Too much rust or is it merely on the surface?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zachary miller, Jun 5, 2024.
  1. Jun 5, 2024 at 8:37 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Price. I suspect price is what is driving so many people to pray that a rusted out POS tacoma is worth the gamble.
    I don't get why there is Tacoma hype though, and I say that as someone who loves his Tacoma. If the same money can get you an F150 or Silverado with no rust then I'd go that route, especially since those do better at towing/hauling and some of the newer ones get better MPG despite being a full size.
  2. Jun 5, 2024 at 8:53 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I only had my 2018 for 5 years so I’m no expert but that is way more rust than I had - I find it hard to believe it is that bad for a Montana truck. You do get more moisture on that side of the divide I guess - or maybe they just salt the crap out of the roads over there? I’ve gotta fluid film my 2023!!!
  3. Jun 5, 2024 at 8:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This looks serviceable and fairly typical for a 12 year-old truck. Not worth the effort to "restore" it. Just spray yearly with Krown/FF/NHOU to slow down the rust and prevent it from getting catastrophic.
    2012 models tend to have problematic secondary air injection system pumps and switching valves. Then there are the typical 2nd gen problems like timing cover leaks and steering rack leaks. Expect to spend a few thousand fixing these issues if you can't live with them.
    TJTM likes this.
  4. Jun 5, 2024 at 9:52 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    What is mag chloride?
    Black97v6MT likes this.
  5. Jun 5, 2024 at 10:57 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Magnesium chloride, a salt compound, would be my guess.. so I believe there is some in Montana….
  6. Jun 6, 2024 at 4:55 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Liquid deicer and dust control used in the nw (mt, id, wa, or)
    Calcium chloride is used for the same purposes as well.
    Salt is used too but very rarely. blue/purple rock salt.
    Sand/gravel is used in rural areas and when temps render deicing agents ineffective.
    Op I think you can do better. Prices are dropping on 2nd gens in the nw. Lots of trucks available with a lot less rust to no rust.
  7. Jun 6, 2024 at 12:04 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
  8. Jun 6, 2024 at 12:09 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Whats the biggest tire I can fit with Rust......:anonymous:
    GrandMasterChooch and 23MGM like this.
  9. Jun 6, 2024 at 12:16 PM
    lynlan1819
    Tacoma
    Lifted
    48s
  10. Jun 6, 2024 at 12:20 PM
    Thechief86
    Thechief86 Well-Known Member
    Eric
    Middle TN
    Stock 2006 TRD OR, as well as some other junk...
    Sparkly blue shift knob
    It looks alright to me. Check out Eastwood's Rust Encapsulator paint. I'd wire brush the crap out of it and brush on the Eastwood stuff. In fact, that is the plan for my similarly crusty 06.
  11. Jun 7, 2024 at 3:26 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I've lived in the rust belt for my whole life. So, I know way too much about rust. Let me explain what's wrong with a truck like that with "just surface rust" on the frame.
    Yes, there is surface rust on that frame. Lots of it as a matter of fact. Some people think surface rust is a minor problem and you can just wire brush it, bomb it with some Rustoleum and maybe some Fluid Film and call it a day. Let me tell you something. Those people have never tried to get into all of the nooks and crannies on a Tacoma frame. Trust me, you'll give up in about an hour - after only hitting maybe 20% of the frame.
    The best you can hope for is to slow the surface rust down. That can be done with Fluid Film, Woolwax and various other products. But if you don't knock off the dirt and paint partially hiding the corrosion, those products are not nearly as effective. And remember, those products are designed to prevent rust from starting. Stopping it once its started is not part of the program.
    Then there's the issue of the rust you can't see. Yup, if it's got surface rust, it's virtually guaranteed to have rust on the inside of at least some surfaces. That hidden rust is what kills a frame. And you can't do a damn thing about it. Sure, you can possibly slow it down just a bit, but the tin worm never sleeps once it's awake and feeding. On a Tacoma frame, these are numerous areas where two layers (or more) of metal are laminated together. Although they are joined, they are not sealed. Once water gets in and the rust starts in those areas, you're all done. Trust me.
    Sorry to be the bearer of sad news. I'm not being cynical, just annoyingly realistic. That baby is toast.
  12. Jun 7, 2024 at 4:18 PM
    RockTrixWheels
    RockTrixWheels Well-Known Member
    2018 Cement Tacoma TRD Pro
    I unfortunately agree with the above. That's a real tip right there not sugar coating anything. Good luck with it! Hopefully you can get rid of most of the rust!
  13. Jun 7, 2024 at 4:20 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Re: >>>Too much rust or is it merely on the surface?<<< : Unfortunately: Both. If you buy it you're going to have to address this before next winter or it gets any worse. I have a 2014, purchased on 2021 w/104k. (Now at 133k) It had less frame and rear axle surface rust than this one. Frame has passed three annual Toyota inspections since I purchased it... two years left to go on the frame warranty. As soon as I got it, I started wire-brushing, priming with Rust-O-Leum prime and satin black. Then I coated the entire works with four cans of Fluid-Film and do it every fall. Everything except the rubber parts, control arms, and driveshaft. Every frame weld. Paint has held up good and so has the CRC the Toyota dealer applied. I emptied an entire can of Fluid-Film on the inside of the rear bumper and trailer hitch. At the end of the winter salt season in the spring, I seek out and drive through huge puddles when it's raining and then spray down down the entire under-carriage with a hose and nozzle. .. Touch up as required. For the hitch: every year it's a mess. Dunno why. Frame welds are always rusty after a while: even on southern vehicles and other makes. Treat them anyway.
    The cast-iron rear axle components: same thing: Treat them: The focus here is to preserve the mating (gasket) surfaces. If they start weeping/leaking due to rust-intrusion, it's too late/done. and that's not a cheap sheet-steel cover back there like most most cars have. It's massive casting. Expensive to say the least. "If you have to ask how much: you can't afford it.";)
  14. Jun 7, 2024 at 5:02 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Hard pass. It already needs work and will be ongoing.
    Look out west, then take a plane ride and drive it home.
    O'DubhGhaill and Williston like this.
  15. Jun 7, 2024 at 5:12 PM
    #35
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’d buy it. Go for it.
  16. Jun 10, 2024 at 2:56 PM
    #36
    IA DIY
    IA DIY Well-Known Member
    Iowa
    2008 DCLB 4x4
    Tap on everything with a 8 oz. Hammer. Thin spots produce a different sound than solid metal w/ superficial rust.
