Tonneau covers for 2019s?
Discussion in 'Tonneau Covers, Caps and Shells' started by cnliberty, Nov 4, 2018.
  1. Nov 4, 2018 at 4:17 PM
    cnliberty
    cnliberty [OP] Member
    Christopher
    2019 toyota tacoma sport
    So I have a 19 tacoma sport shortbed and am looking for tonneau covers.Many sites don't show anything for a 19 but toyota hasn't changed anything with bed since 16 have they
    tacoscott16 and Sum1 Else like this.
  2. Nov 4, 2018 at 4:20 PM
    Sum1 Else
    Sum1 Else Well-Known Member
    They are the same, nothing has changed
  3. Nov 4, 2018 at 4:22 PM
    cnliberty
    Christopher
    That's what I figured, thanks. BTW any recommendations on tonneau covers?
    Sum1 Else likes this.
  4. Nov 4, 2018 at 4:35 PM
    maverick42
    maverick42 Well-Known Member
    2018 red TRD Off Road
    Big fan of my truck covers American roll cover. Not cheap but worth it imo
  5. Nov 4, 2018 at 4:37 PM
    USPfan
    USPfan Well-Known Member
    North of 60th paralell
    2018 Tacoma TRD OR DCSB
    I really like my OEM tonneau cover. Others don't, all up to preference.
  6. Nov 4, 2018 at 4:38 PM
    cnliberty
    Christopher
    None of them seem to be cheap I'm leaning towards undercover ultra flex but from what I've heard I can still use my track system w the cleats just limited movability
  7. Nov 4, 2018 at 4:39 PM
    Sum1 Else
    My limited came with the factory cover as
    do 90% of the Limited have.
    I really did not care for it at first, but now
    really like it. It was the only option on the truck, and that was exactly the way I wanted.
    I wanted to pick out after market stuff myself,
    not forced with crap like paint sealant and
    over priced carpet mats, etc.
    The Limited is maxed out with all the plush goodies anyway.
    USPfan and erikarthur like this.
  8. Nov 4, 2018 at 4:51 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Not sure if you're considering hard or soft, but I have a tri-fold Extang trifecta 2.0 (~$350) for my '18. Quality is good and it's super easy to open/close, but if money wasn't a factor I'd have gotten the solid-fold 2.0. (~$850).
    CusterFan likes this.
  9. Nov 4, 2018 at 4:54 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I wanted the ultra flex too but opted for the one piece SE because the joints started leaking and the locking mechanism parts broke in a lot of reviews. It depends on how often you need to put large items in the bed. The one piece is essentially water right. And it can be removed pretty easily.
  10. Nov 4, 2018 at 4:55 PM
    cnliberty
    Christopher
    I'm looking for a hard one ,Lmao,tonneau cover.I still am kicking around the brands now but I'm gonna check that extang out for sure thanks
    jboogy27 and DA3 like this.
  11. Nov 4, 2018 at 5:07 PM
    ms231
    ms231 Well-Known Member
    Westchester ny
    Any issues with leaking with the trifecta?
  12. Nov 4, 2018 at 5:16 PM
    tacoscott16
    tacoscott16 Well-Known Member
    scott
    2018 TRD pro
    you also can use 2nd gen double cap tonneau cover for your 3rd gen.
  13. Nov 4, 2018 at 5:21 PM
    DTaco18
    Yes it does leak a little bit. Mainly from washing and direct hose, but definitely not 100% water tight.
    tacoscott16 likes this.
  14. Nov 4, 2018 at 5:26 PM
    tacoscott16
    scott
    2018 TRD pro
    never 100% tight, but when u truck roll, look at the truck bed ,the bed move badly so tonneau cover never 100% water tight.
  15. Nov 4, 2018 at 5:27 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    I got a Bakflip mx4 installed about a month ago and I'm really liking it. Not totally waterproof, but works great, is lockable and sturdy. My dad has the undercover ultra flex on his 2nd gen and they are pretty comparable however I like mine a little better because it is lower profile when looking from the side. Also, mine allows you to close the cover or the tailgate in whatever order you want but his requires you to close the cover last.
