Top Cars Owners Keep for 10 years or more, Tacoma is....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Pete626, Nov 2, 2015.
  1. Nov 5, 2015 at 11:47 AM
    #61
    tgear.shead
    tgear.shead Well-Known Member
    Let me illustrate with an example;
    A manual 4-cyl that happens to be delivered with a LUK clutch in a cold climate. Regardless of what year it happens to be manufactured, it will probably need a new clutch after around 10,000 miles when things smooth out and the clutch no longer grips. Things like that that lead to downtime on a new vehicle, because it means that its going to take several dealer trips to convince them of the problem, and then its going to have to sit there for probably a week while they're futzing around with it. Once you get that problem out of the way, you can expect a much more normal/long life for the replacement clutch.
  2. Nov 5, 2015 at 8:39 PM
    #62
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    I'm tracking on the point you're trying to make, I just think it's over-exaggerated and I disagree.
    How many Tacomas do you think burn out clutches within the first 10k? Furthermore, how many new vehicles do you think burn out a clutch within the first 10k? I mean, do you really think this is a common problem - are you serious?
