Too Much Power?
Discussion in 'Audio & Video' started by jkc, Nov 17, 2011.
  1. Nov 17, 2011 at 9:29 AM
    jkc
    jkc [OP] Member
    Baltimore
    06 TRD Double Cab
    I was doing good about not tinkering with my truck until i found Tacoma World. TW + down time at work leads to money spending and ripping things apart in my truck.
    Heres what i'm doing, over the years i have accumulated stereo parts. I have an old set of pioneer TS-TRX800's. I also have a kenwood 250 watt amp (KAC-529S). I figured i give building a sub for my double cab a shot since i have all the parts and wood. I have scavenged one of the truck speakers and built a new enclosure for behind the driver side rear seat. I just finished the box last night and now doing my research on hooking it back up. My new setup will only be utilizing one of the subs (i used both in past installations). I just happened to notice that the sub is rated at 200 watts max music power (75 watts nominal). The amp is 250w. I was going to "bridge" (im not up on all the terms) the sub as according to the recommendation for a 1 sub install in the instructions. The specs say Max power--normal is 80w x2 and bridge is 250w x1. Its a two channel amp.
    do i have too much power for this sub to do the bridged option or should/can i hook it up to just one channel to send less power to it? which is better to hook it up to the left or the right channel?
    thanks
    thanks
  2. Nov 17, 2011 at 9:59 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Bridge it and don't worry about it.
    Just make sure your amp is stable in bridged mode for the ohms value of your sub.
  3. Nov 17, 2011 at 10:06 AM
    jkc
    jkc [OP] Member
    Baltimore
    06 TRD Double Cab
    both the amp and speaker are rated at 4 ohms. how would i know if its stable or not?
    thanks
  4. Nov 17, 2011 at 11:25 AM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    The short answer is, it will be!
  5. Nov 17, 2011 at 11:29 AM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '06 DC LB 4x4
    OME lift w/ Dakars & 885's Remote Start w/ window control
    You'll be fine.... when you go to adjust the gain, be smart about it, don't just crank it.
    if you have questions, find a local shop and flip one of the installers $5 to help you adjust it. Installers love a free lunch
  6. Nov 17, 2011 at 11:48 AM
    jkc
    jkc [OP] Member
    Baltimore
    06 TRD Double Cab
    thanks guys. this site is great. with what i will be listening too i wont be maxing it out. not looking to rattle the truck just a little more than whats there. hopefully this box works out. never made one before. took 2 tries to get something that fit the space and my salvaged sub. so far the the budget has been just 20 bucks for some glue, calk and extra wood. if it works ill add some carpet and have 2 less things in my (i may need this some day) box.
  7. Nov 18, 2011 at 12:13 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    A few hundred watts over what its rated wont do anything. Focus on keeping the distortion low, as thats the main killer
  8. Nov 18, 2011 at 1:41 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Clipping....we've been over this....clipping
  9. Nov 19, 2011 at 2:38 PM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    you clip an amp which results in distortion, yes. who the hell says "keep the clipping low"???
    but thanks for the so called correction
  10. Nov 19, 2011 at 2:53 PM
    ItalynStylion
    Steven
    DFW, Tx.
    For those who aren't electrical engineers, the term distortion on it's own typically refers to THD (total harmonic distortion). This is what most people think of when they hear the term 'distortion'. So when you say to "keep the distortion low" 99.999% of individuals reading that post will assume you are referring to the ONLY AMPLIFIER SPECIFICATION that quantifies any type of distortion...THD
    We have a special term for waveform distortion which isn't even close to being the same thing....it's called clipping. The term exists for a reason.
    I made the correction for clarity's sake so others know what the hell we're talking about.
  11. Nov 20, 2011 at 2:10 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Eibach Springs with Billstien 5100's - Full Katzkin Leather - Back Flip Roll-X bed cover - Custom Projector/Dual Halo Headlights by ambiguous - Eagle Eye LED tail lights - LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Rear AAL TSB - 4 Tie Down Mod - Pop N Lock - Running Boards - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    +1
  12. Nov 20, 2011 at 2:25 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    I was like :rolleyes::crazy::der::typing:
    Then I was like :yay::bowdown::evil::bowdown:
