Too much torque??
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco terror, May 3, 2013.
  1. May 3, 2013 at 2:19 PM
    taco terror
    taco terror [OP] 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Okay, so since my annoying ass steering wheel shake is still a mystery, I decided to see if my front lugs needed to be torqued down. I got out my torque wrench and went up to 75 which is what discount tire originally put my wheels on at. I recently had my front tires rebalanced at what my everyone says is an excellent tire place a few months ago.
    Well anyway, I went to check and noticed there was no sound/ popping at 75. So I decided to loosen a lug and see what ft lbs they were at. The torque wrench just kept going and still no noise. I maxed it out at 150 with slight popping from the lugs yet no movement still. Isn't this WAY too much for aluminum wheels??? I also doubt my torque wrench is that off cause I (155 lbs) could stand on top of the regular 1/2 wrench.
  2. May 3, 2013 at 2:24 PM
    taco terror
    USA
    I was leaning on it pretty hard
    Proof:
  3. May 3, 2013 at 2:32 PM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    Breaking torque is often times much higher than the original torque. And the longer it is on there the more likely the case. Galvanic corrosion comes to mind between the lugnuts and the aluminum wheel itself. The corrosion doesnt have to be major, or even very noticeable. A very thin layer of corrosion can cause this. I am not saying that they werent overtorqued to begin with, but this may be a factor.
  4. May 3, 2013 at 2:55 PM
    taco terror
    USA
    I was just wondering if that much torque could have damaged something.
  5. May 3, 2013 at 3:10 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    You should be OK. the worst that will usually happen is a stud breaks.
  6. May 3, 2013 at 3:22 PM
    Turbofed
    Turbofed Well-Known Member
    Kevin
    Roseville, CA
    13 O/R Dbl-Cab SB 4x4 6-Speed
    Color Matched Sports Grill, Front Skid Plate, Bed Mat
    The first problem and most correctable is to not go to discount tires, they are the worst. Or at least I've had the worst experience with them. They don't give a S**T about what they do to anyones cars, damaging wheels, improper balancing, etc.... Those places are all about numbers, they care about getting more customers through the door and selling tires. There's no quality in their work, at all. Sorry for the rant, but over torquing the wheels is to be expected from discount tires, worse case scenario it'll break the studs as stated above.
  7. May 3, 2013 at 5:11 PM
    taco terror
    USA
    Actually, discount tire isn't the one that over torqued my driver side wheel. It was the "reputable shop" that did it.
    The only thing bad from discount tire was the guy put a really small dent in my hub cap with the torque wrench when I got the wheels re-torqued after originally buying them. I heard it from inside the truck but didn't say anything. I could tell he was still clenching his butthole when he told me I was good to go lol.
  8. May 3, 2013 at 5:18 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I've found that I cannot loosen the lug nuts with a star wrench, if the lugs are set to factory specs. I have to use a breaker bar ( could be my advancing age though :( ).
    I usually re-torque all of them to 75lbs if and when it a shop puts on the wheels. That way I can remove the lugs on the road if I get a flat, without getting a hernia. I've been doing this for years, and find that 75 is more than enough.
  9. May 3, 2013 at 5:23 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    You should never use a torque wrench to loosen nuts or bolts...
  10. May 3, 2013 at 5:34 PM
    taco terror
    USA
    haha, sorry to hear about your aging. I'm outta luck if I get a flat. A 31" spare won't fit under the truck with the dual exhaust.
    I was just going in the opposite direction, thats all.
  11. May 3, 2013 at 6:19 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I use America's Tire (Discount Tire, same business/alt. name) all the time.
    The folks working there, do exactly as I ask/request.
    They will turn/rotate the tires on the wheels 180* if wheel weight/oz is excessive.
    Prep/clean the wheel surface before adhering the sticky weights that I commonly request.
    They allow me to select my tire PSI and lug nut torque choice... along with other services I request for my monies paid.
