too much oil
Discussion in 'Technical Chat' started by House, May 6, 2008.
  1. May 6, 2008 at 5:53 PM
    House
    House [OP] Member
    Ontario
    08 SR5 4X4 AUTO 4.0 Access Cab
    Had the oil changed today. The receipt from the dealer shows 6 units of synthetic. This seems like too much oil to me - I think the owners manual calls for 5.2 litres with filter. So I check the oil after the truck has been sitting for two hours (plenty of time to level) and the stick shows about a half an inch above full. Now, these dipsticks can be a pain in the ass to read, so I did it like 10 more times - all the same.
    Before I go back to the dealer, can someone tell me if they've experienced the same?
  2. May 6, 2008 at 6:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well, depending on if you have the bigger filter or not, you can run 6 quarts with out any problems. i usually put 5.5 quarts in mine,with a mobil1 m1-102 filter, and its usually pretty close. alot of people are using 6 quarts though, without any problems.
    and you are correct....the dipstick sucks man!! you may want to sand it a bit.....give the oil something to stick to.
  3. May 6, 2008 at 6:36 PM
    missileman125fw
    missileman125fw Well-Known Member
    How will sanding the dipstick help? My oil is so clean I can't tell either!
  4. May 6, 2008 at 6:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sanding it will just give it a better surface for the oil to sit on when the truck has been sitting for a little while.
  5. May 6, 2008 at 7:37 PM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    or score it w/ a knife o===============xxxxxxxxx==>
  6. May 6, 2008 at 7:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that'll work too.
  7. May 8, 2008 at 6:08 PM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    I too have difficulty reading the dip stick. My wife's 1995 Rav 4 has a great dip stick with cross hatches, making it very easy to read.
  8. May 8, 2008 at 6:30 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Take it back to the dealer with your manual. Show them the dipstik reading. Ask them why they overfilled it. 1/2'' on a dipstick is getting into dangerous territory because at a certain point the crank as it's spinning will cause air bubbles in the oil which can adversely affect lubrcation and damage engine parts. I'm speaking directly from experience;)
  9. May 11, 2008 at 2:07 AM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Dremel tool and a sanding bit and rough it up between the low and high marks. So much easier to see. That's a mod right? ;)
