too small
Discussion in 'Lighting' started by AsianAnts, Jun 5, 2011.
  1. Jun 5, 2011 at 9:04 PM
    AsianAnts
    AsianAnts [OP] just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    MY OVEN TOO SMALL TO PUT THE HEADLIGHT in and do the retrofit project =(!!!!!!!!!!!!!!!!!! AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
    anybody local wanting to do it for me ?? ;)
  2. Jun 5, 2011 at 9:10 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    you'r oven can't fit one head light?
  3. Jun 5, 2011 at 9:26 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
  4. Jun 5, 2011 at 9:50 PM
    AsianAnts
    AnT
    nope D:
  5. Jun 5, 2011 at 10:03 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    use the heat gun method. i actually believe it's the safer way to do the lights. as alot of the parts in the light are not and should not be exposed to that kind of heat. the tacoma in particular can have issues with the tab that the grill clicks into breaking especially in after market housings. take your time don't over heat the housing and this method works excellent imho. you also will not run the risk if touching the head light on the inside of the over it can happen it did to me once right on the fapping lens lol.
  6. Jun 6, 2011 at 12:20 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    damn. you must have an easy bake. jkjk. i never new a oven could be that small.
  7. Jun 6, 2011 at 7:26 PM
    AsianAnts
    AnT
    i was thinking of heat gun method too.... i can borrow that from a buddy of mine....
    this oven is a joke man... lol.