    Thought everyone did that too :confused: :notsure: (should)
    Being ignorant is no excuse IMO.
    Ignorance is akin to laziness... especially when every answer is available, right there at our fingertips or ears :rolleyes:
    Maybe the difference is... I know what I want/expect for my paid services.
    And so I have that discussion with them before they even begin work.
    Doesn't matter whom that service/vendor might be.
    I'll suppose if one just drops it off and says do yer thang...
    then that will be what the customer gets.
    bah...
    the customer has to take some responsibility, for being clear on what services they are paying for... and in fact receive.
    I often stay there and watch the techs as they do their work on my junk.
    Because I trust no one.
    If they deviate from what my instructions are... correction comes swiftly.
    Over torquing the wheel studs does more then just break studs.
    That's the most obvious/visual thing maybe...
    But less obvious/noticeable is the possible warping of the rotor and/or hub from over torquing the lug nuts.
    Warped rotors cause oscillation and can lead to vibration issues.
    83-84 ft lbs max... more then that... is fubar
  12. May 3, 2013 at 6:26 PM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    somewhere in my michelin training log,it says "over torque can also cause misalignment". im not too sure how that is connected but your truck only needs to be torqued at 80flbs. you can break the studs easily from overtightening and strip out the lug nut
  13. May 3, 2013 at 6:36 PM
    BamaToy1997
    Bill
    Navarre, FL
    Depends on if they use a torque rod. I used to have several in my tool box when I was working at Sears. They look similar to an extension, but the design of the metal is such that no matter how strong of an impact you are using, the torque rod will not allow a higher torque to be applied to the lugnut. Not sure if they actually use them, but I know several times I would have customers complain that we used impact guns to tighten wheels until we showed them the torque rods.
    The most common problem with incorrectly torqued lug nuts is a potential for a warped rotor. A very common problem.
  14. May 4, 2013 at 8:58 PM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    Discount tire is one of the places they do a good job torquing wheels...I'd never go back to a place that torqued the crap on a lugnut....can result in warped brake disks, etc...
  15. May 4, 2013 at 10:12 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    A few points:
    - Breakout torque when loosening is almost always higher than the original tightening torque, due to the screwform acting as a continuous wedge.
    - The 12x1.5mm studs in Toyotas should be tightened to 83 ft-lb. Not sure where you got 75 ft-lb.
    - The torque spec is determined by stud size and the grade of steel used in the stud and lugnut. Steel and aluminum wheels should be torqued to the same specs. The aluminum wheel will be compressed more, but that's OK, because cracks don't form in compression.
  16. May 8, 2013 at 3:46 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    snap studs - be a man about it. break things then fix them.
    *popcorn*
  17. May 8, 2013 at 3:54 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    I have a very long breaker bar, it will do one of two things fairly easily, only one way to find out unless you have an air gun to rattle the nuts off, it will either loosen the nuts or shear the studs....rears are easy to replace, fronts take a bit longer..
    I find my medium sized rotary hammer drill set on hammer only with a long pointed bit make short work on removal, about 5/10 seconds on the left over, out.... it is harder to seat the new ones, have some fun, go for it...
    might be a good idea to invest in some new studs and have them on hand, just in case...
  18. May 8, 2013 at 5:08 PM
    taco terror
    USA
    Thanks guys, I didn't say I couldn't get them off though.
    I had the tires rotated over the weekend by discount tire and they should be torqued down to 85 foot lbs now.
  19. May 9, 2013 at 9:46 AM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    I wouldn't worry about it just tighten them and go if your worried about exact torque you need to replace studs exerytime you r&i wheels everytime a bolt is tightened it stretches the threads
  20. May 9, 2013 at 10:06 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    nope, aluminum wheels require correct torque every time, or else the
    bolt hole chamfer deforms slowly over time (during installation) from overtorque and eventually becomes junk
    if you use the 'gutentite' method (such as installing a spare on the road)
    it is best to retorque to spec at the earliest opportunity
