tooter 2.7 intake manifold spacer...
Discussion in '4 Cylinder' started by tooter, Jul 11, 2013.
  1. Oct 17, 2013 at 12:19 PM
    #401
    Jrice00
    Jrice00 Active Member
    Maine
    93 Pickup
  2. Oct 17, 2013 at 1:42 PM
    #402
    tooter
    tooter [OP] play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Here's the first batch in process... :)
  3. Oct 17, 2013 at 10:32 PM
    #403
    tooter
    Greg
    Los Angeles
  4. Oct 21, 2013 at 8:27 PM
    #404
    evilone
    evilone Active Member
    evil
    southern cali
    08 tacoma 4-banger sr5 access cab 5-lug
    Great sounding product Tooter, I'd love to see if this product helps me with my own project. i got a 08 access cab with the auto. i've just ordered the fat bobs lift with the longer aal spring and the longer procomp shocks. i actually plan on taking mine offroad to places like calico here in cali. i've ordered 32" x 11.5 tires mounted on 15"x 8 wheels to help distribute the weight. i've ordered the obx long tube header for our trucks, plan on using the stock piping but using a higher flowing muffler and building my own safari intake ( just cause i think they look super badass), i'm hoping to get as much torque as possible to help move those big meats, so this looks like a great addition. Please let us know asap when we can buy one, and if you need another test rig let me know. i'm local and would love to help out.
  5. Oct 21, 2013 at 10:34 PM
    #405
    tooter
    Greg
    Los Angeles
    The first production run will be ready any day now! :bananadance:
    And thanks for your offer. I already have SingleCabGuy as the tester because he's been running his 2.7 Taco at the drag strip and has lots of timing slips for a valid before and after hard data empirical comparison. The rest of the testing was done with the prototype on the dyno before any were produced, and the results decided whether or not the spacer would yield enough real world gains to be worthy of selling.
    I've been driving every day with the spacer on my truck for 2 and a half months now, and am pleased with the increased low rpm pull. The truck doesn't feel like it accelerates any faster (although SingleCabGuy will quanfity that for sure on the drag strip) but it definitely pulls stronger at very low rpms, and feels like I'm driving a tractor. :)
    It's good you're getting a header. My header helped to lower the torque peak more than twice as much as the spacer did (650 rpm and 250 rpm), so both working together really helped to make a nice difference.
    The OBX is a really good deal.
    This OBX for 2005-2008 Tacomas is only $207 at Super Savers Accessories. :)
    http://www.ssaccessories.com/servlet/the-529/OBX-Header-Exhaust-05-dsh-09/Detail
    Greg
  6. Oct 22, 2013 at 12:31 PM
    #406
    evilone
    evil
    southern cali
    SounDS good Tooter, has anyone by chance done any research as to any gains from changing the size of our exhaust piping?
  7. Oct 22, 2013 at 12:46 PM
    #407
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Tooter do you think the obx header would be better for low end because its a tri Y? Or is a 4 into 1 long tube like a lce gonna be better for low end.
  8. Oct 22, 2013 at 11:51 PM
    #408
    tooter
    Greg
    Los Angeles
    I only have my own subjective experience opening up my stock exhaust with a Magnaflow straight through muffler. There was a noticeable loss of low end torque. And when I reinstalled the stock muffler a week later, the low end torque returned as before.
    This proves that the engine needs some backpressure for low end pull. The stock exhaust system is hardly restrictive between 1,000 rpms and 3,000rpms but it does provide enough controlled backpressure so as not to lose the low end torque.
    I'm happy with the stock muffler now that I know that removing exhaust restriction reduces the low end torque. It might add to top end performance, but I use my Taco as a fully loaded daily driver work truck that always runs under 3,000 rpm. Even on the freeway in 5th gear, only 3,000 rpm is 90 mph, and I never drive at that speed. So I'm only interested in low rpm power. :)
    Greg
  9. Oct 23, 2013 at 12:14 AM
    #409
    tooter
    Greg
    Los Angeles
    As a general rule, shorter header tubes affect higher rpm ranges. And longer header tubes affect lower rpm ranges. The OBX short tube 4-2-1 design would be better than the stock header.
    And the folded long tube LCE would be better than the OBX.
    But remember, it costs about 2 1/2 times more than the OBX so you pay for the better low end performance.
