Toolbox in composite bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tarheeler, Mar 30, 2014.
  1. Mar 30, 2014 at 2:20 PM
    tarheeler
    tarheeler [OP] Well-Known Member
    Newport News, Va
    06 PreRunner TRD offroad
    3" lift
    Any problems mounting a crossover box?
  2. Mar 30, 2014 at 3:18 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    its easy peazy! go to local hardware store and buy some "j" hooks. 4 of them. 1/4" or 5/16" would suffice.
    you will notice slots in the bottom of the rail up close to the cab. drill holes in your toolbox where the "j" hook will poke through, with the "j" part engaged in the slot. my truck isn't here right now so I have no pics
  3. Mar 30, 2014 at 3:21 PM
    92dlxman
    Kevin
    Visalia, CA
    these too would work
  4. Mar 30, 2014 at 4:55 PM
    tarheeler
    Newport News, Va
    3" lift
    Thank you for the reply, jhooks ought to work fine
  5. Mar 30, 2014 at 4:59 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Jhooks work fine..just don't overtighten them cause you will crush your bed side plastic cover thingies...you just need to make sure the toolbox can't move easily. Lol
  6. Mar 30, 2014 at 5:06 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
  7. Mar 30, 2014 at 5:56 PM
    robulur
    robulur Member
    [Can you mount full length side boxes. With. These. To??
  8. Mar 30, 2014 at 8:19 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    I used four bolts instead of the J - hooks to mount my crossover box.
  9. Mar 30, 2014 at 8:26 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I'm not sure I'd trust them without a support that extends to the bottom of the bed.
    Especially on rough terrain, there's a lot of stress on the bed rail with an unsupported side box.
  10. Mar 30, 2014 at 11:18 PM
    robulur
    robulur Member
    OH yeh your right. I've always had to support them I t may be hard to do with the composite bed. I'm looking at a 2014. In pyrite Mika and some black boxes I think would look. Very good. Plus. I've never seen a taco with them. Before Dbl cab sb
  11. Mar 31, 2014 at 9:07 AM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    I used j-hooks on my last pickup and toolbox. Never again. It seems like I have to pull that thing out 2 or 3 times every summer and dealing with those hooks and trying to hold everything steady while trying to get that nut to twist off is way too much of a PITA.
    I'm making a really solid mount for mine right now w/ unistrut on the front and 3/4" angle iron brackets for the sides. Goal is for it to be rock solid and easy in/out (5 mins or less) for when I'm moving large furniture / appliances around.
    I used some Grizzly T-slot nuts and 1/2" hex bolts to mount a section of unistrut to my front bed rail channel that's going to stay there permanently. The toolbox will go up against this unistrut bar and I'll put a pair of 1/2" hex bolts through the toolbox that will go into some unistrut nuts and tighten from inside the box. I'm keeping a 3/4" ratcheting open end wrench in the box for quick install/removal.
    I'm almost done with the side brackets. I took some 3/4" angle iron and put three 5/16" holes on top and welded nuts below them. I got some button cap hex machine screws that will go inside the toolbox and screw down into this angle iron. I got a hex key sized for them that will stay in the box. All that's left is to grind them down (I'm a messy welder), clean them up, and prime and paint.
    To hold the angle iron brackets to the bed, I'm using the same thing as with the unistrut bar. I'll mark the rail so I know where they have to go in case I ever remove them, but I'll probably just leave them in because they're low profile.
    So when it's all said and done, I'll be able to pull out a pair of 1/2" bolts in the front of the toolbox with the wrench, hit 4-6 machine screws on the side with an allen wrench, and pull the whole thing out. Easy in, easy out, way more solid than j-hooks. It's definitely a lot of work upfront and probably overkill, I won't argue with anybody on that.
