Took the first step in an AR build
Discussion in 'Guns & Hunting' started by majorhavok, Jun 24, 2013.
  1. Jun 24, 2013 at 6:09 PM
    majorhavok
    majorhavok [OP] Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    I have had a hole(mostly in my mind..) in my gunsafe for years. Given all the floating legislation here in CA that would outlaw AR's, I decided to start a build. I first wanted a M&P, but the pricing and timing didn't work out, and I do like the idea of a fully self-built rifle. I even considered one of the 80% lower kits, but decided if they DO outlaw these in Cali, a registered lower would most likely be grandfathered, and it'd be hard to prove when an 80% was completed.
    Anyway, I bought this from Turners:
    They had 4 different lowers to choose from for $159 before fees. Truthfully all were almost identical, but the finish and engraving on the DTi was a bit better and the reviews online were all glowing. I also picked up the full parts kit for the lower and a separate bullet button to make it CA legal when I do the build.
    The bad news is that the del-ton is completely sold out of the rest of their AR rifle kits to complete the AR which would have been my preference.
  2. Jun 24, 2013 at 7:54 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    congrats on your find! ...take care when you install the roll pin that holds the trigger guard in, as that is a weak part of the lower reciever, ...you wouldn't want to break it, especially now when they are hard to come by (a trick is to use a pair of taped up vice grips, slowly turn the screw to advance the pin into place ;) same goes for the roll pin for the bolt catch assembly...
  3. Jun 24, 2013 at 8:26 PM
    majorhavok
    Mike in Cali..
    Thanks, that sounds like a great tip! I am looking forward to the build.
  4. Jun 24, 2013 at 8:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's not a horrible horrible price, though it's high for a Delton.
    Doesn't Riflegear have any JD Machine lowers in stock? They should be around $130 out the door with DROS.
  5. Jun 24, 2013 at 8:30 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '10 4x4 DC SR5
    WeatherTech liners, Kenwood Media Receiver, Alpine S 6x9 speakers, Sound Ordnance 8" Sub, OEM running boards, MK6 wheels, Dynapro ATs, Tint, Bed Mat, Avid light bar, KC Daylighters
    Great tip! I have never used vice grips but it seems like it would work.
  6. Jun 24, 2013 at 8:33 PM
    majorhavok
    Mike in Cali..
    Negativo captain stevo. They ONLY have the billet, for the same price as turners though. $230 before tax/dros etc..
  7. Jun 24, 2013 at 8:34 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ouch... they're up to $200 for the basic lower?
    My 3 lowers were $89-$120.
  8. Jun 24, 2013 at 8:44 PM
    majorhavok
    Mike in Cali..
    Times have changed. :) I won't tell you what I paid for a case of 900 cci stingers at the last gun show. :anonymous:
  9. Jun 24, 2013 at 8:46 PM
    wileyC
    Centerville, OH
    yep, it works! ....tape the jaws up good, ....relying on a hammer and punch it's easy to scratch the finish...
  10. Jun 25, 2013 at 7:54 AM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    08 Prerunner Texas Edition
    For the bolt catch assy, I go the opposite way and this works a lot easier and less chance of scratching. I use a brass punch and a small tack hammer.
    barrell end ----->stock end
    And for the trigger guard I put a wood block under the ears as I am slowly tapping the roll pin in with a small tack hammer
  11. Jun 25, 2013 at 7:57 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    sounds like a good start, heres my first (and only so far) build
  12. Jun 27, 2013 at 10:02 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    check ammo bros? I saw some lowers for 129 there lately.
  13. Jul 1, 2013 at 7:36 AM
    majorhavok
    Mike in Cali..
    Picking it up today!
  14. Jul 1, 2013 at 10:06 AM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
