Tool Box Carpet / Adhesive question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by djdig, Oct 16, 2013.
  1. Oct 16, 2013 at 2:53 AM
    djdig
    djdig [OP] Active Member
    David
    Thibodaux, La
    I want to put carpet in my Weatherguard toolbox and contact cement / glue it down.
    What do you recommend for carpet and adhesive for this task? I don't store tools in my tool box, its mostly for extra space when going to range, skeet tournaments, big ass haul at Cabela's :)
  2. Oct 16, 2013 at 4:40 AM
    hpeeler
    hpeeler Active Member
    I've done a couple of boxes like this and I use double sided tape. I've also used spray adhesive around the edges.
  3. Oct 16, 2013 at 4:47 AM
    djdig
    David
    Thibodaux, La
    Just indoor/outdoor carpet from Lowes/Home Depot?
  4. Oct 16, 2013 at 5:07 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) You could cut your carpet to fit the tool box floor, then use those carpet non slip pads that they use on wooden floors to hold your carpet. It should hold your carpet in place. Good Luck.
