Tonneau cover.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huzie11, Jul 8, 2022.
  1. Jul 8, 2022 at 10:02 PM
    Huzie11
    Huzie11 [OP] Member
    2004 Tacoma
    Hey guys, I have a 2004 Tacoma, 4wD extra cab. I have a fiberglass Tonneau cover which I took off years ago in lieu of a camper shell. Somehow I managed to lose the hydraulic arms and am trying to replace them now. I'm not sure what size support arms I should be looking for. Wondering if anyone here has a similar cover on their truck and could help me determine the correct size arms? Thanks.
  2. Jul 8, 2022 at 10:39 PM
    02hilux
    Planet: EARTH
    -Will help if you know what brand cover
    -Call the manufacture?
    -Measured the mounting to mounting location (while closed) and go to your local auto parts and check their lift support selection?
  3. Jul 9, 2022 at 5:59 AM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    I have an ARE hard cover on my truck, let me know what you need measured, if you have an ARE
  4. Jul 9, 2022 at 8:05 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have a SnugTop tonneau cover which would nearly be identical. Here is the part number for what I used. You might need to swap the ball studs on the truck or tonneau but that’s expected with new struts.
    Qty (2) PM2048 SE1200M80BL 4568 Tonneau Cover Lift Supports 29.50" Extended 13mm ends 030359 030475 2934 713120 7131201200 713120-1200 716821 8196319 RB8795984 https://www.amazon.com/dp/B00EFDYFHW
  5. Jul 10, 2022 at 10:57 AM
    Huzie11
    Huzie11 [OP] Member
    2004 Tacoma
    So there is no brand indicated anywhere on the cover. It was on the truck when I bought it. I measured from the ball studs to roughly the front edge of the tonneau cover and it's about 36 inches. Can't remember if the rods are fully closed when the cover is down so wasn't sure if 36 inches is what I should be looking for?
  6. Jul 11, 2022 at 10:02 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    36 inches sounds way foo long. Are you measuring between the two mounting gas stut points when in the open and closed positions?
    Not sure what the “front edge of the tonneau” has to do with the gas spring size?
