Tonno pro
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue, Aug 7, 2010.
  1. Aug 7, 2010 at 6:43 PM
    littleblue
    littleblue [OP] New Member
    Does anyone have a picture of a tonno pro tri fold tonneau on their 2010 Tacoma? I'm wondering if the tonneau is tapered to fit the bed (since the Tacoma bed is not square) or if the tonneau is square and looks funny when it's on.
  2. Aug 8, 2010 at 9:43 AM
    WolfPac
    WolfPac Member
    10 DblCab White 4x4
    Here's some pics of the TonnoPro on a 2010. The cover doesn't sit really sit flush in the back over the tailgate, because the top of the bed isn't flush all around. But for the price it's not bad. Bought it in an effort to improve gas mileage and cover stuff I was hauling in the bed.
    Pro: Price, it's a tri-fold and secures in place for hauling stuff, can be remove in minutes if need be.
    Con: Not completely water tight, but that because of the top of the bed. does have a thick weather seal all around the edges.:)
  3. Aug 8, 2010 at 12:42 PM
    littleblue
    Thanks for the pictures! It looks good. Question-where the top sits on the side rails, is there more side rail exposed near the cab than there is at the tailgate end since the side rails get narrower as you get toward the tailgate? Or is it uniform all the way down.
  4. Aug 8, 2010 at 1:26 PM
    WolfPac
    WolfPac Member
    10 DblCab White 4x4
    It's uniform all the way down. You have to center the cover first than hand tighten it down. The front end of the bed and tailgate are lower than the side rails. The TonnoPro has thicker weatherstrip on the front and rear though to compensate for this.
  5. Aug 8, 2010 at 2:31 PM
    littleblue
    Thank You!!
  6. Aug 8, 2010 at 6:18 PM
    littleblue
    One more question-can you still use the tie-down cleats on the utility track while the top is on?
