Took apart cluster for climate control to replace bulbs, Now unit broken!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Down In A Hole, Oct 20, 2015.
  1. Oct 20, 2015 at 3:29 PM
    Down In A Hole
    Down In A Hole [OP] Active Member
    Philadelphia, PA
    2004 Double Cab Limited Pre-Runner 2wd
    De-badged. Air-raid air intake. Magnaflow muffler. Clear front corners. 6700 HID headlights.
    Hey guys I was trying to replace the bulbs in my gauge cluster for the climate control and right after I unscrewed the back panel a strip of wires ripped out from the one circuit board to the other. I tried to feed it back in but it wouldn't stay in place. Tried tape and it would still come apart. Eventually after messing with it for so long the wires got bent enough that it was no longer making good connection and 1 piece of wire broke off. Now nothing that is powered by the right side connection works. I'm assuming I have to replace the whole thing now? Thanks.
  2. Oct 20, 2015 at 4:19 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Yikes! To the bone yard with ya.
  3. Oct 20, 2015 at 6:57 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I can hook you up if its 01-04 truck.
    the way that connection works is the tab locks it in with a pressed in fit, gently pull straight out on the raised lip and the tab slides out too a little bit to "open" the slot, then you press the wire tape in evenly so its all the way seated then you push the tab in to secure the contacts in place. that's it and its making contact again.
    good news is a salvage yard should have a beat up control somewhere nobody wanted
  4. Oct 20, 2015 at 7:21 PM
    Down In A Hole
    Philadelphia, PA
    Yes, it is a 04. Have a extra? I wish I would have posted earlier because the more I messed with it the more I messed up the ends on the wires. The plastic tape came off the one side immediately. Fooling around with it more and the wires came apart. I don't know if new wiring can be purchased and if I can properly install it. All because I wanted to convert to LED's. lol. Forget it. Just want to get my heater working again!
  5. Oct 20, 2015 at 7:30 PM
    keakar
    karl
    louisiana
    send me $15 and I have the rear control circuit board with the wire tape still on it I can send to you.
    gently reinstall in your front circuit board and you are back in action. then you save your old one to have a spare rear circuit board in case you ever need one. Toyota charges like $90 for it lol.
    PM me
