Too Big of Tire?
Discussion in 'Wheels & Tires' started by SSHILEY, Mar 27, 2013.
  1. Mar 27, 2013 at 5:40 PM
    SSHILEY
    SSHILEY [OP] Member
    2010 TRD Sport DC
    Just bought a 10 trd sport recently. Noticed my tires rub the uca's but nothing else when turning sharp but not any other time. It does have a leveling kit in the front not sure of brand but measures around 1.25 inches ( The block between the coil and bracket?)and makes the truck sit perfect without anything done to the rear. Currently has 285/70/17 terra grapplers. What's the long term affects of rubbing your uca's and short term effects aswell? Thinking of selling them and going a bit smaller due to them being fairly new. (Have about 5000 miles on them) or would spacers prevent this? ANY HELP IS APPRECIATED! :)
  2. Mar 27, 2013 at 5:46 PM
    Large
    Large Red
    Spacers would prevent UCA rubbing but might get you to rub more in other areas. Your best long term solution is wheels with a different back spacing or smaller tires. What wheels are on there now?
  3. Mar 27, 2013 at 5:47 PM
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    Spacers would most likely remedy this. Or wheels with at least 4.3/4.5 back spacing.
  4. Mar 27, 2013 at 5:49 PM
    SSHILEY
    SSHILEY [OP] Member
    2010 TRD Sport DC
    Just sitting on stock 17" sport rims?
  5. Mar 27, 2013 at 5:51 PM
    Large
    Large Red
    Use some 1-1/4" spacers with 285s and stock wheels & you'll be good
  6. Mar 27, 2013 at 5:56 PM
    SSHILEY
    SSHILEY [OP] Member
    2010 TRD Sport DC
    Sweet thanks ill try that
  7. Mar 29, 2013 at 11:28 AM
    tears5150
    tears5150 Member
    Pete
    Danville
    '08 Tacoma PreRunner Sport
    2.5" Icon Suspension Lift KC light bar/lights Demello Offroad sliders Demello Offroad High Lift Jack Bed Bar
    So let me just make sure I have this right, because I'm about to drop $1,000 on new tires. The recommendation for 285/70/17 tires on stock 17" rims with an Icon Stage 2 (2.5") suspension lift is to add wheel spacers in the front to eliminate any rubbing, right? Any recommendation on the brand of spacers and where to buy them?
  8. Mar 29, 2013 at 11:37 AM
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    SpiderTrax, Bora, & All-Pro just to name a few of the common ones.
  9. Mar 29, 2013 at 12:30 PM
    tears5150
    tears5150 Member
    Pete
    Danville
    Thanks for clarifying. One thing I forgot to ask was whether or not wheel spacers are required for my setup if I plan to continue using the stock 17" wheels. Thoughts?
    PS -- I'm assuming that two sets of spacers will be required so that the front tires don't stick out further than the rears. Right?
  10. Mar 29, 2013 at 12:41 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    NO! the only benefit to wheel spacers is to eliminate rubbing on the UCA. adding wheel spacers will increase your turning arc of your tire and cause it to hit the fender wells even worse if you do not have a lift and have it trimmed to accomodate them. Your best option is to get a wheel that has proper backspacing and offset.
  11. Mar 29, 2013 at 12:46 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Most people on here run Spidertrax wheels spacers and dont have any issues. Matter of fact someone was selling a used set on here about an hour ago but they might already be sold.
    I would add the wheel spacers if I were you to clear the UCA's but you will most likely start rubbing on the front fender lip which is super easy to trim. A simple dremel will be able to trim everything that you need. You will also most likely need to remove the front mud flaps but thats easy. Yes get 2 sets that way the front and rear match.
  12. Mar 29, 2013 at 12:46 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    lower backspaced wheels will still increase the turning arc of the tires and potentially worsen the rubbing same as the spacers. Though, the properly sized and backpspaced wheels are a much better option that bolt on wheel spacers. In some states, (PA is one) spacers cannot be more that .25" thick to pass inspection. I had to remove mine (.75) for inspection and reinstall after passing.
  13. Mar 29, 2013 at 12:53 PM
    tears5150
    tears5150 Member
    Pete
    Danville
    OK, so it sounds like wheel spacers are the answer. Right? A little bit of trimming is cool. What size spacers do you all recommend for what I'm about to do? Again . . . stock 17" wheels with 285/70/17 BFG A/T's.
  14. Mar 29, 2013 at 12:58 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    With the stock 17" wheels and 285's you will need wheel spacers to clear the UCA's. But once you add the wheels spacers you will need to do minor trimming around the front fender but thats the case for all 285 tires not just your setup.
  15. Mar 29, 2013 at 12:59 PM
    Large
    Large Red
    Good rule of thumb, if you're lifting 2.5+ inches in the front and using stock wheels, use spacers.
  16. Mar 29, 2013 at 12:59 PM
    tears5150
    tears5150 Member
    Pete
    Danville
    Cool. Thanks everyone.
  17. Mar 30, 2013 at 4:04 AM
    DevL
    DevL Well-Known Member
    Oh no... that wont eliminate ANY rubbing... you still need lots of trimming and a cab mount chop etc. thats only to stop rubbing the UCA. Just learn all the possible trims people do and then if you have to do less all the better. Every 285/70R17 is a differnt size... 285/70R17 is just a guideline and not a precise measurement. If you have tires that are big and new UCA that add caster tyo get good alignemnt specs you are looking at a lot of metal cutting.
