Too many miles to buy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kennywalkup, Jul 30, 2020.
  1. Jul 31, 2020 at 9:37 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This^. Mileage and time are killers of vehicles. The major drive train components may last a long time but all the little things can and will break or fail. There definitely is a lot of costs and downtime with older high mileage vehicles. If you are good at working on vehicles and you don’t mind working on and fixing all the “little” things that will go wrong and fail then that may be the truck for you. The little things also add up over time to major $$$.
  2. Aug 1, 2020 at 9:26 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Toyota has a long history of fucking up the first couple years of a new V6 engine. This includes 95, 96, 05, 06, and 2016. Let's not even mention the 3.slow. There are known head gasket issues for 05 and 06 V6 engines. They have never fucked up a 4 cylinder. If it was an 07 or later I'd be more inclined to agree. But I'd never touch a high mile 05 or 06 V6. Anything else I'd at least be open to reviewing the maintenance history.
    Another important thing people neglect is mileage accumulation. If a vehicle history report indicated that 150,000 of those 250,000 were put on in 3 or 4 years, that's a really good sign. It means they were most likely low wear highway miles.
  3. Aug 1, 2020 at 9:54 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I would think it’s the opposite. 4 cyl would take a beating straining to move the truck it’s entire life, while 6cyl there is less strain due to spreading it over more cyl’ s.
    Sprig likes this.
  4. Aug 1, 2020 at 10:01 AM
    andrew61987
    That is not at all how it works. The 4 cylinder doesn't strain to move a Tacoma. It's a commercial engine that's used the world over in vehicles way larger than Tacos. The exact engine is used in CITY BUSES in Japan. It's an overbuilt tank.
    If anything the lower power of the 4 cyl results in less stress on the entire drivetrain because it's simply not capable of subjecting it to the same torque that the V6 is. But this is really only a factor when you're gunning the engine to power ranges that the 4 cyl can't reach which isn't too often hopefully.
  5. Aug 1, 2020 at 10:50 AM
    TexasWhiteIce
    Texas
    so you’re saying 4 cyl engine wouldn’t strain as much pulling the exact same truck as a 6cyl would?
    so by your logic, we should just put 1 cyl engines in our vehicles then .
    Wattapunk and Sprig like this.
  6. Aug 1, 2020 at 12:13 PM
    andrew61987
    You are claiming that the 2TR is designed in such a way that accelerating a Tacoma to a given speed stresses the engine block/internals more so than the 1GR would be stressed accelerating to the same speed simply because one engine is capable of a higher power than the other. You simply cannot make this claim.
    Maybe you need to utilize the 4 cylinder to 60% of its capability and the 6 cylinder to only 40% of its capability to reach that speed. But that has absolutely nothing to do with how much the engine is stressed and how much wear and tear is put on it in doing so. Both engines would be doing the exact same amount of work.
    By your logic I should be able to drop a 454 into my Tacoma and expect 2 million miles out of it because I only need to use 10% of it's capability day to day. That's not how it works.
  7. Aug 1, 2020 at 12:58 PM
    TexasWhiteIce
    Texas
    so are you agree that dropping a 1cyl into a Tacoma works best then?
  8. Aug 1, 2020 at 1:12 PM
    andrew61987
    No, that's also a terrible idea.
  9. Aug 1, 2020 at 2:57 PM
    TexasWhiteIce
    Texas
    so 4cyl are in comparison to 6cyl
  10. Aug 1, 2020 at 6:28 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    " Damn, I regret buying my 6 cyl over that 4cyl" says no one.
    Marc70, TexasWhiteIce and Sprig like this.
