Toomuch oil
Discussion in 'Technical Chat' started by sheamus, Dec 13, 2012.
  1. Dec 13, 2012 at 7:07 PM
    sheamus
    sheamus [OP] Well-Known Member
    Regina, SK
    2013 TRD OR
    Just did a change and ended up with about a quarter of a litre too much in case. Shows just under quarter inch over top mark on dip stick this morning. Should I drain a bit or leave it. Normally I would leave it, but new truck and I am fairly anal about it.
  2. Dec 13, 2012 at 7:10 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Leave it and just cut your next oil change interval in half (3 mo. or 5000 km). The 1GR-FE dipstick isn't very precise anyway.
  3. Dec 13, 2012 at 7:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Why?
    If it's going to cause damage, it's going to begin happening as soon as he starts it (and 1/2qt over is not going to cause a problem).
    There is nothing gained by changing earlier.
  4. Dec 13, 2012 at 7:16 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Personally, I wouldn't find it any trouble to drain a little. It is probably okay to leave, but "IF" something happened you would always kick yourself in the ass. Just my opinion.
  5. Dec 13, 2012 at 7:31 PM
    KenLyns
    Belly of the Beast
    My dealer recommended cutting the first two oil change intervals by half for break-in.
  6. Dec 13, 2012 at 7:33 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Okay... so nothing to do with the overfill.
    You really had me scratching my head... you're usually pretty on the ball :)
    I agree that it's not a bad idea to make the first change a bit earlier.
    On a new car, I generally hit the first change at 2000 miles and switch to synthetic from there out.
  7. Dec 14, 2012 at 7:49 AM
    sheamus
    Regina, SK
    2013 TRD OR
    I actually did my first change way early (1650km), because I wanted to get syn in there quick, as the week I picked it up it was -30C.
    Yeah, it is simple to drain some... I'll just go do it, and pick up a marked jug for the next change.
  8. Dec 14, 2012 at 8:14 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I don't know if they have them in Canada but I use those Mobil 1 5+ jugs, it's like 5.1 quarts and seems to be perfect for the V6. Just dump the whole jug in and you're good to go. I end up about 3/4 of the way up between the low and high marks.
  9. Dec 14, 2012 at 8:43 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My owners manual calls for 5.5 qts but that shows over on the stick... around 5.25 qts puts it closer to the fill mark. All the capacities are approximant according to what i've read and it's recommended to add as necssary to bring to appropriate levels. This was according in the Chilton's manual... not sure what the Haynes manual says
  10. Dec 14, 2012 at 9:43 AM
    sheamus
    Regina, SK
    2013 TRD OR
    Yeah, I think I was pretty close to 5.5, I drained little over 1/4 litre. We'll see where that puts it. Oil is still so clean, I couldn't really tell where it was reading this morning. I'll drive it, wait and check it, see where it is at.
    We have the 5L (5+ qts) jugs here but most are 4.4L (4.65 qts). The oil I bought came in 4.4L.
  11. Dec 14, 2012 at 9:52 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. This is the perfect way to go and I'm going to start doing the same. I just learned the 3/4 mark on the dipstick is around the best spot cause if you fill it to the top or overfill it, you can over pressurize the engine.
  12. Dec 14, 2012 at 10:12 AM
    Pugga
    Massachusetts
    The other nice thing about them is I drain my oil into one of those drain pans with a spout on them. I drain that back into the oil jug after I refill the engine and it's easy for me to return to the store for disposal and I can also pretty readily tell if I burned oil between changes and, if so, how much.
  13. Dec 14, 2012 at 10:27 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    That sounds like a good plan. I also use those oil drain pans but luckily just a few blocks from my house is the public works shops so I just dispose of my oil over there and they reuse it to burn their shop furnaces so its a win/win situation.
  14. Dec 14, 2012 at 4:59 PM
    KenLyns
    Belly of the Beast
    I think in Canada those are sold as 5-liter jugs. :D
    And yes, according to the owner's manual, the dipstick reading takes precedence over the nominal oil capacity listed in the specs.
  15. Dec 14, 2012 at 6:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Same company now.
    I bought both for the Taco because for my '95 Suburban, each manual had information lacking in the other, example, one gave all of the OBD codes as well as all of the ABS codes and how to jumper the OBD-1 connector to pull the ABS codes.
    The other only gave the OBD codes and provided NO information on working on the ABS system, telling you to take it to the dealer.
    But the manual that had the ABS codes and information said to take it to a shop for repair of the HVAC system. The one that lacked the ABS codes told you how to rebuild the entire AC system.
    But the Taco manuals? They are identical, and the quality of the information in the manuals has fallen badly over the last 15 years. I won't be buying one again.
    5.5 quarts is about where you want to be.
    The dipstick tends to "drag" oil out of the pan when you pull it out so it tends to read high.
    Best to remove the stick and let it sit for 5 or 10 minutes, then wipe the stick and reinsert it, pulling to read.
  16. Dec 15, 2012 at 8:07 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    another sk'er
    5L of mobile 1 here is, i think over $50 with tax
    castrol gtx is around $25
    castrol ftw!
  17. Dec 15, 2012 at 8:39 AM
    OffroadToy
    Where is that wrote and what exactly does it say if you don't mind me asking.
  18. Dec 15, 2012 at 10:10 AM
    sheamus
    Regina, SK
    2013 TRD OR
    I castrol syn for $30 at Canadian tire sale. Just gotta watch the sales for syn.
  19. Dec 15, 2012 at 10:28 AM
    BamaToy1997
    Bill
    Navarre, FL
    Overfilling does not cause any type of excessive pressure. If you do overfill by too much (and 1/2 quart is not too much) what happens is that the oil level is high enough that the journals of the crankshaft will actually "splash" into the oil. This can cause some problems. Imagine what happens when you swing a bat and it hits water. It slows down. This is the same result in an overfilled engine. The crankshaft will splash into the oil, and the end result is normally an engine vibration (remember this crankshaft is rotating at around 750RPM at idle) that gets excessive with higher RPM.
    Again though, you would need to overfill by usually 1.5 to 2 quarts too much for this to happen.
  20. Dec 15, 2012 at 10:50 AM
    KenLyns
    Belly of the Beast
    Page 454 of the 2013 owner's manual (page number may be different for other years)
    http://www.toyota.com/t3Portal/document/om/OM35A10U/xhtml/OM35A10U_0025.html?locale=en
    There's some good info in there. For example, if you intend to drive at 100 mph all day on stock tires, then the tire pressure when cold should be increased by 3 psi over the door jamb label.
