Toomuch oil
Discussion in 'Technical Chat' started by sheamus, Dec 13, 2012.
  1. Dec 15, 2012 at 11:16 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  2. Dec 15, 2012 at 3:08 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I put 5.5 quarts in and get less than 5 quarts out, 3 - 5K miles later. I have no drips.
  3. Dec 15, 2012 at 4:03 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  4. Dec 15, 2012 at 4:25 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I've got no noticeable drop on the dipstick on the Taco over 5000 (currently just over 80k), but I'm definitely not getting 5.5qts out on a drain.
    Wife's Rav4, OTOH, it's around 125k now, and for the last 30k or so it's used about a quart every 4000.
    Just enough to piss me off... don't want to change oil every 3k, don't want to wait until 5k running it low considering it only holds 4.
    So when I change the oil in the Taco, I use 5.5 and dump the last 1/2qt into the Rav.
  5. Dec 15, 2012 at 5:13 PM
    OffroadToy
    Does your owners manual show a picture of the dip stick with the low and full marks and mention below the low dot you add oil and above the full dot it's too full? Also, does your manual have a notice on that same page that says... avoid overfilling, or the engine could be damaged? Mine does.
  6. Dec 15, 2012 at 6:01 PM
    KenLyns
    Belly of the Beast
