Too much antifreeze ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Nov 8, 2010.
  1. Nov 8, 2010 at 2:15 PM
    george3
    george3 [OP] Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I took a gal of antifreeze out of the radiator but couldn't get a full gal back in. I ran it to work, let it cool and got a little more in but still have little left. Should I be at all concerned ? Thanks. Curious George.
  2. Nov 8, 2010 at 3:07 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Did you run it with the heater on and the cap off?
  3. Nov 8, 2010 at 3:12 PM
    george3
    new jersey
    tacoma
    No. With the heater on and the cap on, going to work. If I ran it with the cap off the antifreeze would fly all over the place. Maybe I'm missing your point.
    Thanks.
  4. Nov 8, 2010 at 3:20 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Well, that will happen if you don't put the cap back on.
    I always run mine without the cap on and heater on and after a few minutes, I can put more fluid in until the fluid keeps going down. Now when it's full and it starts to overflow, time to put the cap back on.
    Putting the cap back on and running it traps air in the system.
  5. Nov 8, 2010 at 3:24 PM
    george3
    new jersey
    tacoma
    Thanks. I'll give that a try in the driveway.
  6. Nov 8, 2010 at 3:55 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It sounds like you have to 'BURP' the system to get the air bubbles out.
    Basically, radiator cap off.... let vehicle idle long enough until it gets hot enough to open up the thermostat. You can actually touch the big radiator hose near the engine and feel the fluid cycling. At this point, watch the fluid at the radiator cap and it'll probably drop. Hopefully you've got enough in there that it won't drop down too much. Add more fluid. Continue to watch... The system will cycle the fluid and the air bubble shoud eventually work themselves out.
    Search www.google on 'burping the coolant' - should be lots of info out there.
  7. Nov 8, 2010 at 4:54 PM
    george3
    new jersey
    tacoma
    Thanks Jandy for the details. Appreciate it.
  8. Nov 21, 2010 at 11:30 AM
    george3
    new jersey
    tacoma
  9. Nov 25, 2010 at 5:54 PM
    BH15001
    BH15001 Well-Known Member
    SW PA
    09 Tacoma DC LB SR5
    Do what Janster said and also have the truck parked facing up hill while you are burping.
  10. Nov 25, 2010 at 6:10 PM
    george3
    new jersey
    tacoma
    Thanks. I didn't get anything when I tried burping it so I just put the extra in the overflow tank. No problems so far.
  11. Nov 25, 2010 at 6:27 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    thats actually what the over flow tank is for. If the coolant in the system gets low, it SHOULD pull it from the over flow tank, back into the system, and vice versa..If the coolant is to much, it SHOULD spew off into the over flow tank.
  12. Nov 25, 2010 at 6:29 PM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    if it's just a overflow tank, none will go back in,, and I think those systems are a partial recovery, but not a full recovery. you might want to still keep a eye on the level for a bit, pack that jug with you. you still might have a big air pocket trapped somewhere.
    Next thermostat change, drill a small 1/8" hole in the flanged area of the thermostat. The open area flange part needs to touch coolant so the drilled hole can burp the system as you refill. this trick allow complete block fillage, and allows any possbily trapped air pockets to purge out quickly. it wont affect anything except getting the air pockets out.
    once you the drill the thermostat, whatever you take out, will go back in.
  13. Nov 25, 2010 at 8:17 PM
    george3
    new jersey
    tacoma
    That's a new one on me. Learn something every day or at least try to.
  14. Nov 25, 2010 at 9:14 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    this a 50/50 mix? or do you still need to get water in?
  15. Nov 26, 2010 at 3:56 AM
    george3
    new jersey
    tacoma
    You can buy premixed of straight. I bought straight and mixed it with 50% distilled water.
