too soft rear suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gonzalocortes, Apr 11, 2012.
  1. Apr 11, 2012 at 1:20 PM
    gonzalocortes
    gonzalocortes [OP] Member
    Santiago Chile
    Tacoma 4x4 2008
    How would be the better way to make the rear suspension of a 2008 Tacoma TRD hard?
    I use this truck in Patagonia and roads are very bad, my problem is when I take 3 people plus me the rear suspension make a nock when hit the gum stopper at he chassis, any solution?
    I already change the schocks for red Koni and still the same.
  2. Apr 11, 2012 at 1:30 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Add a leaf or TSB if possible?
  3. Apr 11, 2012 at 1:35 PM
    nvrquit1gc
    nvrquit1gc Member
    Buffalo, NY
    09 SR5 Sport
    Bluetooth for smart phone
    I just added a set of Firestone air bags to my truck, they mount between the frame and the leaf spring. They are inflatable so you can adjust the pressure in them as needed.
  4. Apr 11, 2012 at 1:35 PM
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    I've been considering air bags in the rear for my occasion heavy loads. Most of my driving is paved roads but sometimes I load up with fire wood for my sister and really don't haul much else. Haven't decided yet but over summer I'll do something.
  5. Apr 11, 2012 at 1:36 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    an add a leaf would help that quite a bit, but that will give you rear lift. can you still get the TSB?
  6. Apr 11, 2012 at 1:37 PM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    x2 adding a leaf will make the back end stiffer.
  7. Apr 11, 2012 at 1:38 PM
    rbishopp
    Rich
    Webster, NY
    Hey nvrquit1gc was that much of a job to install the airbags ?
    I'm not a mechanic but can normally follow directions and figure shit out. Have most tools but can get what I don't have.
  8. Apr 11, 2012 at 1:39 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    add a leaf or easier yet..a simple leaf spring helper from your local auto parts store for $25
  9. Apr 11, 2012 at 2:00 PM
    nvrquit1gc
    nvrquit1gc Member
    Buffalo, NY
    09 SR5 Sport
    The cost is about $290 through Auto Anything. If you have a good drill & a drill bit and your not scared to drill a couple holes in your frame, it will be well worth it if you want an adjustable system. I use my truck as a daily commuter, but there is times I need to haul something heavy. I did the job myself and I'm no mechanic and it took me about 3hrs. I took my time to run the air lines to the enclosed storage door in the back of the bed and I zip tied the lines neatly.
  10. Apr 12, 2012 at 8:36 AM
    gonzalocortes
    Santiago Chile
    Tacoma 4x4 2008
    What is a TSB? TXS.
  11. Apr 12, 2012 at 8:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Toyota Service Bulletin.
  12. Apr 12, 2012 at 8:54 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Technically , " Technical Service Bulletin "
  13. Apr 12, 2012 at 8:54 AM
    98tacoma27
    Ben
    Not Beech Creek
  14. Apr 12, 2012 at 11:27 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Since your truck is a 2008 model even with an extended warranty it would probably be next to impossible to get the harsh ride TSB approved for your vehicle. Cheapest correction is an AAL but this will only be a bandaid if you haul with some consistency. I would go for a whole leaf pack or airbags.
  15. Apr 12, 2012 at 12:17 PM
    gonzalocortes
    Santiago Chile
    Tacoma 4x4 2008
    thanks I think will go for the airbags
  16. Apr 12, 2012 at 12:19 PM
    gonzalocortes
    Santiago Chile
    Tacoma 4x4 2008
    any advise for the best airbags?
  17. Apr 12, 2012 at 3:23 PM
    cmoschip
    cmoschip Well-Known Member
    Robert
    Houston, Texas
    2008 TRD Sport DC 4x4
    In my opinion, Firestone Ride Rite
  18. Apr 13, 2012 at 7:01 AM
    rbishopp
    Rich
    Webster, NY
    Thanks. Seriously leaning toward this. My Tacoma is my DD too so it needs to be flexible. Not sure about the drilling in frame and warranty issues. I'll have to check that out.
    :cheers:
  19. Apr 13, 2012 at 8:49 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Ive been running Hellwigs one-piece helper springs for over a year now. It raised the back end slightly and stiffened it up considerably. They're adjustable too, but not as easy as the air bags. Also helps with cornering on paved surfaces.
  20. Apr 13, 2012 at 9:13 AM
    gologit
    gologit Well-Known Member
    In the redwoods.
    2023 SR5 4x4 long bed
    Nothing major or fancy. Just stuff to make it work better for me. Running boards, seat covers, BakFlip
    I just finished putting a set of Firestone Ride-Rites on my 2011
    No drilling necessary, in most cases. Firestone has a "no drill kit" for the later model Tacoma...kit # is 2407. It uses existing frame holes and the only holes you'll drill are two small and easy ones for the air nozzles.
    The three hour installation time isn't always accurate. If you have access to a hydraulic lift and have a good set of air tools you might do it in three hours. Otherwise, plan on most of the day. :D
    I've had airbags on two previous Tacomas but this was the first set I installed myself. One thing I would advise...when you cut off the rubber bump stop don't use a hacksaw. It will take forever. Get a sawzall instead.
    Here's the best link I found that shows the installation process. Scroll down to the video.
    http://www.etrailer.com/Vehicle-Suspension/Toyota/Tacoma/2011/F2407.html?vehicleid=20111014497
