Too much fluid in the rear DIF?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tadman95, Jun 22, 2019.
  1. Jun 22, 2019 at 5:50 AM
    Tadman95
    Tadman95 [OP] Active Member
    Mayberry
    2008 Tacoma, 4X4, 4.0L, Off Road Pkg #1
    Good morning Tacoma World, hope everyone is having a fine Saturday!
    I'd like to get some opinions. I bought a 2008 Tacoma Auto 4x4, Access Cab, Off Road Pkg #1 last week. Started going thru the dif fluids this morning. Rear dif was drained, expected to put about 3 qts back in. Ended up putting about 3 3/4 back in before it started spilling back out.
    That's too much based on what I've read.
    I put the fill cap back on (Loosely) for now so I can go to run to the store with my wife and let the oil settle a little.
    Any thoughts, ideas, concerns? This is pretty straight forward stuff that I've done before (No expert though)
    Thanks for any help!
  2. Jun 22, 2019 at 5:50 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Sounds right to me. Fill it till it dribbles.
    My first gen calls for 2.8 quarts. I did 3 and it still wasnt coming out. Very close however, so I let it ride.
    Tadman95[OP] and ovrlndkull like this.
  3. Jun 22, 2019 at 5:53 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It’s about right. If it worries you turn the truck around 180 degrees in the same place you filled it up and pull the fill plug.
  4. Jun 22, 2019 at 5:56 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    All depends on if you are sitting on a slope facing forwards that could be part of the deal. Not a huge deal for a little overfill. It'll get down the axle tubes to the bearings easier. I did mine the other week think I got a little over 3qt in it IIRC
    Tadman95[QUOTED][OP] likes this.
  5. Jun 22, 2019 at 7:01 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Last month I changed my F/R differentials. Rear took 3.1qt as was in my owners manual. Was not oozing out. But you could put your finger in filler hole and touch fluid. You'll be fine if it's at top of filler hole. What brand and weight of fluid did you use out of curiosity?
    Tadman95[OP] likes this.
  6. Jun 22, 2019 at 7:07 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I found that Toyota's differential fluid specs for both the 2nd Gen Tacoma 4.0L and 5th Gen 4Runner are incorrect. As you discovered, the differentials in these vehicles take more than the owners manual specifies. I always fill a diff until it starts coming out the fill hole; then stop.
    mikalcarbine and Tadman95[OP] like this.
  7. Jun 22, 2019 at 7:22 AM
    Tadman95
    Mayberry
    Thanks everyone. I leveled the truck before starting. Putting in Mobil1 75w90.
    What's bad, but great, is the fluid I drained was really clean. I think I got a gem, 115k, frame is great, body great, inside great.
    Still going thru it good though. :D
    Again, thanks to everyone!!
    ovrlndkull likes this.
  8. Jun 22, 2019 at 11:04 AM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    Like the previous owner changed all the fluids just for you ))))
