Too mutch rear brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by goualon69, Feb 13, 2013.
  1. Feb 13, 2013 at 4:04 AM
    goualon69
    goualon69 [OP] Well-Known Member
    Mathieu
    Québec, Canada
    2011 sr5 tacoma
    Lifted 3'' front and 1.5'' back, removed ABS, when I brake hard, rear brakes have too much power, I heard the rears tires burning!
  2. Feb 13, 2013 at 4:32 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Removing abs + light rear end I suppose?
    What route of removal was used?
    Switch or fuses?
  3. Feb 14, 2013 at 3:27 AM
    goualon69
    Mathieu
    Québec, Canada
    2011 sr5 tacoma
    fuses! but I remove ABS because ABS was engaging too often and dangerousely!
  4. Feb 14, 2013 at 4:24 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Im wondering if its got to do with ur lift and the VSC stuff........I think the dealer can dial down its sensitivity
  5. Feb 14, 2013 at 4:39 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    What tires are you running? What driving and road conditions?
    Sounds to me like it may be working normally. Rear tires have no traction so ABS kicks in. Disable ABS and rear tires lock up.
    When ABS first came out in vehicles, many trucks only had rear ABS to keep the rear tires from locking up so easily. No front ABS on them.
    ETA: How are your brake linings?
    Metal on metal in the back could cause it. Minimal pads in the front and new in the back could make it worse. Air in the front lines? Lots of possibilities.
  6. Feb 14, 2013 at 7:39 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I suggest learning how to use ABS.
    Works great if you use it properly.
  7. Feb 14, 2013 at 7:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This. ^^^^^^ X1000.
    Removing or disabling the ABS wasn't a real smart move IMO. I think you are seeing the results.
  8. Feb 14, 2013 at 7:49 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    Its not the abs. Its the vsc and trac control. The computer needs to be reset. This will solve your problem. And they need to do a Zero Point Calibration. I had it done for free at my stealership.
  9. Feb 14, 2013 at 7:56 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I think it's clear the ABS is too mutch of a problem in the Tacoma. But disabling it completely is a bit mutch. I would take the other guys recommendation. Go to the dealership and ask "is it too mutch to ask that you guys reset my computer, my rear brakes are gripping just a bit to mutch."
    They might try to charge you too mutch but I think a "that's a bit mutch" to the tech should save you some money, not too mutch, but a little.
    GL!
  10. Feb 14, 2013 at 8:29 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    LOL! Your post was just too mutch funny!
  11. Feb 14, 2013 at 8:31 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    ABS in these trucks is way too touchy. Fucking sucks. That's my vote.
  12. Feb 14, 2013 at 8:52 PM
    IGO4LOW
    Zach
    Fullerton, CA
    Good point!
    OP. Put the abs fuse back in and go get the system reset and a Zero point calibration done. I bet that solves it.
  13. Feb 23, 2013 at 8:47 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Sound like you have a brake problem. ABS amplifies brake problems. Are your rear brakes adjusted up to far ? Are your e-brake cables frozen ? Is there something wrong with your front brakes ? When your brake system works normally so should your ABS.
  14. Feb 24, 2013 at 4:16 AM
    goualon69
    Mathieu
    Québec, Canada
    2011 sr5 tacoma
    its not a big problem! I can leave it like that! its apear when I leveling it! I would like to know if brakes have a systeme to aply more brakes in front when front end dive! Like vw did! If yes, then its the problem of the leveling kit! Its good to know that dealer can adjust that! thank
  15. Feb 24, 2013 at 4:16 AM
    goualon69
    Mathieu
    Québec, Canada
    2011 sr5 tacoma
    Yes this is true!
  16. Feb 24, 2013 at 4:21 AM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    in winter driving condition the abs on these truck sucks, by far the worst abs system ive ever driven!
  17. Feb 24, 2013 at 8:46 AM
    Hugh Morron
    Bill
    Don't you love when you are coming to a stop sign or red light you hit your brakes in plenty of time(not waiting until the last second) you slow to about 10 mph and the ABS kicks in and you go sailing right through. Mine almost caused 3 accidents so far.
  18. Feb 24, 2013 at 9:07 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    you can adjust the brakes in the rear
  19. Feb 24, 2013 at 11:21 AM
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I drive in the snow all the time and have no problems.
    I am still calling people out that say they have problems because I think it is the drivers. Its not a snow cat or snowmobile or an ATV so don't try to drive it like one.
    I go so snow removal in an area with 10-15% grade hills and pull a trailer with my snow blower on it. And have no problems at all.
    The only problem i have had with ABS is when i have been hot roding around.
    ABS is not some kind of miracle braking device you still need to use common sense in how you drive.
  20. Feb 24, 2013 at 12:27 PM
    zackn291
    zackn291 Well-Known Member
    Zack
    Princeton, Ontario
    '05 Taco TRD
    Bilstein 5100 set at 2.5", 2" AAL, Fog light mod.
    no need to make fun of the french canadian for his spelling.. tabernak!
