tool box install with a bedliner
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2KTacoPr3runn3r, Apr 18, 2011.
  1. Apr 18, 2011 at 12:55 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r [OP] Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    Just bought a tool box off my coworker and was wonderin if you guys know how to install it with a bedliner in. Its got 4 holes, 2 on each side of the box to attach to the bedrails. Any ideas?
  2. Apr 18, 2011 at 1:03 PM
    Onion27
    Onion27 Well-Known Member
    San Antonio, TX
    05 Tacoma Dbl Cab PreRunner
    Go to BetterBuilt.com. They make an adapter for installing toolboxes using the bed rail system. Costs like $10.
  3. Apr 18, 2011 at 1:17 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    not the bedrails built into the 2nd gens but the actual bedrails like the top of the bed sides
  4. Apr 18, 2011 at 1:45 PM
    wtmtntaco
    wtmtntaco Well-Known Member
    NH
    03 TRD xtracab V6
    Bilstein 5100's at 2.5", Grey wire, Wheeler's 1.5 aal,
    I used j hooks, no drilling into the side of the bed, but it does bend the rim a bit if you really crank it down, or the grip clamps sold at Lowe's work good, I don't have one near me though.
  5. Apr 18, 2011 at 1:48 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    ill have to check that out
  6. Apr 18, 2011 at 2:19 PM
    newskooler
    newskooler Well-Known Member
    Nick
    Mount Shasta, Ca
    1997 ext cab base, 2012 Base Access cab, 2018 trd OR
    Mall Crawler
    J hooks ftw. 5 bucks max and no holes in your bed rail
  7. Apr 18, 2011 at 3:08 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    how exactly do they work? do i need to cut a hole in the bedliner?
  8. Apr 18, 2011 at 3:20 PM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    I just strap mine in with the ratcheting straps. Really tight and easy to pull out when you need to.
  9. Apr 18, 2011 at 3:23 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    i was thinkin about using my tie down to loop it around the front and tighten it down but i want somethin a little more secure
  10. Apr 18, 2011 at 3:55 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I use the j-hooks, which I recommend to you, but I also have a factory drop-in bedliner that goes under the bed rails. I drilled holes in the toolbox to accommodate the hooks them used nuts and washers. My box is fairly light though so it doesn't take much to keep it in place.
  11. Apr 18, 2011 at 9:43 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    got pictures of it installed with the j hooks?
  12. Apr 18, 2011 at 10:14 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    are you guys talking about j bolts? or j hooks? cus theres a big difference
  13. Apr 19, 2011 at 6:15 AM
    RattleTractor
    Harry
    VT
    Sorry. j-bolts. Actually they're i-bolts that I bent into j because the store didn't have the right j ones. :D
    I'll take a picture today.
  14. Apr 19, 2011 at 11:24 AM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    also my bedliner goes over the top of the bedrails so i think i have to cut out a slot anyway i install the tool box correct?
  15. Apr 19, 2011 at 4:39 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have J Bolts in mine that are pretty slick. I wish I would've used bigger washers though as I cranked the nuts down too tight and they split right through the plastic box. It's still secure but it pisses me off.
  16. Apr 19, 2011 at 4:55 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    here is how mine is mounted but i have spray in bed liner. but should be similar as long as you cut a notch in the drop in liner as you were talking about.
  17. Apr 19, 2011 at 9:17 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    ^thats what i was imagining it would look like
  18. Apr 19, 2011 at 9:36 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Yup and only one for each side, and it holds in place just fine!
  19. Apr 19, 2011 at 10:17 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    i was thinkin i was only goin to do one on each side also. it holds pretty well?
  20. Apr 19, 2011 at 10:19 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I havent had any problems with mine moving around.
