Access LE tonneau owner. I am planning to get the pop n lock as well.
    BTW, you can get the Tuxedo LoPro for $100 less than what you paid AA here
    http://truckalterations.com/html/tacomaworld.html
  10. Feb 7, 2010 at 5:52 AM
    hoopscoach
    hoopscoach Active Member
    Danny
    Fredericksburg, VA
    08 DblCab TRD
    Does anyone know if there are tonneau's that will fit an 05+ without having to remove the bed rails.
  11. Feb 7, 2010 at 5:55 AM
    wildtrax1
    wildtrax1 Active Member
    GA
    09 4x4 TRD OffRoad
    EXTANG Trifecta
  12. Feb 7, 2010 at 6:26 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    Not sure if it factors into your decision but with simple modifications the cargo divide is able to be utilized atleast with the Access Literider. If the LE is of the same profile it should work also.
  13. Feb 7, 2010 at 6:28 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    $450! yikes!
    I bought a cheap tonno pro tri fold off Ebay for $269, couldn't happier!
    Super easy install, No rails to mess with, Comes off as easy as it went on.
  14. Feb 7, 2010 at 7:40 AM
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    There are really pros and cons for each. I ended up getting the Access LE, but now maybe thought the truxedo would be better. This is because I have a bed extender, and I am not able to swing it in and out because the tonneau rail is in the way. I also had MAJOR trouble dealing with two torx screws from hell, they stripped while trying to remove the rails. So I suggest anyone using access tonneau to spray PB blaster to the screws first before removing them. If you would never use a cargo divider or a bed extender, then I'd say access tonneau is a better choice (best bang for the buck is the literider for $280 shipped) because the installation will look cleaner (no clamps hanging on the rails), otherwise get the truxedo, which cost about the same as the access le.
  15. Feb 7, 2010 at 7:53 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Extang Tuff Tonneau III. Press and Seal is fantastic, I don't have any leaks, and I have use of my rail system.
  16. Feb 7, 2010 at 7:53 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Same one my father has on his sierra. They're nice covers!
  17. Feb 7, 2010 at 8:07 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Its not a fold, but the Extang Tuff Tonno allows for full use of the rails, I use a cargo divider under mine.
  18. Feb 7, 2010 at 8:10 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Got it on my truck and love it.
  19. Feb 7, 2010 at 9:56 AM
    chazbourne
    chazbourne New Member
    I have a 2010 tacoma I am interested in tonneau and also if any one knows if the Thule 2160 fit kit will work on the 2010 cab. Not sure if 2009 and 2010 are identical cab designs.
  20. Feb 7, 2010 at 10:10 AM
    FishErTaco
    FishErTaco Well-Known Member
    Chapel Hill, NC
    10 DoubleCab 4x4 SR5
    Extang Trifecta tonneau, black textured N-Fabs, AFE Pro Dry S, WeatherTech vent visors, WeatherTech floormats
    I got the Extang Trifecta about a month ago for a 2010 DC short-bed. Fits and looks great, and no problems with the composite bed rail and you can leave the cleats in the bed rail system. Easy to install and remove. Definitely worth it.
