Tools and recovery
Discussion in 'Recovery' started by EagleTaco, Apr 14, 2016.
  1. Apr 14, 2016 at 1:19 PM
    EagleTaco
    EagleTaco [OP] SSDD
    Kentucky
    2016 TRD OR Quicksand
    Alright, since i now have a 4x4 trd off road i will no longer be a co-pilot on trail riding and will be running em in my own vehicle. With that being said, my truck is stock (lift and tire) so I would imagine I'll definately need recovery gear at aome point and it seems that people who are serious about off roading have a few must have tools. So if y'all would be so kind as to kinda show this noob, and any others that are curious about the same thing, some good gear and ways to stow the gear.
    JimboAnz likes this.
  2. Apr 14, 2016 at 1:27 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    So many options.....probably some sort of tow strap, a way to hook a strap to your truck, like a d-ring hitch insert for the rear. Maybe some traction ramps, great for self extraction out of mud, snow etc. Maxtrax are the best, but there are off brands too. you may air down tires, so you may need some sort of air compressor. MV-50 style is a good budget one. more will chime in I am sure :thumbsup: congrats on the new rig
    http://www.amazon.com/s/?ie=UTF8&ke...vptwo=&hvqmt=b&hvdev=c&ref=pd_sl_1z98gm98fr_b
    bjmoose likes this.
  3. Apr 14, 2016 at 1:34 PM
    EagleTaco
    EagleTaco [OP] SSDD
    Kentucky
    The link is great...seems like Amazon has a since of humor for people buying gear to get out of mud/snow/sand...recovery gear and and ankle/knee braces in the same results lol
    Biscuits and JimboAnz[QUOTED] like this.
  4. Apr 14, 2016 at 1:39 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You'll be tempted to get a high lift jack - but there's really no where to jack from on a stock truck. If you want to use it for recovery, you can use this:
    http://www.summitracing.com/parts/b...rKTrByH5I8Zx3rMXqsbsDelPKhd_f56-wnhoCmrHw_wcB
    But it's useless for changing a tire.
    Bring big pieces of wood - like 2x8s a couple feet long, varying sizes, to sit on the soft/uneven under the truck in case you have to use your stock jack to change a tire.
    Tire repair kit.
    Water and snacks, and protective clothes in case you get stuck and end up "out there" longer than you planned.
    Harvo likes this.
  5. Apr 14, 2016 at 1:41 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    There've been some really good and complete lists of equipment posted here, if you search a bit, you'll find some better lists that folks have put together thoughtfully.
  6. Apr 14, 2016 at 1:49 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's really common to get "large" shackles. But take a look at your stock factory recovery point. (make sure you're looking at the recovery point, which is BOLTED on, not the little tie down loop that's tack-welded. It's not nearly as strong) Make sure that you get a shackle that's small enough to fit into that - otherwise you won't be able to connect to your (or someone elses) recovery strap.
    EagleTaco[OP] likes this.
  7. Apr 14, 2016 at 1:50 PM
    EagleTaco
    EagleTaco [OP] SSDD
    Kentucky
    I did a quick search for what i entitled this thread and didn't come up with a lot so i decided to start this for those who wish to share can and those searching for "Tools and Recovery" will hopefully have a helpful thread to read through. I do need to get some gear though. Trying to follow the motto of "Be Prepared"
  8. Apr 14, 2016 at 2:00 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    wrenches, lube, ratchet straps, snatch straps, highlift, traction boards, winch, air compressor, tire patch kit, gas cans, water, food, block of wood, spare parts, tie rods, wheel bearings, coolent, engine oil, spare cv axle, tree saver, d-rings, recovery points, floor jack, first aid, emergency sleeping bag, shovel, axle, hatchet, knife, zip ties, rope, washers, bolts, electric impact, brake fluid...
    I have all that and more in my truck at all times.
  9. Apr 14, 2016 at 2:18 PM
    Mademan925
    Nick
    Discovery Bay, CA
    Also for got a CB radio and FRS radios. compass, maps, handheld backpacking gps
  10. Apr 14, 2016 at 2:22 PM
    EagleTaco
    EagleTaco [OP] SSDD
    Kentucky
    Where do the passengers sit lol your definitely prepared for anything and there's a wish list on Amazon and puretacoma growing lol
    Biscuits and PureTacoma like this.
  11. Apr 14, 2016 at 3:09 PM
    Mademan925
    Nick
    Discovery Bay, CA
    something to jump your battery. A life straw. flashlight. batteries, jb weld, extra wire,
  12. Apr 14, 2016 at 3:10 PM
    Mademan925
    Nick
    Discovery Bay, CA
    I have two tool boxes in the bed. A large one for parts and big tools and a small one for wrenches. Food, water, first aid, sleeping bag are behind the seats. straps under the seats
    Biscuits likes this.
  13. Apr 14, 2016 at 3:13 PM
    Howen
    Howen Well-Known Member
    2016 DCSB OR M/T black w/Leer 180
    Leer cap over bed, platform inside cap, plastic containers under platform.
    Mademan925 likes this.
  14. Apr 14, 2016 at 3:13 PM
    Mademan925
    Nick
    Discovery Bay, CA
    All my camping gear is in the trailer so that helps
    Biscuits, UTdez23, Two Hawks and 5 others like this.
  15. Apr 14, 2016 at 3:20 PM
    Howen
    "All" except your spare tire, solar panel, awning, Jerry can, second set of MAXTRAX cleats, and whatever camping gear is in your SHELL!
    :thumbsup:
    Mademan925[QUOTED] likes this.
  16. Apr 14, 2016 at 3:22 PM
    EagleTaco
    EagleTaco [OP] SSDD
    Kentucky
    Who says tacomaworld puts a hurtin on the bank account...Mademan925 alone has my wallet threatening to bitch slap me lol nice set up :cheers:
  17. Apr 14, 2016 at 3:23 PM
    Mademan925
    Nick
    Discovery Bay, CA
    I did win build of the year 2014 & 2015. So im probably not the norm on here.
  18. Apr 14, 2016 at 3:26 PM
    EagleTaco
    EagleTaco [OP] SSDD
    Kentucky
    Sweet! Well, i think that somewhat sums up a goal (for myself at least) now to find stepping stones lol
  19. Apr 14, 2016 at 4:02 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
  20. Apr 14, 2016 at 4:04 PM
    Mademan925
    Nick
    Discovery Bay, CA
    Yep. I have them for my wife jeep Cherokee. The AT tires suck in the deep snow. Those have gotten us out.
    eon_blue[QUOTED] likes this.
