Too Broke for Coilovers - Suspension Question
Discussion in 'Hawaii' started by cubiclesurfer, May 21, 2015.
  1. May 21, 2015 at 7:59 PM
    cubiclesurfer
    cubiclesurfer [OP] Well-Known Member
    Kailua-Kona, HI
    hey, I know a lot of you are suspension experts over here, so I have a n00b question that could result in some degree of burnage :rolleyes:
    I currently have 5100's/885x in the front and 5100/Icon AAL in the rear. I was thinking about trying to get a little more height in the front, without getting too nuts and killing my CV angle (see pics)
    So, is it possible to add a 1/4" top spacer to the front to squeeze out more height, and possibly match it with a small 1" block in the rear? I'm getting a camper shell next month, so I was hoping to counter any rear sag I might get. plus, I want to get 255/85's :anonymous:
    please go easy. haha, mahalos
  2. May 21, 2015 at 8:00 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Why not just up your 5100s one notch? And then the block in the rear. Or, just add the block and see what you look like after the camper shell
  3. May 21, 2015 at 8:03 PM
    cubiclesurfer
    Kailua-Kona, HI
    I've been told that with 885's I should always stay at "0" because of the preload/ride quality :confused:
  4. May 21, 2015 at 8:04 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Yup
  5. May 21, 2015 at 8:08 PM
    Haslefre
    Brady
    TN
    2019 Tundra
    What are you lifted to right now?
  6. May 21, 2015 at 9:47 PM
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    Yes you can put the 1/4 spacers on there. That shoul get you to a full 3" upfront or there abouts. It ends up being the same as coilovers cranked up o 3". Which is what I did.
    cubiclesurfer[OP] likes this.
  7. May 22, 2015 at 1:18 AM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    Jus get ome 887s like me :thumbsup:
  8. May 22, 2015 at 2:17 AM
    cubiclesurfer
    Kailua-Kona, HI
    what are you running for rear suspension? I also have the drivers side spacer in for the taco lean. would I just leave that in, and throw the top spacers on?
  9. May 22, 2015 at 3:04 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't like spacers personally, unless of course you compensate for the spacers by spacing out your bump stops downward as well. Then you should be ok. How much you would need to space them out that I do not know.
  10. May 22, 2015 at 4:32 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    You can put the 10mm or the 13mm spacers on top with no ill effects. I would skip out on going with the trim spacer as that would do very little.
    The one thing to remember is that when doing the 10mm or the 13mm top plates, they will come with longer strut bolts.. easy.. I have the 5100s, 885s, and 13mm..
    I also have a shell on my LB... I think once you get the shell, your rear will drop enough to almost negate the AAL (especially when it settles and you have a couple loads in the rear). I ended up with a dakar pack in the rear with the added AAL...
  11. May 22, 2015 at 6:32 PM
    cubiclesurfer
    Kailua-Kona, HI
    so if I already have the 1/4" spacer in, just leave it?
    yeah, that's what I was worried about. does your truck sit pretty level with that rear pack+AAL setup? maybe I should get that pack in the Boss group buy :spy:
    I gotta check your truck out one day so I can see for myself. then I can compare what kind of heights I can expect, to what I have now :D
  12. May 22, 2015 at 10:57 PM
    Vanguard
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Yeah if you already have the 1/4 lean spacer I'd leave it and add another 1/4, one on each side. Now I'm running dakars in the back with OME nitros and timberens. Man I love those timberens. I've already gotten my money out of them hauling heavy loads.
  13. May 24, 2015 at 7:11 PM
    cubiclesurfer
    Kailua-Kona, HI
    since I have a 1/4" on the driver's side, maybe I'll order a 1/2" to replace it, and move the 1/4" to the passenger side. theoretically, this should bring it up 1/2", right?
    also, what if instead of the 1" blocks (which seems to be worse than murder after reading through this site), I add the overload spring back in? I think that's around a 1/2"?
  14. May 24, 2015 at 11:30 PM
    Vanguard
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    yeah the math works out that way too. I guess just the cost of the single 1/2" vs 2 - 1/4". I went with one polyurethane and one aluminum when I stacked them. That way they bind and are less likely to slip. As far as the rear, if the OL will give you 1/2" then that could work. I guess it depends on how you like it the way it sits when it's all said and done.
  15. Jun 1, 2015 at 6:19 PM
    cubiclesurfer
    Kailua-Kona, HI
    well, I guess if I want to go down this 1/2" spacer route, I need longer top plate strut bolts... which means I need to take the top hat off. so......... who has a spring compressor and would like to help? I can pay :anonymous:
    and if you want to install some LR UCA's, and possible 1" blocks in the rear, that would be awesome :oops:
  16. Jun 2, 2015 at 11:42 AM
    raycie
    Oahu, HI
    In need of $$$
    The rear blocks are easy... just jack the rear up, take off u-bolts, put block in, and reassemble.. You will probably need to get new u-bolts just in case.. , blocks are way easier than even an AAL.
    As far as the fonts, you can always do the LCA method...
  17. Jun 2, 2015 at 11:44 AM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    I dropped my lca's wen i installed my ome 887 springs.
  18. Jun 2, 2015 at 1:02 PM
    YotaBum
    YotaBum Not So Well-Known Member
    Alex
    North Georgia
    2015 TRD Sport DCSB
    Blacked Out-887-Dakars-LR UCA-FJ Trail Team wheels-285 BFG KO2
  19. Jun 2, 2015 at 1:13 PM
    cubiclesurfer
    Kailua-Kona, HI
    oh yeah, I still get the u-bolts from my Icon AAL's. the box says they're 8"... stock is 6-1/2"? I dunno, but when Iven and Mike installed my suspension, we decided to just reuse the OEM u-bolts since my truck only had like 1,500 miles. lol
    PM'd you.
