Toolbox LEDs on lid open write up.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Large, Nov 26, 2011.
  1. Nov 26, 2011 at 11:41 AM
    Large
    Large [OP] Red
    My first write up, be gentle.
    Drilled a hole for my pressure switch in the back on passenger side:
    here's an outside shot:
    installed the switch:
    the lid open, the switch depresses and contact is made:
    note: there are sharp edges all around the hole and where i cut out from the toolbox, ill get to that in a minute.
    inside shot, really blurry:
    had some LED strips from harbor freight, $12 for a 4 pack, they are 1.2V, used some adhesive from lowe's that was $4, caked the lights inside the lip of the toolbox, here is the wiring i ran:
    another angle:
    terminated the wiring:
    used 3m double sided automotive tape, placed a strip about 3 foot long between the LED strips for my wiring, tucked the wires in, this is the end result:
    here are the lights on:
    here is the switch wired up:
    used an inline fuse and ran a hot to the battery and
    for the sharp edges I used a dremel to smooth them out and a pencil file for a smooth finish, on the outside and inside of the switch i used silicone to keep out moisture, i only installed 2 of the lights, because i wanted to see what they look like at night time, if i need more i will install them but im pretty sure 2 will work just fine, these pictures are poor quality, so i uploaded a video:
    http://www.youtube.com/watch?v=QReK4j-u_x0
    i will take more pictures tonight, maybe another vid if i get enough interest
    edit: here is a pic & video of it at night time. enojoy.
    http://www.youtube.com/watch?v=pVnQzXmJOLg
  2. Nov 26, 2011 at 11:45 AM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    Looks good man, nice writeup too. I gotta do something similar under my hood.
  3. Nov 26, 2011 at 11:49 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    That is really good.
  4. Nov 26, 2011 at 12:06 PM
    Large
    Large [OP] Red
    Thanks guys, I think the video does more justice than the pictures do. I'll have to do another one tonight.
  5. Nov 26, 2011 at 12:11 PM
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    04 tacoma double cab
    all of them
    nice write up
  6. Nov 26, 2011 at 3:27 PM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    looks good, i want to do something similar here also under the hood and arm rest..a few questions...what size fuse did you use/where did you ground LED's/what route did you take for your power/the type of switch is a pressure switch, where did you get it? thanks
  7. Nov 26, 2011 at 4:56 PM
    Large
    Large [OP] Red
    added a new night shot & video.
    I used a 25amp inline fuse, with #12 wire from the battery, i plan on doing more leds with it, you only need a 1amp if you are just gonna run the 2 lights. i used an "eye" type lug on my J bolt that holds my toolbox down and i put it between the flat washer and lock washer, as far as the wiring, i drilled a hole in the top of the cubby in the right side of the bed, ran the hot wire through the same hole as the J bolt, and came through the gromet underneath the passenger side of the cab where my hot wire was that i ran from the battery.
  8. Nov 26, 2011 at 5:10 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Nicely done! I plan on doing something similar for under the hood and bedlights.
  9. Nov 26, 2011 at 6:48 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Cool. I'm gonna have to copy you. :D I already have power in my box. We have the same box too.
  10. Nov 26, 2011 at 7:46 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    i put lights inside my toolbox and never had to drill such a huge hole. just a hole big enough for the wires. used a much smaller switch screwed to inside lip of the tool box that the top hits and its not noticable at all
  11. Nov 26, 2011 at 7:58 PM
    Large
    Large [OP] Red
    May just be camera but the hole isn't big at all, my pinky wouldn't fit through it.
  12. Nov 26, 2011 at 8:42 PM
    2000GTacoma
    Snow Hill NC
  13. Nov 27, 2011 at 7:34 AM
    2chains
    Calgary, Alberta
    Large
    thanks for taking the time to post the pictures and video! rep coming your way
  14. Nov 27, 2011 at 7:47 AM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    very nice! i went the lazy route and bought a dot-it light from home depot. it just uses 3m tape and sticks on. works okay but was only $5 so you cant expect much.
    this is what i have
  15. Nov 27, 2011 at 8:39 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    This should be sticky in the DIY section!! Nice write up hoepfully Mods think so too.
  16. Nov 29, 2011 at 7:55 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    nice man! thanks!
