Too sipe or not too sipe?
Discussion in 'Wheels & Tires' started by badguybuster, Nov 5, 2010.
  1. Nov 5, 2010 at 5:30 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Me too. Thats my hope
  2. Nov 5, 2010 at 6:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    When I asked them about siping, that's what they said. They will only sipe the two center rows of tread blocks. I asked why not the out blocks and got two answers. One said it is hard on their equipment. The other said their research showed the biggest impact is from the center lugs. :notsure:
  3. Nov 5, 2010 at 6:16 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    My question is if siping is so great why do manufacturers that design, test and construct the tires not sipe them from the factory?
    I know manufacturers sipe some of the tires that are made but not all tires come from the factory siped. Around the Pacific NW it is a very common practice.
  4. Nov 5, 2010 at 6:29 PM
    badguybuster
    Michael
    The quicker your tires wear....the sooner ya gotta buy new ones.
  5. Nov 5, 2010 at 6:45 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I appologize for being a noob, but what is siping?
  6. Nov 5, 2010 at 7:09 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    a machine rotates your tires and makes cross cuts into your treads. This helps the tread split during movement and cut through water, snow,etc and keeps better grip on dry road. At the expense of faster wear
  7. Nov 5, 2010 at 7:15 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This may help to explain what siping is.
    http://www.discounttire.com/dtcs/tireSiping.dos
    From the Discount Tire doc.
    Why Don't My Tires Come Siped From the Manufacturer?
    Our siping process doesn't remove ANY rubber from the tread allowing the individual sipes to support each other. A molded sipe leaves vacant gaps in the tread. Siping creates edges without gaps. To sipe (in mass production) after the molding process would be too expensive and time consuming for the manufacturer.
  8. Nov 5, 2010 at 8:21 PM
    radioactivemint
    radioactivemint Well-Known Member
    Oregon
    2011 Reg. Cab 4x4
    I have the stock Dunlop AT20 tires and as much as I would like to get winter tires or even just better A/T tires like Michelin AT2s, I just can't afford it right now and winter is fast approaching. I've read a lot of bad reviews on the stock Dunlops in ice and snow...this has me very concerned. I don't drive fast in these conditions...will the tires be fine with conservative driving habits? Would siping dramatically help give these stock tires more grip?
  9. Nov 5, 2010 at 8:34 PM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    not a mud tire but, I just ordered a set of Cooper Discoverer ST's. Gonna have them siped and studded for winter. Pretty excited, never had a studded tire before.
  10. Nov 5, 2010 at 8:40 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Wow. Never heard of "siping". Good information here.
  11. Nov 5, 2010 at 8:41 PM
    Razorecko
    Especially since you are out in or , i would recommend getting them siped. i spent about a week with my at20's in our chicago winters and I literally couldnt make it down the street unless i was in 4hi. It was ridiculous that they would put this junky of a tire on a truck
  12. Nov 5, 2010 at 11:17 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My current winter setup is a set of 17 inch TRD Sport wheels with the stock Dunlop AT20 tires that I found on craigslist.. I have run them for the last 3 winters.. While I am not nearly as comfortable on them as I was with my previous BFG AT's, they have gotten me around for the last 2/3 harsh winters without siping.
    07- 5 Feet of snow
    08- 8 Feet of snow
    09- 6 inches of snow
    10- TBD
  13. Nov 6, 2010 at 4:55 AM
    badguybuster
    Michael
    I think I am gonna take my dremel with a small blade and cut two slots in each of the center lugs and see how it works. Im gonna start shallow tho, so if it doesnt work well they will wear off. Maybe 1/8"
  14. Nov 6, 2010 at 7:10 AM
    Razorecko
    The problem with that is my guess the cut slots wont be equal in length. So during movement when the rubber flexes you'll have uneven flex from the sipes which will cause weird behavior and extremely fast wear n' tear on your tread.
  15. Nov 6, 2010 at 7:39 AM
    #35
    Beeson
    Beeson Well-Known Member
    Seattle
    '96 Tacoma SR5 4x4
    33" Goodyear Wrangler Duratracs, 15" Unique Steelie rims, Allpro wheel spacers, Heavy Old Man Emu coils, struts, shocks, leaf springs, Daystar 1" spacer, Camburg UCAs, 1" diff drop, NO sway bar, Allpro sliders, Allpro Rear bumper, Bushwacker fender flares, Tire Gate with spare, ARB Deluxe bumper with Hella 700s and 100w bulbs, 100w lights under frame pointed at tires, 50w lights on bumper for reverse, K&N Drycharger with cover, Flowmaster cat-back with custom 2-out exhast, DeeZee tool box, Huskey Liners, 5% window tint, JVC iPhone/CB compatable deck, Bazooka sub, sony speakers, Uniden CB w/4 ft. anntenna, Dixie Horn.
    I would not get your tires siped if you drive on small rocky surfaces at all, ESPECIALLY shale. Shale is bad enough on tires, but on a siped tire it really finds the way to get in there and rip them up. If you stay away from surfaces like this in your driving, go for it, it's cheap and supposedly gives a dicernable difference.
  16. Nov 6, 2010 at 7:43 AM
    #36
    NicP
    NicP Well-Known Member
    Nic
    colorado
    05 DC LB
    3" Icon CO Icon Rez and AAL ProComp 7089 BFG 285 AT KO
    To those that researched it. Discount tire will be able to do the center lugs only??
  17. Nov 6, 2010 at 7:43 AM
    #37
    NicP
    Nic
    colorado
    05 DC LB
    Has any one siped BFG TA KO's? IF so what was the result on snow/ice?
  18. Nov 6, 2010 at 8:36 AM
    #38
    Razorecko
    I have about half the tread left on my duratracs. I'm wondering about siping them to keep them for another winter but i dont know if i have enough tread left to do it. Otherwise the new 'tracs are going on
  19. Nov 7, 2010 at 9:06 AM
    #39
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    Why doesn't Toyota make a solid-axle diesel for us to buy in the US?
    It's a matter of expense and "good-enough".
    http://www.dickmantires.com/sipe.html
    http://www.lesschwab.com/siping.asp
    A fun read: http://www.overdriveonline.com/feature-article-siping-strides/
  20. Nov 7, 2010 at 9:08 AM
    #40
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    I have been having Discount Tire do just that for two decades or so :)
