Took It Out Today
Discussion in '1st Gen. Tacomas (1995-2004)' started by tjgraner09, May 6, 2009.
  1. May 6, 2009 at 6:22 PM
    tjgraner09
    tjgraner09 [OP] South Carolina Member
    TJ
    Conway, SC
    97 XtraCab
    Bilstiein 5100 w/ TRD Coils in the front, new fog lights, 2 12" isignia subs,
    Well after getting my new tires on monday i decided to try them out
    After being in the hole for about half an hour (sorry for the crappy cell phone pic)
    and then when i was power washing the truck
  2. May 6, 2009 at 6:23 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Looks like the tires worked well enough.
  3. May 6, 2009 at 6:26 PM
    tjgraner09
    TJ
    Conway, SC
    97 XtraCab
    yeah they work pretty good but i got stuck as FCUK
    bottomed out in the hole and exhaust pipe was under the water for about 30 mins but i got yanked out
  4. May 6, 2009 at 6:29 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    is that bad? that the exhaust pipe is under water?
  5. May 6, 2009 at 6:31 PM
    tjgraner09
    TJ
    Conway, SC
    97 XtraCab
    well its bad if your truck cuts off and the water gets sucked in the motor... then your SOL!
    but i held the gas pedal down a little bit and it was alright
  6. May 6, 2009 at 6:32 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    ahhh. so it can work as a vaccume effect on your motor? i did not know that
  7. May 6, 2009 at 6:41 PM
    tjgraner09
    TJ
    Conway, SC
    97 XtraCab
    yeah man dont do it
    that will mess up your shit bad
  8. May 6, 2009 at 6:44 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah, i dont plan on it. but if someone tells me there going muddin, ill pass along that info to em
  9. May 21, 2009 at 10:53 PM
    efranck2
    efranck2 The Eternal E
    St. George Utah
    2004 Tacoma Limited Doublecab 4x4 impulse red
    Brute Force Intake, Flowmaster Exhaust, 3 Inch Lift, Bilstein shocks, HiD Lights, Security System, Gray wire mod,
    just make sure you fill your tailpipe with mud so water cant get in there ;P haha
  10. Aug 12, 2009 at 2:05 PM
    tjgraner09
    TJ
    Conway, SC
    97 XtraCab
    lol oh yeah that will work perfectly
