tons of lights on! need help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cmatt1605, Nov 9, 2010.
  1. Nov 9, 2010 at 10:07 AM
    Cmatt1605
    Cmatt1605 [OP] Well-Known Member
    Cody
    Mount Pleasant, South Carolina
    Squeaky leaf fix
    -check engine light on
    -(break!) light on
    -abs light on
    -speedo not working
    -a/c & heater fan not working
    -windows will not roll down
    -rear diff lock light is on (the red one with the x over the rear axle) BUT I DONT EVEN HAVE A REAR DIFF LOCK ON MY TRUCK!
    does anyone know what is going on?
    this started after attempting the "anytime fog light mod." so any ideas?
  2. Nov 9, 2010 at 10:11 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  3. Nov 9, 2010 at 10:13 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    WTF?!?! Maybe a fuse??:confused:
  4. Nov 9, 2010 at 10:14 AM
    Cmatt1605
    Cody
    Squeaky leaf fix
    yeah i was kinda figureing that it was one, but which fuse would do ALL OF THAT???
    im completely lost
  5. Nov 9, 2010 at 10:17 AM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    try reversing the foglight mod? check all wires for slices / shorts
  6. Nov 9, 2010 at 10:18 AM
    Logically Insane
    Logically Insane Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    Sounds like you tapped into the wrong wire.. lol
    I originally tapped into the wrong wire when I did it, but only the check engine light came on.. It went off when I redid it.. but dang... idk what to tell ya.. good luck
  7. Nov 9, 2010 at 10:20 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Is this while engine is running?
  8. Nov 9, 2010 at 10:23 AM
    Cmatt1605
    Cody
    Squeaky leaf fix
    i already reversed it, put everything back to stock, and this morning when i started up the truck all that came on.......idk whats going on
  9. Nov 9, 2010 at 10:24 AM
    lasllc
    lasllc Wait. . what’s wrong here
    Southwest RedRocks
    13 SuperWhite DCSB Sport TRD
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    Frankly, I doubt it is a fuse; if it is it would need to be one that is involved in the ECU in some major way.
    I would suspect that a more likely senario is an inadvertant short, either during the work or actually installed ( ie. wrong wire in wrong position, etc) or something fried the ECU (or some portion of it).
    Seems to me that it is time to tow it to somewhere that has the electronics to chase it down.
  10. Nov 9, 2010 at 10:27 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Disconnect the battery for a while then reconnect it.
    Otherwise...something definitely got screwed up during modding.
  11. Nov 9, 2010 at 10:27 AM
    Cmatt1605
    Cody
    Squeaky leaf fix
    the weird part is that is still drives fine, i drove it to school this morning and it worked fine.
  12. Nov 9, 2010 at 10:27 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Well you were fiddling around with your wiring. So there are three possibilities, right?
    1. You shorted something temporarily while you were working, and blew a fuse.
    2. You wired something up wrong, and blew a fuse when you powered up.
    3. You wired something up wrong, and caused component damage when you powered up.
    How confident are you that you wired everything up right? If I were not confident, I'd return everything to stock first, before I did anything else.
    You did disconnect the battery while you were working on the wiring, right? Whether or not you did, that's a practice you need to adopt from now on.
    Then, I'd check the fuse boxes first, and see what's blown. Could be multiple fuses.
    Then I'd replace any blown fuses and power up again.
    If I returned wiring to complete stock configuration, left the battery disconnected long enough for all the computers to reset, made sure all the fuses were good, and still had lights on when I powered everything up, I'd come to the unfortunate conclusion that I might have damaged one of the circuit boards - though a loose/broken connector is also a possibility.
    You'll need a code reader to see what the diagnostics are telling you. If one of the boards/computers/control-units is returning a "failed" diagnostic, I'd check continuity of all its leads, triple check I didn't cross wire anything, and if that test passed, I'd try and locate a replacement from a wrecking yard.
    Good luck.
  13. Nov 9, 2010 at 10:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    You more than likely blew the 120/140 AMP ALT fuse.
  14. Nov 9, 2010 at 12:24 PM
    Cmatt1605
    Cody
    Squeaky leaf fix
    The battery was disconnected, and everything has been turned back to stock, and its still doing it....how ling do i have to leave the neg cable off for the comp to reset?
  15. Nov 9, 2010 at 12:25 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    I think it's about time to take it somewhere.
  16. Nov 9, 2010 at 12:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    If you have check the fuse I referenced and it is fine, then I would follow PB65Stang's suggestion.
  17. Nov 9, 2010 at 12:33 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    similar thing happened to my friends 05 Dodge Ram when he had the Drivers side door removed. All the problem lights were on, Turned out to just be a fuse. if its not that then get it checked out.
  18. Nov 9, 2010 at 12:37 PM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    :popcorn:Getting ready to do the mod, want to see how you make out here. Retrace all of your steps, with truck running good I have a hard time believing you fried anything, but possible i suppose. I hope you get it figured out without having to unload any $$. I'd be tempted to get the codes scanned at autozone or something first to make sure you aren't missing something simple. Good luck man.
  19. Nov 9, 2010 at 6:30 PM
    Cmatt1605
    Cody
    Squeaky leaf fix
    problem solved!!!!!! after hrs of looking in the black fuse box and checking each fuse by eye, i decided to break out my test light, checked all of them, and there all good, so i also decided to check by eye under the dash once more, they looked fine.....so i tried the test light again, and it was a freaking 10A fuse that powered all of that crap! so lesson learned: always use the test light first!
    however i am not going to re-attempt to do this mod, because i also found out today it is illegal to run fogs without headlights on in my state....
  20. Nov 9, 2010 at 7:25 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Bravo! Rep to you for sticking with it and figuring it out.
