Too much ps fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MacGyvR, Aug 17, 2011.
  1. Aug 17, 2011 at 10:30 PM
    MacGyvR
    MacGyvR [OP] Well-Known Member
    Tom
    Arizona
    03 Prerunner SR5 2wd
    My steering wheel has started moaning, for lack of a better word, every now and then when I'm in the process of pulling in to or out of a spot (Turning the wheel a bunch). I checked the fluid level and it was WELL above where it was supposed to be. Is there any way drain some of the excess fluid? I can only imagine the damage that can be caused by too much fluid in a pressurized system.
    Thoughts?
  2. Aug 20, 2011 at 3:57 PM
    MacGyvR
    Tom
    Arizona
    Fixed it!
    Rather than looking for a drain like a NORMAL person, I decided to get some straws that were about 3 feet long, and just pipet the excess fluid out. I don't think I measured even a little when I added fluid a month ago. I just poured the whole thing in, like a boss.:cool:
    Just thought I'd post a solution if anyone else pulls a dumbass maneuver like I did.
  3. Aug 20, 2011 at 4:48 PM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    More than the wife knows!
    Had the same problem i used a turkey baster and a hand pump for kerosen to get the excess out!
  4. Aug 21, 2011 at 2:26 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Flush the entire system(easy) using Amsoil Dex III. It will make it quieter. It holds just over 1 quart.
  5. Aug 21, 2011 at 3:34 PM
    MacGyvR
    Tom
    Arizona
    Hmmm, I'll keep that in mind next time I swap the fluids in my truck. Probably another thousand miles or so. Thanks!