    Noch, Mistaken and tacoscott16 like this.
  16. Nov 4, 2018 at 5:32 PM
    ms231
    Westchester ny
    Yup figured nothing is watertight but had the extang encore for a bit and couldn’t get it to stop leaking at the folding seams. The solid fold I had on my F-150 was actually pretty water resistant so definitely not against extangs.
    The trifecta does seem like it would avoid the problems I had with the encore since it has no folding seams.
    Thanks for the feedback
  17. Nov 4, 2018 at 5:36 PM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    I see you mentioned a hard cover specifically. In the event you are also considering a soft trifold, here is some info.
    I am very happy with my tonneau cover. It is Lund Genesis Elite model, trifold soft cover. It's been on my 2017 AC Tacoma for about 9 months. Zero leaks. The "Elite" model uses a premium cover material manufactured by the Harrtz Co., which produces materials for OEM convertible tops. The Elite material has a woven appearance like you would see on a convertible top on a luxury car. Lund also makes a regular Genesis trifold, which uses a vinyl material, and is less expensive.
    Many detailed YouTube videos on the product and its installation. It went on fairly easy. Also, simple to remove and reinstall. It attaches to the OEM rails in the bed utilizing a clamp system. The rails and tie-downs can still be used. No need to drill or otherwise modify the truck.
    I am sure there are other good products out there. Lund is the only one I have direct experience with.
  18. Nov 4, 2018 at 7:48 PM
    Mc269
    Mc269 Well-Known Member
    2018 TRD Pro
    I really like mine. not totally waterproof but I am fine with that.IMG_0070.jpg IMG_0070.jpg
  19. Nov 4, 2018 at 7:57 PM
    imovelives
    imovelives Well-Known Member
    Erwin
    San Diego
    18 Tacoma TRD off-road 4x4
    Flowmaster, Pace Edwards Jackrabbit, bedrug, pop n lock TAILGATE lock Kuat Bikerack NV, PioneerNDBC8 front camera, pioneer avh-w4400nex head unit, DWG D10 17x9, good year wrangler ultra terrain AT Kicker speakers font/back Max Modular KBvoodo 10 inch rack (linger on short bed) Freespirit high country medium RTT Pedal Commander
    Pace Edwards Jack rabbit. It locks from the outside with a key and locks every 12 inches. Aluminum under vinyl. Love it
    It’s lower profile than the switchblade cover from Pace Edwards which locks and unlocks from the inside. Tail Gate is what locks it on that one. Amazon for $1100
  20. Nov 4, 2018 at 8:02 PM
    Virginian
    Virginian Well-Known Member
    Raleigh, NC
    2017 Tacoma Double Cab TRD Off Road
    451B9DC8-EFD9-4F7A-87AF-237CF14F50B7.jpg 323B6572-FC30-49F1-9195-60BBDAB2681C.jpg 3BC990AD-2466-4CA1-8653-560C7DBD9447.jpg 1258E4B2-565F-4848-9758-FF8764E6ECE4.jpg +1 Undercover Elite. Easy to install to the bed rails and keeps the moveable cleats. Comes in a Huge shipping box. My box was pretty beat up, but no damage to the cover. (Big truck ship due to size.) Only nervous about the hardware bag getting out, but it was there. Good instructions, but I ended installing the mounts just a bit more forward than shown on the installation instructions to get a better fit at the tailgate. It’s a little awkward to take on and off, but can be done in just a couple of minutes. (Even with a short wife!) Just watch that you don’t drop it on the pointy corners, and I put a thick towel in the middle to store it on edge! I personally like the security...tailgate can’t be opened without the cover up. Only negative is My key is the groved key which won’t work in the cover lock. They will send you separately (free) a notched key instead. Virtually waterproof. I got the non painted black that I felt looked great on my MGM. And as a backup plan, thought it would be an easy sell to someone else since black looks pretty good with all colors ( if I want to sell and get something else later. Also didn’t want another painted surface to wax! If dollars were no issue, like to have a trifold also, keep both.
