Tonto27's Go Anywhere Build
Discussion in '1st Gen. Builds (1995-2004)' started by Tonto27, Feb 6, 2013.
  1. May 6, 2015 at 2:27 PM
    #421
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    oo dual swing out!
  2. May 6, 2015 at 4:24 PM
    #422
    Tonto27
    Tonto27 [OP] We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    indeed!
    main bumper goes back on the truck tomorrow hopefully and i'll tack the rest together on the truck to check any clearance issues
  3. May 6, 2015 at 7:08 PM
    #423
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Oh i dig that man good work!I just got a new welder and would loVe to make a swing out onto my tg. Im thinkin single swing out though.... yours is very fancy! Did you sing the bearing pieces into those two extensions so you can weld around them 360*?
    Ive always wondered where the hell do you guys that build all this badass shit get those bearing pieces and latches??
  4. May 6, 2015 at 8:30 PM
    #424
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    thanks man. it's been a bit of a headache but i tend to overthink everything. yes, they are welded 360 around a 1/4" sleeve and the spindle is only welded to the sleeve at the bottom so it doesn't mess with the integrity of the spindle itself. i'll post up some better pics and info once i'm finished. which with any luck should be pretty soon.
    i have the dual shear spindle but i'm building it without for now just so i can get it finished but i ordered spindles and the latch from comp4x4.com and the tire mounting plate from ruffstuffspecialties.com
  5. May 6, 2015 at 9:30 PM
    #425
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    I am going to check out grainger on harmony hopefully this week to see what destaco latches they have on hand so I can look for something close to what I have in mind. Their website seems to show they have a ton of styles in stock.
  6. May 6, 2015 at 11:10 PM
    #426
    Blackdawg
    Monte
    Wyoming/St. Louis
    mccarr.com sells the latches direct. Bit cheaper. Have many many style. Go to pull lever latches.
    don't skimp on the latch either. 2000lb rated all the way.
  7. May 7, 2015 at 4:44 AM
    #427
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    http://mccarr.com
    ??? Not sure if your site is down or what.
    Edit- found it!
    http://www.mcmaster.com
  8. May 7, 2015 at 5:39 AM
    #428
    lotsoftoys
    Jace
    Denver
    bunch of crap
    Very cool information! Are making the spindles vertical from the earth or the bumper? How'd u position them with the bumper off?
  9. May 7, 2015 at 6:50 AM
    #429
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    i didn't have much luck with grainger honestly. and what they did carry needed to be ordered anyways...... for what its worth
    ^this. 2000lb latch or nothing. i have the safety catch on mine and it is what made it possible to mount mine how i did. i would recommend spending the little bit extra just in case you need to mount it a little funny
    vertical from the bumper....ish. i used the two main tubes from the bumper itself as a reference angle (since they are not perfectly even vertically) and built the spindles off of that with a slight cant toward the truck. this way they won't come flying when i open the latch. i'm going to mount the main bumper on the truck and build up from there so the two frames line up with the tailgate and don't look funny.
  10. May 7, 2015 at 7:33 AM
    #430
    NativeTaco
    Travis
    Fort Collins, CO
    '08 DCLB
    Are the latch parts weldable? Or did you drill and tap the holes?
  11. May 7, 2015 at 8:36 AM
    #431
    Blackdawg
    Monte
    Wyoming/St. Louis
    I weld them. Done it to three latches with no problems.
  12. May 7, 2015 at 9:12 AM
    #432
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    I'm sure you could weld them. I bolted mine...... If it doesn't hold how I like..... I'll weld it
  13. May 8, 2015 at 3:13 PM
    #433
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    wheels and tires are on.
    had an issue balancing 2 of the wheels that had a visible "hop" in them at the rim and center bore.
    they stick out just a wee bit further now
  14. May 8, 2015 at 3:16 PM
    #434
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    So cute!
    JK, :jellydance: of the tires. I was looking at getting those when I got these MTR's :pout:.
  15. May 8, 2015 at 3:20 PM
    #435
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    aw, thanks haha.
    i can hear myself think again!
  16. May 8, 2015 at 4:07 PM
    #436
    Blackdawg
    Monte
    Wyoming/St. Louis
    good ole wheelers rims
    looks good man!
  17. May 8, 2015 at 4:19 PM
    #437
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    thanks man. may go back in tomorrow to possibly switch out the bad rim with the one on my spare though. i can feel the vibration in my seat pretty good at about 30mph. (bad wheel is mounted driver-rear)
  18. May 8, 2015 at 4:25 PM
    #438
    BabyTaco
    Wyoming
    2011 RC Tacoma
    I would call up wheelers and see if they would fix it? That's a crappy situation and I wouldn't even want it on my spare.
  19. May 8, 2015 at 4:26 PM
    #439
    Tonto27
    Joey
    Denver, CO
    2004 double cab
    i called and left a message with wheelers, but they are closed fri, sat, and sunday
  20. May 8, 2015 at 5:36 PM
    #440
    lotsoftoys
    Jace
    Denver
    bunch of crap
    Right on, those treadrights were gnarly
