tooter 2.7 intake manifold spacer...
Discussion in '4 Cylinder' started by tooter, Jul 11, 2013.
  1. Aug 11, 2013 at 5:44 PM
    #101
    tooter
    tooter [OP] play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I picked it up this afternoon and stainless steel bead blasted it to normalize the surface, and I'm starting to take off the manifold to install it...
    Elapsed time from project conception to first prototype installation:
    ONE MONTH :)
  2. Aug 11, 2013 at 7:37 PM
    #102
    tooter
    Greg
    Los Angeles
    How did the spacer fit?...
    "Like a gluuve..."
    However...
    The intake manifold is an octopus of tubing, so naturally moving it to a new location, nothing fits. A few of the tubes appear to be flexible enough to work, while others will need longer lengths to fit. I'll record in detail everything that needs alteration.
  3. Aug 11, 2013 at 10:14 PM
    #103
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  4. Aug 12, 2013 at 4:14 AM
    #104
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    Wow that sure looks pretty, if it doesn't do anything at all it still looks cool. ;)
  5. Aug 12, 2013 at 5:30 AM
    #105
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i can't wait to hear the results of this!
  6. Aug 12, 2013 at 5:32 AM
    #106
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I would be down for one of these depending on gains and price. Already have the LCE.
  7. Aug 12, 2013 at 8:41 AM
    #107
    tooter
    Greg
    Los Angeles
    Yeah, it could end up just being a nice looking paperweight. ;)
    I do know this. Lengthening the runners on an intake manifold definitely changes the operating characteristics of the engine. Exactly what and how much I don't know. So that's what this is all about... finding out. :)
    The engineer and I were talking about if the tooter spacer produces proven documented gains on the dyno, building more out of nylon instead of aluminum. So the prototype may be the only metal one. Man, is it heavy. It weighs four pounds. :eek:
  8. Aug 12, 2013 at 9:16 AM
    #108
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    How would that relate to heat dissipation? Any thoughts?
    I'm kinda fascinated by this thread. :eek:
  9. Aug 12, 2013 at 9:25 AM
    #109
    camojared
    Jared
    SE Ohio
    If it is proven to make gains what would the price of an aluminum one be? I would prefer aluminum over nylon. Just my .02 Nylon is easier to work with though.
  10. Aug 12, 2013 at 9:49 AM
    #110
    tooter
    Greg
    Los Angeles
    Yeah, Homer... so am I. :)
    It's lots of fun exploring uncharted waters. I'm not certain of the effect. All I do know is that a larger heat sink is able to dissipate more heat. A non metal spacer would render the whole issue moot.
    Running it on the dyno will provide us with useful "real world" results of how well it works, or even if it works at all.
  11. Aug 12, 2013 at 9:52 AM
    #111
    tooter
    Greg
    Los Angeles
    Beats me. :confused:
    It's scary how little I know about this stuff. :laugh:
    The CNC machine uses exactly the same xyz coordinates to fabricate the parts, so both metal and non metallic spacers could be made.
  12. Aug 12, 2013 at 9:59 AM
    #112
    tooter
    Greg
    Los Angeles
    I don't know that yet, as I need to find out if this concept will even work first.
    This is actually not my decision what they're made out of. It's yours, because the customer decides what they want them to be made out of.
  13. Aug 12, 2013 at 11:31 AM
    #113
    tooter
    Greg
    Los Angeles
    While the intake manifold was off, I took the opportunity to do a little light porting on it as it had these irritating bulges and casting seams on each side of the intake port...
  14. Aug 12, 2013 at 1:23 PM
    #114
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    Good luck with the mods!
  15. Aug 12, 2013 at 2:17 PM
    #115
    tooter
    Greg
    Los Angeles
    Thanks, man. :)
    It's going a lot better than I had expected it would at first look...
    The manifold went on with a certain amount of pushing on all of the many surrounding hoses. It went in vertically back end first and then I rotated it to slide down over the studs.
    Better than just adding runner length, the spacer adds more STRAIGHT runner length just before reaching the injector and intake valves. :)
    I also discovered that the hose mounting bracket mounting holes were offset enough to reverse them so that they would fit onto the relocated manifold without any stress on the hoses.
    The throttle body plug is an obvious issue. I'm going to try unwrapping the loom just to see how much length can be freed up. It doesn't take much to reach the relocated socket.
    The rear throttle body coolant hose needed to be disconnected as it is in the way when you tighten up the nut on the rear stud.
    Because the spacer exactly duplicates the perimeter of the stock manifold, is offers plenty of clearance for the fuel injectors and fuel rail.
    The bottom studs turned out to be the biggest issue as they do not point in exactly the same direction as the top studs, so as the manifold is moved outward sliding on the upper studs, the lower ones do not line up with the bottom holes on the manifold. I'll likely need to make two small plates with two holes in each plate, bolt the manifold on to the plates and use the lower holes to connect to the engine block. I can make them using the extra stock manifold, so I don't need to take this one off.
    Dang if it isn't almost ready to run! :)
  16. Aug 12, 2013 at 2:21 PM
    #116
    camojared
    Jared
    SE Ohio
    Thanks tooter can't wait for you to get the octopus fixed and see how it works.
    Edit- I see on page 7 you already have :)
  17. Aug 12, 2013 at 2:23 PM
    #117
    tooter
    Greg
    Los Angeles
    See above. /\
    You posted just before it went up. ;)
  18. Aug 12, 2013 at 2:31 PM
    #118
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Aight so I gotta ask ......... Where does "tooter" come from?
  19. Aug 12, 2013 at 2:58 PM
    #119
    tooter
    Greg
    Los Angeles
    One of my hobbies is 1/8th scale model railroading in my back yard...
    ...and that's my screen name on the model railroad forums so I just kept it. ;)
  20. Aug 12, 2013 at 3:08 PM
    #120
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    YOU GUYS HAVE SO MUCH SPARE ROOM IN YOUR ENGINE BAYS IT IS RIDICULOUS.
    In comparison:
