Too all cold weather Tacoma owners.
Discussion in '1st Gen. Tacomas (1995-2004)' started by twodogs, Feb 22, 2012.
  1. Feb 22, 2012 at 6:59 AM
    twodogs
    twodogs [OP] Member
    Brandon
    Colorado Springs
    02 Trd
    Too all cold weather Tacoma owners. When it is cold out (snow cold), my e-brake light will go off for a minute after disengaging it, then come back on and stay on till I drive for about 20 - 30 minutes. I have checked the brakes, all good, and sprayed the cables with lube. Still only happens when it is cold. Any ideas? Thanks for you help
  2. Feb 22, 2012 at 8:56 AM
    Madjik_Man
    Colorado Front Range
    Is the brake fluid topped off?
    If not, the emergency brake light comes on.
  3. Feb 22, 2012 at 9:10 AM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Does your e-brake actually work?
  4. Feb 22, 2012 at 9:17 AM
    GunnyCO
    GunnyCO Well-Known Member
    Colorado Rockies
    98 Tacoma TRD SR5
    Hey TwoDogs, mine does it too. I live a bout three hours west of you in Gunnison, so its a lot colder here I guess. I've just chocked mine up to it being so cold the e-brake handle wont disengage and seat properly. My fluid is topped off, e-brake works, and dont ever feel it dragging.
  5. Feb 22, 2012 at 9:26 AM
    OutlawJas
    OutlawJas Well-Known Member
    Southeastern PA
    04 Stock Ext cab TRD 4x4
    Had the same problem. It doesn't have to be that low. Just below Max is too low.
  6. Feb 22, 2012 at 9:34 AM
    twodogs
    twodogs [OP] Member
    Brandon
    Colorado Springs
    02 Trd
    My brake fluid is at max level. I guess I will chalk it up to a Colorado thing, ha. Brake work fine and doesn't drag either. Thanks guys
  7. Feb 22, 2012 at 9:37 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Mine does the same thing... Probably just whatever small amount of moisture within the cables freezing up. Sometimes it freezes to the point that I gotta really rev it up and dump the clutch to break the rear drums free. I'd say it's normal and no cause for concern.
