Too much rubbing, smaller tire?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Christian01016726, Oct 22, 2020.
  1. Oct 22, 2020 at 11:12 AM
    Christian01016726
    Christian01016726 [OP] Member
    San Antonio Texas
    2013 DC TRD Sport 4X4
    I’m running 285/70r17 with around a 2” lift in front and aal in the rear. They rub a ton on the plastic after much trimming when I take sharper turns or while on a dip with -12.5 offset. Can I just get 275/70r17s to avoid more rubbing and a chop?
  2. Oct 22, 2020 at 11:15 AM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    It'll help but it might still rub a little bit but since you've already trimmed some you will probably be fine. BTW lift doesn't affect rubbing at all unless you never plan on going over a speed bump or compressing the suspension.
  3. Oct 22, 2020 at 11:20 AM
    OvrlandTaco
    OvrlandTaco IG: Ovrlandtaco
    Colton
    Wyoming/Texas
    '06 Black DCSB TRD Off-Road
    I have the same problem, I went from 265/70/17 to 285/70/17 and they rubbed like crazy, I had to trim a little bit of the plastic, I recently lifted the truck to 3” in the front and now when I go over a large dip they don’t rub. However they do rub like crazy when backing up with the tires pointing to the left, but that’s due to the fact one of the mounting points for the fender liner got ripped off so it hangs a little. It’s just one of those things you’re going to have to deal with having larger tires. I just had a friend help my by turning the tires each way until I found where the tires made contact every time and just trimmed those areas.
  4. Oct 22, 2020 at 11:28 AM
    Christian01016726
    San Antonio Texas
    Yeah true. I’m just really not liking my side wall getting eaten up not only on the plastic but smaller areas of the cab and fender. I’m thinking if I get a smaller tire in width and diameter it’d help with those issues.
  5. Oct 22, 2020 at 11:43 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    said it before n will say it again, lift size is not the determining factor of max tire size on our truck. The wheel well just physically doesnt fit a 285/75R16 or 285/70R17. largest you can go would be a 265/75R16 or MAYBE if you are lucky with a spot on alignment a 255/85R16
    boston23 likes this.
  6. Oct 22, 2020 at 5:49 PM
    Glockster22
    Glockster22 Well-Known Member
    2005 tacoma
    Ironman lift
    Where is it rubbing? You'll typically need to get your alignment shop to get you close to 3 degrees of positive caster and then look up the body mount chop. I'm running a small lift wheel often with no rubbing. I've done no cutting on the fenders or inner wheel well.
  7. Oct 22, 2020 at 5:58 PM
    KILLINTIME
    KILLINTIME Like a Villain
    I have same lift with 35’s. Just cut more:D
    MSN88longbed and tcjacado like this.
  8. Oct 22, 2020 at 7:14 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If go 3” and want a 285 gonna have to get aftermarket ucas and push caster to at least 3* but imo 4 is great. That’s what I run and zero rubbing and no cmc. No issues on light trails as it’s a Prerunner.
  9. Oct 23, 2020 at 9:45 AM
    Christian01016726
    San Antonio Texas
    I have aftermarket Light Racing JBA UCA’s otherwise they’d make contact. I think my caster needs to be set at a better degree or something. But I’m getting rub on the plastic behind the tire and a bit behind the plastic liner behind it but that’s metal when going down a dip while turning, up a slope turning and while reversing.. I don’t know if achieving a higher lift would be the fix then, I thought I’d get 3” but they settled around 2.5”unfortunately. But as I do light off-roading every now and then with billies 5100 all around I won’t be doing any heavy flexing. Would a different UCA be able to get me a better caster? Smaller tire, or just chop the dang thing?
  10. Oct 23, 2020 at 10:38 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This is why you rub. OEM wheels are around +30 mm offset, so your tires are stick out ~1.6 inches more than stock. When steering, that tire is swinging over a 1.6 inches wider arc.
    275/70r17 would rub less because it's a smaller 32" tire, while you have 33" tires now.
    Do you have Light Racing or JBA UCAs? If Light Racing (aka SPC), you can try redoing the alignment to improve clearance. If JBA (i.e. non-adjustable), start cutting more plastic.
  11. Oct 23, 2020 at 11:02 AM
    Christian01016726
    San Antonio Texas
    Gotcha, so my offset is incorrect for the size I have after my lift. I have JBA UCA’s right now sorry for the confusion. Now because I usually drive on City/Hwy roads 85% of the time, would a smaller tire be better for those light trails or dives in turning down a road would help save my side walls or just getting some adjustable UCA’s?
  12. Oct 23, 2020 at 12:59 PM
    gotoman1969
    You can get 4* caster with the JBAs all day. That’s plenty.
  13. Oct 23, 2020 at 1:22 PM
    Christian01016726
    San Antonio Texas
    Alright, I’ll have it aligned then. I hope that will help with the rubbing!
  14. Oct 23, 2020 at 1:29 PM
    gotoman1969
    Caster, camber then toe in that order.
  15. Oct 23, 2020 at 5:31 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
  16. Oct 23, 2020 at 5:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    No. Caster, toe, camber, then re-check toe... The reason: the inclined steering axis causes camber gain unless the wheels are pointing straight ahead.
  17. Oct 25, 2020 at 8:04 AM
    Christian01016726
    San Antonio Texas
    Thanks so much y’all. This is why I love this forum!