    I have dyno results for my LCE header and the stock muffler. And they show the torque peak being reduced from 3,800 rpm down to 3,150 rpm. The tooter II.VII spacer further reduces the torque peak another 250 rpm down to just 2,900 rpm. This is a total 25% reduction in torque peak rpms which is significant.
    Video of a dyno run with the LCE header, the stock muffler and exhaust, and the tooter II.VII spacer....
    http://www.youtube.com/watch?v=H6ofUy8_-6Q
    ...and a run from 25 mph to 70 mph on the road running the same components as the dyno run...
    http://www.youtube.com/watch?v=UFTl75q49e4
  10. Oct 23, 2013 at 3:21 AM
    #410
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Definitely looking forward to adding the spacer in January............LCE and oem exhaust with KVA intake (K&N tube, Volant box & aFe dry flow filter) right now.
  11. Oct 23, 2013 at 8:54 AM
    #411
    tooter
    Greg
    Los Angeles
    No problem. :)
    I'll keep them in stock so there's no hurry. The very first ones are done, and if I can get done with work quick enough, I'll be picking them up today. :thumbsup:
    Greg
  12. Oct 23, 2013 at 9:37 AM
    #412
    evilone
    evil
    southern cali
    how much is the spacer and hardware going to be tooter?
  13. Oct 23, 2013 at 4:12 PM
    #413
    tooter
    Greg
    Los Angeles
    The spacer kits are $245 including shipping. I just now started a FOR SALE thread in the 2nd Generation Marketplace. All of the information is there.
    Greg
  14. Oct 24, 2013 at 3:35 AM
    #414
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Third coast sales rep discount available? :D
  15. Oct 24, 2013 at 7:45 AM
    #415
    tooter
    Greg
    Los Angeles
    Sorry T@co... these spacers aren't commercially mass produced. Each one is manufactured one at a time so the cost per unit is considerable.
    This is just a fun hobby. I have a real job that makes money to fund this project. My goal is just to break even on these spacers so that I can use the original capital to fund another project, because I also have ideas for other products. :)
    Greg
  16. Oct 24, 2013 at 7:46 AM
    #416
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    do tell :spy:
  17. Oct 24, 2013 at 8:33 AM
    #417
    tooter
    Greg
    Los Angeles
    My wife's car is a 2012 Yaris...
    The results were so good for the tooter II.VII intake manifold spacer, I'm going to make a 2 inch thick tooter I.V for the 1.5 1NZ FE engine. :)
    Greg
  18. Oct 29, 2013 at 7:48 AM
    #418
    tooter
    Greg
    Los Angeles
    When the spacer is installed, the throttle body is relocated 2 inches to the right so that the plug will not reach to the socket...
    If you remove the wiring loom from two of the holders and gently unwrap it, you will be able to free up enough slack from both the throttle body wires and the #2 ignitor wires so that both will reach their destinations. This reolcates the loom outside of its holders, so a couple of zip ties are needed to reattach it to the outside of the two brackets.
  19. Oct 30, 2013 at 1:37 PM
    #419
    holokai
    holokai Well-Known Member
    Honolulu
    '12 PreRunner SR5 Access Cab
    Installed: OEM Bed Mat, Secondary Air Filter Delete/AFE/stock CAI elbow mod, LEDs ( Rear License Plate, Map, and Dome Lights), Ceramic Tint (Front 35%, Rear 27ish%), Viper Security, Image Dynamics Front Components, 4 channel Arc Audio Amp (rear channels bridged for sub), Kicker CVT 6.5 (yes, it's a tiny sub but it's enough to keep me happy), Headunit (Bluetooth and iPod/Pandora), EGR Window Visors, OEM Door Sill Protectors, Roll-N-Lock, Wet Okoles, Fog Lights with 2500k bulbs, UltraGauge EM, Spidertrax spacers, Smittybilt Side Steps, Tooter 2.7 Intake Manifold Spacer Upcoming: LCE Headers?
    Additional shipping costs to Hawaii? Thinking January. Thanks.
  20. Oct 30, 2013 at 3:21 PM
    #420
    tooter
    Greg
    Los Angeles
    All the spacers ship USPS Priority Flat Rate because they fit into their medium size box. One went to Alaska for no extra charge. I'll check for Hawaii and get back to you. :)
    Greg
