Top 10 maintenance procedures for maximum tacoma life
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brianMTB, Jul 4, 2017.
  1. Jul 4, 2017 at 10:28 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If it hasn't been done, I would do the following this weekend - if it were my truck: Flush coolant; replace radiator hoses; replace serpentine belt; replace thermostat; replace pulley bearings; replace ATF filter; flush ATF; replace gear oil all around; replace plugs with Iridiums; replace oil & oil filter with full synthetic. That's 11 things.
    Carefully inspect the following and replace accordingly: brake fluid, PS fluid, air & cabin filter, u-joints, carrier bearing, brake pad/rotor wear, front wheel bearings, ball joints, LCA bushings. Also, do a battery load test as well as a load test on your charging system. All the how-to's you need you will find in the Mods & Tutorials drop-down.
    Consider doing the reverse light mod and the tailgate security mod. Look up Cheap Tacoma Mods for other helpful hints.
    whysosirius likes this.
  2. Jul 5, 2017 at 5:42 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I don't think you need a list of things. Just replace things as they break or wear out. Change the oil regularly (intervals will differ for everyone) I'm going on 9-10k mile intervals as recommended by Blackstone https://www.tacomaworld.com/threads...y-a-build-journal.125201/page-7#post-15431989
    . My truck is at 101k and no problems. I've only changed the trans, diff fluid and plugs once.
    Don't over-maintain it. It's a waste of time and money ;)
