Tool Question....
Discussion in 'Garage / Workshop' started by Pster, Jul 7, 2009.
  1. Jul 7, 2009 at 7:36 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    OK, I got my 8' x 2' and 1/4" steel workbench top today. I need to clean it up and polish it now. I want to put those nice swirl circles in it if possible before I seal it and may need to clean up some of the edges. Do I need to get a "polisher/grinder"? Is there a certain type or grit of wheel I need to get for it? I would like to use whatever I get to also polish my truck, if that is possible? I am just not sure of what tool to get. Any thoughts on type and a good brand in this category? Thanks!
  2. Jul 7, 2009 at 7:38 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Ah, you want what is called "engine turned" finish.
  3. Jul 7, 2009 at 7:40 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  4. Jul 7, 2009 at 7:42 AM
    coppert
    coppert Mall Krawler
    Travis
    916
  5. Jul 7, 2009 at 7:44 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  6. Jul 7, 2009 at 8:55 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
  7. Jul 7, 2009 at 8:58 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    The Engine Turn is in fact what I had in mind, but this piece is 8 feet long and would it take forever to do this. I was hoping that I could accomplish something "similar" with an orbital grinder/polisher or something.......
  8. Jul 7, 2009 at 9:09 AM
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    Sorry can't offer you any suggestions. Sounds like it will be sweet when you are finished. Post some pics of the finished product. :)
  9. Jul 7, 2009 at 9:11 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    You wont be able to get the finish your looking for with an Orbital.
    Have a couple beers ready, because it can take a while and requires some patients.
  10. Jul 7, 2009 at 9:12 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You can, but the idea is to be evenly spaced which is almost impossible to do by hand. You can always test on one side to see what works best. i would recommend an air die grinder.
  11. Jul 7, 2009 at 9:31 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I think what I am going to do is get an orbital grinder/polisher since I always wanted one....I'll use some rubbing compound on a disk and just go over as best I can to get it really clean and shiny....swirls are OK, even if not symmetircal. I just don't want it to look like bare metal. Thanks for ya'lls advice. Is there even such a thing as on orbital grinder/polisher? or is it an orbital sander/polisher? I don't suppose an orbital anything would be used to "grind metal"...
  12. Jul 7, 2009 at 9:33 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Just get an orbital sander. It is the pad/grit that is going to make the difference. Start with a low grit, say 180 then work up to a +600.
  13. Jul 7, 2009 at 10:00 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    OK, I am going to look at them this weekend. Want a variable speed one as I know going too fast can damage your paint. Can I put polishing pads on an orbital sander as well?
  14. Jul 7, 2009 at 10:07 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I think so. The higher grit pads like +400 and above are pretty much polishing pads.
  15. Jul 7, 2009 at 10:32 AM
    SaltySteve
    SaltySteve sMo
    Denver
    2012 4runner
    Here's an idea . . . .
    With whatever tool you end up using you could make a "stencil" for it our of plywood with a hole saw or something. Hold it down with some clamps so it won't move. Then move the stencil over appropriately so you get the even spacing and finish you desire. Make sense? I actually think that'd work pretty well.
  16. Jul 7, 2009 at 10:40 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Makes perfectly good sense......I need to get this heavy thing onto the bench tonight (still in back of truck)......I'll clean it up first, go to Lowes and see what they have. I want to study it and think about it before diving in, which is why I value ya'lls suggestions. :D
    I have a pretty steady hand and a good eye, if I used a non-orbital type polisher, I'll bet I could do this without have to use a template....
  17. Jul 7, 2009 at 10:41 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    What kind of steel is it?
  18. Jul 7, 2009 at 10:49 AM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    there is a wire wheel that you can put on a drill.it's about 2inches in diameter and they have smaller but i saw it done with the 2.the sanding disk won't give you the brushed look that i think your looking for
  19. Jul 7, 2009 at 11:09 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    It's Hot Rolled steel plate. Edges deburred with the two outside corners cut with rounded corners......I also was just looking at the wire brish attachment you mentioned and thought the same thing you mentioned. On the "face down" side of the plate I intend to do some practicing....:D. I'll take some good pics when I am done and how/what I did.
  20. Jul 7, 2009 at 11:11 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Hot rolled? That is going to take some work. Can you post a pic of it now?
