tons, cummins, 40s, 80 series Land Cruiser build
Discussion in 'Other Builds' started by 92LandCruiser, Oct 8, 2013.
  1. Sep 18, 2014 at 4:44 PM
    #361
    92LandCruiser
    92LandCruiser [OP] Well-Known Member
    Nevada
    Cummins, tons, 40s
    Going to have to pull the the timing cover and make sure everything is lined up. From what I can tell the only thing that times a VE pump is having it indexed to dots and letters on the gear at tdc compression. I gather that the p pump may very.
    From there timing is measured from the back of the pump with a sst dial indicator to measure lift. Meh Ill just set it pretty neutral and see how it runs slightly advanced from there. That doesn't quite make sense to me though now that im reading it. If rotating the pump can advance timing then the pump has to be timed?
  2. Sep 18, 2014 at 11:50 PM
    #362
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Okay, think I have a better idea of what's going on now. Going to work through a couple things and go from there.
  3. Sep 19, 2014 at 10:14 AM
    #363
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  4. Sep 19, 2014 at 10:20 AM
    #364
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Off topic but you did do the Killer dowel pin already right?
  5. Sep 19, 2014 at 10:45 AM
    #365
    Large
    Large Red
    Never been to this site but I get this message when I try
    :laugh:
  6. Sep 19, 2014 at 6:40 PM
    #366
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Oh that's lame!
    Yes I used a coat hanger, pliers, a punch, hammer, and red loctite.
  7. Sep 19, 2014 at 7:37 PM
    #367
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Nice job sir, you figure out the problem yet though?
  8. Sep 20, 2014 at 12:08 PM
    #368
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    No, pulled the pump top, replaced the throttle shaft bushing and seal, swapped governor springs. Hardest part was getting the idle screw out of the way to get to one of the pump top bolts.
    Waiting on these guys to answer me back. Theyre saying keyway shkuld be at 10 at TDC and mines at 7 o'clock position...
  9. Sep 21, 2014 at 4:46 AM
    #369
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Well doesn't look promising... can't see that theres anything wrong with timing.
    Keyway lines up with mark on pump face, it's all facing the right way for a 6bt. Pump gear timed to 'E'.
    So... thoughts now, pump internals fucked -- doubtful, it's throwing fuel at the injectors comparable to any other cummins I've seen.
    headgasket? -- I do have shit in my oil but dunno if it's residual or what. Truck hasn't run much (if you call that running) so seems kind of odd. Not getting oil in coolant, not getting bubbles in coolant, not getting smoke in exhaust. Could still be leaking into oil though, haven't checked for excessive blowby because it doesn't run for fuck. seems plausible this is what's happening. Original oil was black, could be headgasket went to shit after sitting...
    injectors? -- maybe... seems unlikely to me but could be...
    or???
  10. Sep 25, 2014 at 4:29 PM
    #370
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Injectors tested bad. Almost all of them.
  11. Sep 25, 2014 at 4:30 PM
    #371
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Sounds like you may have found your problem
  12. Sep 25, 2014 at 4:32 PM
    #372
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Part of it, going to scope it...
  13. Sep 26, 2014 at 12:13 PM
    #373
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I didn't get to talk to the guy, out of town, but he left me notes on every injector.
    Plugged, no atomization, pegged gauge
    popped at 2800 PSI no chatter, bad atomization
    popped at 3200 psi, 2 holes plugged, no atomization, no chatter
    popped at 4800 psi, 3 holes plugged, no atomization, no chatter
    popped at 2800 psi, okay chatter, okay atomization
    popped at 3600 psi, 4 holes plugged, no chatter, no atomization
  14. Sep 26, 2014 at 12:49 PM
    #374
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Sucks, but at least you have a solid place to start.
  15. Sep 26, 2014 at 1:05 PM
    #375
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Ordered lucas 300 prince of darkness injectors from Industrial Injection. I wanted those anyway lol
  16. Sep 26, 2014 at 1:12 PM
    #376
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Hurry up already!
  17. Sep 26, 2014 at 2:51 PM
    #377
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    SHITTTTTTTTTT
  18. Sep 27, 2014 at 1:51 AM
    #378
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    scoped out the cylinders, man I tell you what, bore scope what handy tool man you know what I'm sayin? Mighty nice of my buddy to let me use it when he just bought it.
    All the pistons look good except number 1 looks like it's coated in oil and water or something, but it wasn't firing anyway, that injector was fucked. Can still see cross hatch in all cylinders. Everything looks cool. Took a bunch of snapshots but have to get the images off the SD card, and I dunno how the fuck to do that...
    Stuck it in the oil pan but I could only see main caps or something, IDK. Hard to make shit out. Have to get pretty close for the LEDs to work. Cool tool though. Glad the pistons and cylinders weren't fucked.
    I'm hoping if I do have a coolant leak it's either the head gasket or the oil cooler.
    I'll try to post pictures later.
  19. Oct 4, 2014 at 3:18 PM
    #379
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  20. Oct 4, 2014 at 4:00 PM
    #380
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Good to see this finally running. Ive been lurking from the get go. Cant wait to see it rolling around. What have you decided about the driveline issues?
