Tool Recommendations for Wheel bearing Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kwe1982, Aug 12, 2020.
  1. Aug 12, 2020 at 7:25 PM
    Kwe1982
    Kwe1982 [OP] Well-Known Member
    Wisconsin
    Gone - Just a couple Tundras and a Sequoia
    I have a press, basic tools and a good 3/4" torque wrench
    I'll need the locknut socket, below is one I found on Amazon.
    https://www.amazon.com/gp/product/B01N4989WC/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
    Can anyone recommend a good press bearing sleeve set?
    Also maybe a bearing knife?
    Also am I missing any other specialty tools, or helpful tools?
    I'm just digging into all the threads and videos on wheel bearing replacements.
    I've got a 2002 Doublecab Automatic 4x4 with automatic hubs.
    Going to do a complete replacement on all front suspension components while I install a new lift, real soon.
  2. Aug 12, 2020 at 7:45 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I didn't have a press so I just bought a harbor freight set that has a ton of different sizes too pull and press bearings cleanly. //
    Kwe1982[OP] likes this.
  3. Aug 12, 2020 at 8:17 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    The snap ring is kind of a pain because it's so big. But it sounds like you have everything you need. The bearing took alot of force to get out!
    Also the bearing looks the same on both sides, but apparently there is one side that is supposed to face out. I dont remember all the details because I had help but I remember it being mentioned.
  4. Aug 12, 2020 at 10:40 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Kevins60, Kwe1982[OP] and CS_AR like this.
