Tool list by job
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jproffer, May 17, 2020.
  1. May 17, 2020 at 7:59 AM
    jproffer
    jproffer [OP] Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    Thought it might be handy to have a thread, admittedly very similar to the Tools thread by @Crom , but sorted by the job you're doing.
    For instance, I recently did a U-joint job (DS u-joints), so maybe the list would go like this:
    Thanks to @TnShooter and OP of the following:
    Driveshaft U-joints:
    14mm sockets and wrenches
    Press
    Small screwdriver
    Needlenose
    Paint marker
    Channellocks
    24mm socket
    Grease
    Files
    Torque wrench
    Hammer
    Center yoke = 134 Lbs – loosen one turn – 51 Lbs
    Flange bolts/nuts = 65 Lbs (good luck)
    Center bearing bolts to truck = 27 Lbs …single hole down
    Oil change:
    14mm wrench or socket...may need a breaker bar
    Oil filter wrench
    Oil catch pan
    Small water bottle to catch oil from filter drain can...or 5/16 hose to bottom.
    From @jspadaro from 2011...just saw it lol.
    Front Diff & Transfer Case
    Might add more as time goes on, but just an idea. Feel free to add more or correct/add to mine...I'll edit the OP as needed.
    I don't think it's necessary to specify things like rags, gloves, ratchets for your sockets, other "normal" things you're going to have with you all the time, but if you want to include every single thing needed for a job, I will add it to the OP exactly as you write it.
    If we start to get a big list I'll try to keep it alphabetical as best I can.
    Crom and Biscuits like this.
  2. May 17, 2020 at 9:42 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Subbed.
  3. May 17, 2020 at 10:21 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Biscuits likes this.
  4. May 17, 2020 at 2:34 PM
    jproffer
    Jim
    Perryville, MO
    I have the same problem lol. I even think to myself "I need to make a list of what I needed and maybe even go back after I'm done and mark off all the shit I only THOUGHT I needed"...but then that little devil on my shoulder says "Ahhh, don't worry about it right now...you'll remember later". But I rarely do.
