Toolbox question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oat, Jan 4, 2012.
  1. Jan 4, 2012 at 5:12 PM
    Oat
    Oat [OP] Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    I'm looking into getting a UWS low profile toolbox.
    two main questions;
    Will it scratch my bed rails since i dont have a bedshell that extended there, or a bedliner?
    How is it secured/clamped in?
    Thanks.
  2. Jan 4, 2012 at 5:14 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    different tool boxes are different ways. i know on the low profile me and my brother put in his f-150 there was no way to secure it. we drilled through the box and bed and bolted it in.
  3. Jan 4, 2012 at 5:15 PM
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    I use J- Hooks to secure mine
  4. Jan 4, 2012 at 5:42 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    I know you said you were looking at UWS boxes ...good box ...do they list extra parts too???
    I have both a bedliner and black plastic bedrail protectors( great deal from a 4x4 shop closing )
    These guys sell the accessories you are asking about;
    www.DawsBetterBuilt.com
    I have their low-pro box in my '02 Tacoma and it is attached with their "Grip-Rite mounting kit", 2 of the pocket trays....and has NEVER given me any problems....
    The Grip-Rite should work on any bed-rail box set-up and they make it MUCH easier to remove your box for added bed space....over the J-hooks I used to keep my steel box secure......
    Good luck on your install !!!
  5. Jan 4, 2012 at 9:22 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    My old over the rails toolbox I had I mounted by drilling through the toolbox and the bedrails. It rubbed off the paint where the toolbox was sitting so once I removed the toolbox I herculined my bedrails.
  6. Jan 5, 2012 at 5:23 AM
    defleppardsg
    defleppardsg Well-Known Member
    chris
    texas
    2.7L SR5 4x4
    OME 880's, Wheeler's Offroad 5-Leaf pack. Bilstein 5100's, 1" Daystar shackles, Deck Plate Mod.
    My tool box is held on with J hooks, no drilling required and it's pretty solid. The box also came with some foam strips to stick onto the bed rails so there would be no direct contact with the paint. That being said, after having the box on for years, the sticky foam strips have shifted slightly, and there is definitely some wear on the paint on the bedrails. If I were to do it again new, I'd just make sure I got some wider strips and secured everything better. I believe that that would be enough.
