Tools for Head Gasket Job
Discussion in '1st Gen. Tacomas (1995-2004)' started by jvall_02oma, May 18, 2024.
  1. May 18, 2024 at 5:09 PM
    jvall_02oma
    jvall_02oma [OP] Member
    Jai
    2002 Red Tacoma TRD
    Lift
    Any recommendations for tools other than your ratches, wrenches etc.. to tackle a head gasket leak? Also any trusted sites to buy all the head gaskets and bolts etc.. to do the job?
  2. May 18, 2024 at 5:57 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I bought the Toyota kit with all the gaskets included. No regrets.
    Some sort of razor blade scraping tool for cleaning the block is good - keep the blade perpendicular to the block and scrape away. Do not use anything abrasive, especially the kind that break apart and leave abrasives in your engine.
    jvall_02oma[OP] likes this.
  3. May 18, 2024 at 6:08 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Wish I had bought 10yrs ago
    Really helpful
  4. May 19, 2024 at 10:02 AM
    woad4
    woad4 Well-Known Member
    2003 Tacoma Xtra Cab
    3rzfe
    what motor? 3rz or 5vz?
  5. May 19, 2024 at 10:06 AM
    jvall_02oma
    Jai
    2002 Red Tacoma TRD
    Lift
    Sorry I forgot to mention, it's a 3.4l v6 and it's a 2002.
  6. May 19, 2024 at 10:18 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Pulley holder/ crank holder:
    https://www.amazon.com/dp/B07Y7VT7KN
    25” breaker bar
    Bent nose pliers like @ControlCar mentioned are always great to have
    Torque wrench, personal or rental. I used my personal for 99% but had to rent a bigger one that goes to 250 ft lbs for the crank bolt.
    A nice impact wrench is worth every dollar, if you can get one in the $200 range I think that’s the sweet spot. My DCF891 got the crank bolt out instantly.
    No spill coolant funnel for refilling radiator.
    Flare nut wrenches for the fuel lines are essential
    Gasket scrapper, razor scrapper
    YotaShop for the gasket kit, make sure you get the MLS gaskets. I’d get the kit not just the head gasket, as it’s good practice to replace every gasket you remove (there are quite a few)
    You’ll want to replace the head studs and crank bolt as well as they are torque to yield. Crank bolt from dealer, head studs from YotaShop
    Jaw pullers for harmonic balancer, I used a 3 pack of assorted sizes from harbor freight and they got the job done.
    Paint pen or a torque angle finder as the head bolts are turned like 180d past a torque spec. Don’t quote me on any exact specs here of course.
    While you’re in there definitely replace the timing belt and water pump.
    If you’d like it would also be a good time to replace the fuel injectors.
    Replace the knock sensor harness as the heat inside the engine valley will have made it incredibly brittle, it will likely fall apart in your hands as you remove it. It’s cheap.
    Good time to replace the knock sensors too but they are pricey. I didn’t bother with them but I will definitely regret that if they go out anytime soon.
    ControlCar likes this.
  7. May 19, 2024 at 10:21 AM
    woad4
    3rzfe
    I used oem everything, i figured if it lasted 250,000 miles it should last me the rest of the life of the truck.
    Here are some of the parts I purchased for a 3rzfe
    $20 E-cowlboy Universal Wrench Camshaft Injection Pump Cam Pulley Holder Sprocket Holding Tool for Honda & Toyota
    https://www.amazon.com/dp/B07Q1KPDP2/?coliid=I29ZW6OPRVYKX&colid=1B693N0897FVO
    $25 Orion Motor Tech Gear Puller Set, 3" 4" 6" 3 Jaw Puller Kit for Pulley Gear Bearing Flywheel Removal, Heavy Duty Pulley Puller with Reversible Jaws 3 pcs Bearing Puller Tool Kit
    https://www.amazon.com/dp/B084SXLVK4/?coliid=I1JPFXACJPOYHI&colid=1B693N0897FVO&th=1
    $14 Performance Tool M205 1/2" Torque Angle Gauge Tool, 360 Degree Angle Scale
    https://www.amazon.com/dp/B004O7WCW4/?coliid=I3TXMDLBNJYU7J&colid=1B693N0897FVO&th=1
    $10 OEMTOOLS 25501 Automotive Gasket Scraper, Rust, Residue And Buildup Cleaning Blade Scraper Tool, 10.5" Extended Reach Handle
    https://www.amazon.com/dp/B004FEJIKA/?coliid=I2OVRV64Z84TE4&colid=1B693N0897FVO&th=1
    https://www.amazon.com/gp/product/B017CFWP58?ie=UTF8
    I usually use Sparks parts, they have the best shipping price to me. But the other two listed go back and forth on occasion with prices. When Sparks shipped my headgasket, they didnt do a great job packaging it, and the head gasket arrived bent in half. I was pretty heated when I called them, they were much nicer to me then they should have over the phone to a dick customer (me) and 2 day shipped me a new one without hassle. They got my business from here on out.
    https://toyotaparts.ourismantoyotao...tiziJTaxmD0tNUCuB1Ly3eEOsE3ByBK0aAsepEALw_wcB
    https://parts.camelbacktoyota.com/?...3P5nzG-rP05BzTcgu__V6g2FoVg9Z1hoaArWTEALw_wcB
    https://www.sparksparts.com/?gad_so...vEve0VWL6Gi9WeQR_4IEGtpA0_7x8jbIaAggAEALw_wcB
    Your aftermarket options are here: They have both oem and aftermarket. They don't sell junk, so anything on their websites are generally pretty safe!
    https://www.lceperformance.com/category-s/18301.htm
    and
    https://209yota1.com/cart/
    The following is a order list of parts i ordered for the 2.7 4cyl 3rzfe, but you get an idea of what parts i used while in there. I also did my fuel filter and water pump replacement.
    90179-10175 Nut 6
    90910-A2023 Bolt 10
    90919-01164 Spark Plug 4
    22271-75020 Fuel Injection Throttle Body Mounting Gasket 1
    90301-19006 Fuel Injection Nozzle Holder O-Ring 4
    90116-08328 Bolt Stud 2
    90116-10163 Bolt Stud 3
    90915-YZZD1 Genuine Toyota Oil Filter 1
    00295-00103 Engine Sealant 1
    90561-10018 Fuel Injection Nozzle Holder 4
    23300-79446 Fuel Filter 1
    04112-75190 Engine Cylinder Head Gasket Set 1
    16100-79445 Water Pump and Gasket
    ControlCar and time623 like this.
  8. May 19, 2024 at 10:57 AM
    ControlCar
    Steven
    Sugar Land TX
    Excellent lists woad/time!!!!!!
