Too much oil in the intake?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bayonet6d, Mar 21, 2014.
  1. Mar 21, 2014 at 7:24 AM
    bayonet6d
    bayonet6d [OP] Member
    Clarksville, TN
    '12 MGM TRD Offroad DCSB
    I was installing an Intake Manifold Spacer (IMS) from XTP yesterday afternoon and noticed what appeared to me to be excessive oil in the intake. Most of the motors i've ever been in were old and in need of work, and therefore disgusting anyway. I got nervous seeing that much oil in my new'ish truck. Is this normal oiling, or should i be worried?
  2. Mar 21, 2014 at 7:28 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I see an oil catch can in your future?
  3. Mar 21, 2014 at 7:28 AM
    BennyTRD
    BennyTRD Active Member
    Sask, Canada
    '11 TRD Sport 4X4
    That's caused the the recirculation of heated air from the crankcase back into the intake for emissions reason's. Best thing to do is install an oil catch can to stop that.
  4. Mar 21, 2014 at 7:34 AM
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Wyoming
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    Yup go to Amazon get the, add w1 oil catch can and than search TW for oil catch can the OP is detective dan and I think on the 3rd page is my install of my can. Detective dan did a good install write up as well good luck OP
  5. Mar 21, 2014 at 7:45 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    Does anyone know if the oil catch can system will affect the warranty? It is modifying the emissions system after all... I know it SHOULDN'T, but we all know how things are these days...
  6. Mar 21, 2014 at 8:37 AM
    bayonet6d
    Clarksville, TN
    Thanks for the head's up on the catch can. I'll definately do that.
    Next question... What can be done about the existing oil in there without removing everything and doing a manual cleaning? Any chemicals or sprays or additives to clean up that oil? I've used seafoam for extremely dirty motors before. Would that get it done?
  7. Mar 21, 2014 at 8:46 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    ^^^^^^ This
  8. Mar 21, 2014 at 8:48 AM
    SoCaltaco65
    Actually no, you're still ingesting and burning the oil vapor, just not the raw oil.
  9. Mar 21, 2014 at 8:56 AM
    SoCaltaco65
  10. Mar 21, 2014 at 9:00 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    ^^ this
  11. Mar 21, 2014 at 9:01 AM
    st101
    st101 Well-Known Member
    Can somebody please explain this a bit more?
    Is this mod recommended in all scenarios, or only under certain circumstances?
    Will it improve/extend engine-health?
  12. Mar 21, 2014 at 9:08 AM
    moondeath
    Pa, Gardners
    Engines build up internal pressures and it needs to be relieved. This is done through the PCV valve. Emissions laws don't allow for those gases to be released into the atmosphere, so they run a tube from the valve back to the intake so it's recirculated. With the pressurized gases though comes oil from the engine. The oil gets sprayed back into the intake system and gets everything gunked up.
    So yes, it's a good thing to do in any case.
    The catch can has 2 tubes that come in to it. An in and an out. The gases and oil come in to the can, but the oil drops to the bottom of the can instead of flowing to the intake. The gases exit through the 2nd tube and recirculate.
  13. Mar 21, 2014 at 9:14 AM
    SoCaltaco65
    Chris is correct, to expound a bit further, the excessive oil is not good on the combustion chamber and components from accelerated carbon build up.
  14. Mar 21, 2014 at 9:28 AM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    And with more engines going to direct injection, the problem is probably going to get worse / need more attention in the future.
    With port injection you at least have the fuel to wash the backside of the intake valve. Direct injection is just that, direct into the cylinder, and that oil / vapor will get baked onto the valve.
  15. Mar 21, 2014 at 10:02 PM
    st101
    Thanks for the replies fellas. Ordered one today from Newegg.
    Truck only has 110 miles on it right now so I'm going to do this mod early!
  16. Mar 21, 2014 at 10:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Hasn't created a problem for Diesel engines.
  17. Mar 21, 2014 at 10:34 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I would think that a manifold spacer would have more of a chance of effecting your warranty than a catch can. I'm planning a catch can at some point this summer. And hey it's a Toyota! Why would you need a warranty:rolleyes:
  18. Mar 22, 2014 at 6:00 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I had an 07 VW GTI that had DI. They were notorious for the carbon build up on the intake valves. Mine had 60,000 miles before it started to cause problems with random misfires and starting hiccups. Only way to clean them (properly) was with a dentist's pick and carb cleaner through the ports.
  19. Apr 19, 2014 at 10:56 AM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    He's absolutely right! Direct injection is a great technology for about the first 20-30k. Problem is the huge carbon deposit build up on the valves and on the pistons. Largely due to no injector above the valve to help wash the carbon build up or allow for a decarb service. And with the extended oil change intervals the oil sludge build up is huge and crucial effecting the cam actuator valve.
    The carbon falls into the cylinders and or builds up on the pistins and or rings and causes scoring (some auto manufacturers are calling the "zebra-ing" and calling it normal. ) thus allowing oil to blow by also adding to the carbon deposits. Some of these deposits can find their way all the way to the cat and cause pitting or burn their way through the cat. Cats are expensive. Do a compression check and see which cylinder is low. Or stick a borescope in and take a look for yourself. While you are in there look at the valves, top of the pistons and then find the injector. Notice how the build up on the piston is and this build up directly effects the way the fuel is swirled in the combustion chamber. look how dirty the deposits are on and around the injector tip.
    The key is to do more frequent oil changes!! Keep the oil clean thus preventing sludge and to run a good oil cleaner. Research BG 109 compression performance restoration. Also a anti oxidation oil additive as well. Antioxident is the key! BG MOA. Try BG 44k in the tank for the fuel and carbon clean up. The key is preventative maintenance!!!! down the road you will be doing valve jobs and piston rings. not cheap!!
    I work with Dealerships as well as independent shops and I can not tell you the amount of problems this new technology is having early on in cars.
  20. Apr 19, 2014 at 11:16 AM
    Navar
    Corona CA
    That might be true for diesel but not with the gas direct injection!
