Tools and Compressors
Discussion in 'Garage / Workshop' started by Phillyguy, Jul 13, 2009.
  1. Jul 27, 2009 at 11:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    If that is a 110v motor your amp load would be around 27 amps. It is possible your circuit is under-rated for that compressor. I would suggest have the compressor on its own circuit: ie, wire a new circuit rated at 30 amps.
  2. Jul 28, 2009 at 4:13 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Thanks for the quick reply, It does only happen when the compressor has air in the tank. When it first comes on (to fill the tank initially) no problems at all, I will take a look at the check valve. Thanks again man.
  3. Jul 28, 2009 at 5:57 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Phillyguy this is a fantastic thread!
    One thing I have been meaning to ask someone for a while is, what type of hose should I get that will remain flexible in cold weather? I am not sure what type I have now but it is very stiff in cold weather and even in the summer. I don't need anything super heavy duty since I mainly only use it for running an a cheap impact gun for rotating my tires. Thanks again for starting this thread!
  4. Jul 28, 2009 at 11:09 AM
    Phillyguy
    Phillyguy [OP] Member
    Philadelphia
    09 DC 4x4 SR5
    Still brand new.
    I'm glad you find some of my rambling a little useful! Well flexibility is all relative, isnt it? What one person might thinks is stiff, another might think its pretty flexible...
    Do you take the hose outside alot or is it a garage only hose?
    How long is the hose?
    I recommend several different things with most of my customers...
    1) a swivel fitting (see image attached). This gives almost limitless movement with your tools.
    2) Sometimes recommend whip hoses. Instead of connecting the tool directly into the hose which is directly into the air compressor, buy a 3' hose (whip) that is much more flexible than your current airline and connect that from the tool to the end of the your current airline. Essentially adding another joint, but you do not have to fight the heavy hose as much. Instead of disconnecting the tool from the main air hose every time, you disconnect the end of the whip hose to the airline, keeping the whip hose on the tool at all times (basically pending preference of the operator).
    If you combined both 1 and 2, you will notice a significant difference in mobility/flexibility. These are used quite often in major factories where ergonomics is a huge play. It reduces fatigue on arms and wrists.
    It is sometimes hard to find the perfect hose because the more durable the hose, the less flexible it becomes. Adding a whip and swivel can help get the best of both worlds, just have to be careful or piercing the whip.
    In terms of actual hoses, coil hoses tend to be much more flexible than standard heavy duty lines. If you have a grainger/fastenal account, you can find ones there (brand called "Coilhose").
  5. Jul 28, 2009 at 11:24 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    what viscosity? air compressor pump oil comes in 10,20 and 30WT. maybe wrong oil for your particular comp.?
    possibly a bad pressure switch?
  6. Apr 7, 2011 at 8:50 AM
    unentered
    unentered Son of Baconator
    Jacob
    Virginia Beach, VA
    DCLB4x4MGM
    OME 886/Dakar, ARE CX, AMS Filter, WT Mats, 255/85/16s
    I was wondering if you could give me some advice. I'm looking at this compressor http://www.amazon.com/Ingersoll-P1I...ressor/dp/B0035HYJN4/ref=cm_cr_pr_product_top and was wondering if it'd suit my needs.
    I'm looking for a compressor for the garage to help with car repairs, mainly an impact gun/air ratchet, and various other tasks, like blowdowns, brad nailers, etc. Would this compressor be able to keep up and be somewhat portable for the home mechanic? A little bit of recycle time is fine, but I don't want to wait 5 minutes every time I take off a wheel, if that makes any sense. Also, could it run this impact gun without any problems? http://www.amazon.com/Ingersoll-Ran...pact/dp/B0002SRM3I/ref=tag_dpp_lp_edpp_ttl_ex
  7. Apr 7, 2011 at 10:21 AM
    unentered
    Jacob
    Virginia Beach, VA
    DCLB4x4MGM
    I'm sorry, I know this thread is ancient and Phillyguy hasn't even been on here in a year and a half. I just thought this was an appropriate place to post vice starting anew. I emailed him as well to see if maybe he'd respond that way.
    I appreciate and welcome any advice any one could shed on the subject as well, thanks.
  8. Apr 8, 2011 at 6:22 PM
    unentered
    Jacob
    Virginia Beach, VA
    DCLB4x4MGM
    Ok, ok, I get it, I shall post elsewhere!
    Did some more research and that's not the right compressor for my needs anyhow. :p
  9. Apr 9, 2011 at 7:26 AM
    RCBS
    It should be alright for home projects, etc. Not sure that it'll keep up with a thirsty impact gun though. Maybe try to find some air tools with a lower CFM consumption.
    A 20-30 gallon, single stage, 5 horse belt drive with an oil bathed pump is the smallest that I would recommend for garage duty. They cost a little more, but as the saying goes...."better to have and not need....." .
  10. Apr 9, 2011 at 9:25 AM
    unentered
    Jacob
    Virginia Beach, VA
    DCLB4x4MGM
    I wanted something a little more portable, I was looking at these two as mentioned in another thread. I think it's going to be a compromise either way, look to have good size/cfm, but 2hp vice the 5hp you recommended.
    This one for the price, seems to be pretty good considering cfm/psi/size, and weight.
    http://www.craftsman.com/shc/s/p_101...=1302273867272
    Then this one, it's a little more money, has more CFM, but a little less PSI, same size and weight.
    http://www.northerntool.com/shop/too...7527_200347527
    cheaper here
    http://www.aircompressorsdirect.com/...m=shop+portals
  11. Apr 9, 2011 at 4:42 PM
    RCBS
    Those both look to be a good compromise. Is there a local Chicago pneumatic dealer where you can get parts/service? I know there are Sears everywhere...but have heard their service can be sketchy on equipment. I bring this up because even if you are under warranty and something goes wrong, you need a place to be able to get it serviced.
    Either of these two will most likely meet your needs. Now its just a matter of parts/service for the unit you choose.
    Edit: are there any mom & pops places near you that sell equipment? you may be surprised to find they have just the compressor for you and service to back it up.
  12. Apr 9, 2011 at 4:47 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Ques.
    Any dis-advantages to running 2 lines, one with an auto-oiler, one with a dryer(4 paint), off the same compressor?
    Nothing that I can think of, but you know better than I.
  13. Apr 9, 2011 at 6:41 PM
    RCBS
    nope. I'd just put a tee in right out of the tank to the filter and to the separator, with independent ball valves. That way you can shut down the oiled line when not in use to avoid contamination. Don't use the same hose! :)
  14. Apr 9, 2011 at 8:22 PM
    unentered
    Jacob
    Virginia Beach, VA
    DCLB4x4MGM
    There's a Northern Tool not too far away, and they carry them, not sure on how their service would be, but I guess on par with Sears. I've lived here for about 6 months, don't know of any mom n pop tool/equipment places that would carry Chicago Pneumatic. Zipcode is 23323 though.
  15. Apr 11, 2011 at 1:45 AM
    #35
    Manwithoutaplan
    ID
    I have Craftsman 33 gallon tank. 1.5hp compressor i love this thing.
  16. Apr 12, 2011 at 2:51 PM
    #36
    unentered
    Jacob
    Virginia Beach, VA
    DCLB4x4MGM
    Ended up finding a Central Pneumatic on ebay $200 cheaper because the belt cover had to be replaced because of shipping, free shipping too, deal.
    #36
