Tool Box
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Graè Beard, Nov 7, 2019.
  1. Nov 7, 2019 at 6:59 AM
    Graè Beard
    Graè Beard [OP] New Member
    Lupe
    Silver 2019 Tacoma
    New
    What tool box are y’all using for storage and tools?
  2. Nov 7, 2019 at 7:20 AM
    TheUpstateTACO
    TheUpstateTACO Well-Known Member
    2018 Silver DCSB TRD OR 4x4
    Yakima Overhaul HD bed rack, Faux Pro Grill
    Morning OP and welcome! I had the UWS TBC-42-W-BLK on my 2013 DCSB. Fit perfectly between the wheel wells and was just a tad taller than the sides of the bed. You can also look for a smaller crossover toolbox that fits where mine does but extends over the wheel wells. or you could do a crossover that sits on top of the bed rails. What style are you looking for?
    To mount mine I drilled two holes that lined up with the front two bed bolts and installed the bed bolts through the toolbox, worked perfectly.
    BassAckwards and Graè Beard[OP] like this.
  3. Nov 7, 2019 at 7:47 AM
    Dave3359
    Dave3359 Well-Known Member
    Dave
    Fl
    2018 Blazing blue access cab
    Weather guard hands down I been using them for thirty years
    Graè Beard[OP] likes this.
  4. Dec 2, 2019 at 8:54 PM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    What did you torque the bed bolts to and did you use any kind of lock-tite/etc?
    PS - I grew up in the St Andrews suburbs NW of Columbia.
  5. Dec 3, 2019 at 4:10 AM
    t0nyvalenzuela
    t0nyvalenzuela Well-Known Member
    2019 Tacoma TRD OR DCLB
    Puck level
    Craftsman from lowes for under $250, and deezee toolbox anchors.
  6. Dec 3, 2019 at 6:14 AM
    TheUpstateTACO
    Morning Rick,
    I didn't use lock-tite or torque the bolts to a certain amount, I just used a little anti-seize and cranked down on them pretty good. I did make it a point to check them every few months as the bed mounts under the bed can wear out and cause issues down the road if they aren't tight. When I sold the truck I pulled the toolbox out, even with anti-seize they required a breaker bar to remove.
  7. Dec 3, 2019 at 9:24 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    I have a UWS box, I wanted it a little short and not reaching all the way to the sides of the bed. DeeZee anchors are good and easy, I dipped mine.
  8. Dec 3, 2019 at 11:20 AM
    CTF
    CTF Well-Known Member
    2017 TRD OR
    Betterbuilt makes a good one. I like the matte black finish in low profile. Close to $400.
