Too much lift on RXT option 1
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IvanhoeTaco, Dec 28, 2022.
  1. Jan 6, 2023 at 11:16 AM
    #41
    IvanhoeTaco
    IvanhoeTaco [OP] Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Called icon and they asked for some pics. They said somethings not right ans will probbaly be sending a new pack.
    BadAndy10, Musubi3 and EatSleepTacos like this.
  2. Jan 12, 2023 at 12:21 PM
    #42
    IvanhoeTaco
    Eastern NC
    Icon is sending me new leaf packs to try...
    BadAndy10, Dekoy909 and EatSleepTacos like this.
  3. Feb 1, 2023 at 10:02 AM
    #43
    IvanhoeTaco
    Eastern NC
    New springs installed. Same thing. 3 inches over stock with 300lb in bed.
  4. Feb 2, 2023 at 9:59 AM
    #44
    IvanhoeTaco
    Eastern NC
    I removed the very bottom leaf and lost an inch of lift. Woohoo
    b_r_o likes this.
  5. Feb 2, 2023 at 1:04 PM
    #45
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pic?
  6. Feb 2, 2023 at 1:13 PM
    #46
    cmbondo
    cmbondo Well-Known Member
    San Diego CA
    2021 Cement DCSB TRD Offroad
    FOX 2.5 DSC and some other stuff too.
    I had mine sitting high once. Realized I torqued the bolts when the truck was in the air. Loosened the hanger bolts when the truck was on the ground and it dropped about an inch. Retorqued while on the ground and no problems since.
    INSAYN likes this.
  7. Feb 2, 2023 at 4:45 PM
    #47
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    Currently on Deaver u402 but I've been considering moving to the Icon pack. Can anyone confirm if they are side specific to address Taco lean from the battery and fuel tank on the driver side?
  8. Feb 2, 2023 at 5:00 PM
    #48
    IvanhoeTaco
    Eastern NC
    Mine are same side to side, even though rear is too high its the same on both sides.
  9. Feb 2, 2023 at 6:18 PM
    #49
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Icon says they're not side specific. Op... where are you measuring from to get 3" of Lift? According to the RXT height chart you can't get 3" even at option 3. My hub to fender front is 22" and 24" rear with RXT option 2. After a year the rear has settled to around 23 3/4".... sits pretty much 2" over stock front and back.
  10. Feb 2, 2023 at 6:26 PM
    #50
    IvanhoeTaco
    Eastern NC
    Measuring from top of axle tube to frame directly above. Stock is 8 inches, im at 11+. I have fiberglass so hub measurements are useless to me.
  11. Feb 2, 2023 at 8:13 PM
    #51
    lm546
    lm546 Well-Known Member
    Craig
    Tucson, AZ
    2015 dcsb OR, 2002 double cab, 1985 Toyota pickup
    What is your reasoning for moving away from the u402?
  12. Feb 3, 2023 at 10:00 AM
    #52
    OffroadToy
    My axle to frame is about 10.5" ... rxt leaf's at option 2 which gave me about 2" over stock height (measurend with the weight of the canopy and 200 lbs of sandbags.)
    Do the Hammer Hangers give additional lift? :confused:
  13. Feb 3, 2023 at 10:28 AM
    #53
    IvanhoeTaco
    Eastern NC
    Ive been told by the man who makes them that they do not.
  14. Jun 2, 2024 at 12:04 AM
    #54
    Mendoman
    Mendoman Well-Known Member
    South Lake Tahoe
    2008 SR5 DCSB / 22 TRD OR DCSB
    6112/5100 RXT Option 1
    She's up there!!! Installing my pack next week.
